Shop our productsAmong various choices of solar generators available on the horizon, BLUETTI products stand out for their reliability, efficiency, and lifespan. A BLUETTI solar generator could effortlessly power your house needs, whether you want to rely on this as a power backup in outages or planning to go off-grid altogether.
However, it's crucial to understand what size of solar generator should be compatible with your home energy needs, how to choose it, and what potential benefits it could reap. This guide will answer all those queries.
Along with this, we will also recommend the 3 best solar generators from BLUETTI while discussing their life span and what devices they can run, like fridges and air conditioners.
The Benefits of Using a Solar Generator to Power a House
The shift in the use of solar generators around the globe is phenomenal, and that is, too, for some good reasons. Whether it’s about clean energy, free power supply, or pollution-free electric power, solar generators bring multiple benefits to the table.
Below discussed are some of these.
Reduced energy costs
Free energy is the fundamental benefit associated with solar generators. These units produce their power from the sun and, thus, don’t need any costly fossil fuels. Additionally, unlike the maintenance requirements of conventional generators, these solar systems do not require regular checks, further saving you some money.
However, the initial investments for solar generators are relatively high. But once done, you can harness the benefits of free energy for the life span of the unit.
Clean and green energy
The havoc caused by climate change in recent years is steering the world in a new dimension. The use of clean energy has never been more critical, and solar generators are best at that. They do not consume fossil fuels, and the energy they produce is green with zero carbon footprints.
Safe operations
One crucial concern associated with generators is the emission of carbon monoxide during their operations. This odorless gas could have severe health consequences for humans. Solar generators do not emit any toxic gases, making their indoor use more reliable and safe.
Sustainable power source
Solar generators are reliable and sustainable sources of energy. Unlike their conventional counterparts, they do not need regular refueling. You only need to attach a couple of batteries to them. They will produce power, which eventually will be utilized by appliances, and extra energy is stored in batteries for further use at night or during cloudy days.
Tax incentives
COP 27, a UN climate change conference that was recently held in Egypt, has further emphasized countries for clean energy initiatives. Thus, many governments are offering tax credits to invest in solar generators. This can significantly reduce the initial cost of these units, further making them budget-friendly.
However, it's important to note that these tax credits could vary from state to state, so checking your specific state guidelines related to this is recommended.
Increased home value
A recent survey by Zillow reveals that solar generators boost the average value of your house to around 4.1%. It further states that houses with solar generators sell 17% more and 20% faster than that of homes without solar generators.
So these units not only help you with cutting your energy bills, but their installations can also improve your overall house value significantly.
Can a BLUETTI Solar Generator Power a House?
The simple answer is YES. However, which BLUETTTI solar unit could do this effectively depends on your house's energy consumption patterns. Here is a simple breakdown of this.
Firstly, there is a wide range of BLUETTI solar generators available. All these units have their respective output power and sizes. A big machine like AC500 has an extended output power, thus suitable for the entire family's power needs.
Additionally, batteries are crucial for solar generators to store extra power produced during sunlight hours. This power is used at night or in restricted sunlight conditions. The larger the battery is, the more energy it can store and power your house effortlessly.
Lastly, it is important to understand your home energy needs before opting for any solar generator. You can get an average of your daily use through your monthly energy bill. To run your whole house, the solar generator output capacity must be higher than your requirements.
How to Choose the Right Size Solar Generator for Your House?
A solar generator is a unit that consists of three fundamental parts that are solar panels, inverter, and batteries. While deciding which size of solar generator will be suitable for your house, multiple factors need to be considered.
Below is an explanation of all these concerns to help you navigate through this.
Purpose of solar installation
Solar generators are mainly used for 2 functions, either as a power backup in blackouts or as a solution to cut your hefty energy bills. The size of generators that will be suitable for your house greatly depends on these two factors.
You see, in the case of blackouts, the use of solar generators is periodic. So, in this case, a small size unit can also serve the purpose. On the other hand, if you want to cut your energy bills, your solar generator's power generating and storage capacity should be high to meet your day-to-day power needs.
Understand your energy consumption patterns
Getting an estimate about your energy requirements is another crucial factor in deciding the right size of solar generator for your house. The simple go-to approach for this is collecting your previous energy bills for around 10-12 months and getting an average of your monthly power consumption.
Now, for example, if your monthly energy use is around 60000W, a solar unit with a 2000Wh battery could effectively service your energy demands.
Wattage requirement of your appliances
Besides your daily energy consumption, it's mandatory to calculate the wattage requirement of specific devices. This is because if you are running multiple devices simultaneously, your solar system should be capable of that. You can quickly figure this out by following these simple methods.
- Check the wattage of each device given on their labels. If this is given in Volts and Amps, you can multiply both to convert it into Watts.
Volts X Amps = Watts
- Look for the surge power of these devices. Surge power is the initial amount of power an appliance uses to get started. It is higher than the running power requirement of that device.
- Now add all the wattage and set maximum surge power as a borderline. Solar generators that can fulfill all the wattage requirements of your devices and have a surge power above your borderline will be suitable size generators to run your whole house.
Related articles: How Big of a Battery Backup Do I Need for My House?
Will My House Sell More with Solar Panels Compass? You Must Know
What Size Solar Generator Do You Need for a House?
3 BLUETTI Solar Generators for Your House
Here are our top 3 Solar generators from BLUETTI. Besides their reliability, efficiency, and life span, these generators have different powering capacities that would be suitable for a medium to large size household.
You can choose what aligns best with your requirements.
BLUETTI AC500 + B300S
This giant system is what you need to run your entire household. With its 5000W output capacity and a surge of 10000 W, it can support nearly all your devices, whether it's an AC or refrigerator.
Its LiFePO4 battery offers a storage capacity of 3072Wh, which can be expanded up to 18432 Wh with additional batteries. The lifespan of this battery is 3500 plus charge cycles. This means it can last more than 10 years with one charge cycle per day.
To further ensure that you do not have to rely only on solar energy, the unit comes with 6 recharging streams and can be recharged through a car, lead acid battery, and solar+AC current.
With its 16 output ports that can support 99% of your devices and a 4-year hassle-free warranty, this could be the solution if you need the unit for your entire family's power needs.
This medium size solar unit comes with an output power of 2200W and surge power of 4800W. Its pre-built is 2048Wh, but if your needs roll over, this can be expanded up to 8192Wh with two additional B300 batteries.
With only a 28.1 Kg weight, it is easily portable and can be recharged through 7 different streams. With a solar input that allows 900W input, it takes around 3 hours, and with Solar+AC, that is, a 1400W input, the system only takes around 2 hours to charge itself.
Additionally, its LiFePO4 battery has 3500+ charge cycles and is integrated with a battery management system to deal with all the safety and reliability concerns associated with batteries.
Though this is a medium-sized unit, to ensure it is compatible with all your devices, there are multiple output ports available, including AC, DC, USB, and wireless charging ports.
BLUETTI EP500 + 3*PV200
The last product on our list is equally recommended for both travelers and house use. The EP500 comes with two tires to ensure its easy portability. From a power perspective, the unit has an output capacity of 2000W and an exceptional battery of 5120Wh.
But what makes EP500 stand out from its competitors is its lifespan. With 6000+ plus charge cycles, this unit lasts more than 20 years. Other features include a 5-year hassle-free warranty, LiFePO4 battery, multiple output ports including wireless charging, and a cigarette lighter.
To further make its operations smooth, EP500 could also be operated through the BLUETTI smart app and have an integrated touch screen. Its sleek design not only helps you with power needs but could also add to the beauty of your house interior.
Key Features of BLUETTI Solar Generator
BLUETTI itself doesn't need any introduction when it comes to solar generators. It is a leading brand that is providing reliable and efficient products worldwide. Here are some key features that make BLUETTI solar generators the best options available in the market.
- Price Match Guarantee: When it comes to solar generators, their hefty initial investments are a big concern. Unlike its other competitors, BLUETTI offers a price match guarantee. This means that if you find any BLUETTI product that is more expensive than any other same-size product, you can claim the extra cost within 30 days of purchase.
- Life-Time Customer Support: BLUETTI aims to provide a hassle-free solar experience to its customers. For this, it ensures exceptional quality control during the manufacturing process. But in case you come across any issue and need support, customer service representatives are available there 24/7, and this offer is for a lifetime.
- Integration of Modern Tech: To make operations smooth and convenient, All BLUETTI products are integrated with modern tech and can be operated through BLUETTI smart app control.
- Compatibility: All the BLUETTI products come with multiple output ports to ensure compatibility with all your home appliances. Additionally, to ensure your solar unit does not run out of power in case of no availability of proper sunlight, the batteries of these solar generators could be charged through various charging streams.
- Eco-friendly products: There are various solar generators available in the market that come with various types of batteries. But in the case of BLUETTI, our solar generators have LiFePO4 battery type that ensures a green future and clean energy for you and your children.
The life span of a solar generator is calculated by the charge cycles of its batteries. BLUETTI offers a range of products with charge cycles of 3000-6000 and a life span ranging from more than 10-20 years. And this does not mean that after this time, the products could not be used. This only means that after this period, their efficiency might be low compared to new products.
Can a BLUETTI Run a Fridge?
Basically Yes. Conventional home refrigerators usually require a power of 300-800 W to carry their functions effectively. All of the BLUETTI products, big units like AC500, are capable of running home refrigerators.
However, the running time of these units depends on the battery capacity associated with them. For example, with BLUETTI AC200MAX, you can run a 300W refrigerator for 15-25 hours while
Can BLUETTI Power an Air Conditioner?
Basically Yes. The case is the same with air conditioners as with refrigerators. However, the power required for AC is measured in BTU. Most ACs require between 8000 and 14000 BTU to carry out their functions. With AC200MAX, you can power an AC of 8000 BTU for 6-14 hours.
Additionally, for portable AC, the power requirements are low, thus nearly all BLUETTI solar generators can run those air conditioners.
Solar generators are reliable, convenient, and economical solutions to support your household electricity needs. They are not only sustainable power backup solutions but could also help you effectively cut your hefty energy bills.
However, because of their high initial cost, careful planning is necessary when choosing any solar generator. Ensure it has a good life span, is compatible with all your home appliances, is safe for use, and the brand's overall customer feedback is good. But in case you want to scrutinize your research, BLUETTI is the solution for all these features.
