Shop our productsSolar power technology has improved and become more lightweight, allowing panels to be utilized to charge any gadget. Solar panels are a choice that can be used for a variety of outdoor activities, and they fold up for simple transport, as the name implies. They serve as a foldable power source for your electronics, charging their batteries with sunlight.
These panels can keep your electronics charged with solar energy whether you're trekking, camping, or simply enjoying a day at the beach. We'll show you various panel solutions we recommend, as well as their greatest uses and how to pick the right folding solar panels for camping.
Types of Foldable Solar Panels
- Monocrystalline:These panels are the most efficient because they can generate a large amount of energy even when sunshine is scarce. Monocrystalline solar panels have the highest efficiency. They're the most expensive of the three, but they're also the most robust and resistant to severe temperatures.
- Polycrystalline: These solar panelsare the ideal solar panels for RVs since they are made up of many blocks of silicon. They are less expensive than monocrystalline panels and take up far less space than amorphous panels. Although they don't produce as much electricity as monocrystalline panels, they're still a smart RV investment.
- Amorphous: These panels are made by spreading silicon across a wide bed. Thin-film panels, as they're also known, are popular because they're less expensive than the first two while also being more flexible and allowing for additional installation alternatives. On the downside, they can take up three times the amount of space as polycrystalline and monocrystallinesolar panels while providing the same amount of power.
How to Choose the Best Foldable Solar Panel for Camping
Any solar specialist will tell you that choosing the appropriate product is critical, and this is true for both foldable and stationary solar generators. When shopping for solar panels for camping, search for items that are both robust and simple to use. Because you're working with electricity, safety is crucial; utilizing low-quality solar panels increases the chance of electric shock. Other key considerations to consider when choosing solar panels for camping are as follows:
- Size and weight:Higher-wattage solar panels can power more items, but they're also bigger and heavier. If you travel by car, a larger system is feasible, but when trekking, a lightweight and fold out solar panel is a preferable option.
- Compatibility:Before purchasing a solar power system, confirm that it has the proper ports and voltage for the appliances you'll be connecting to it.
- The convenience of setup and portability: Compact solar panels are lightweight and simple to set up, but most of them are limited to smartphone charging and LED lighting. Larger panels on chargeable power stations need more effort to set up, but they generate more electricity.
- Is it Durable:If your solar panels will be exposed to water and dust, find a panel with a protective cover.
- Charge time and run time: When selecting foldable solar panels, there are two key charging times to consider: the time it takes to charge your electronics and the time it takes for them to charge their own batteries. If you're going camping for a few days, you'll need a solar panel system that can be recharged daily using the sun.
- Price: Price is an important factor that you need to consider when choosing asolar panel. Usually, the price of solar generators ranges from $300 to $2,000. You need to choose the right product according to how often you will use the panels.
Questions You Need to Figure Out Before Buying a Foldable Solar Panel for Camping
1. How many times do you travel in one year?
Do you travel only on a few occasions, primarily over long weekends? Do you try to take vacations for a month or two at a time? Do you take a lot of trips?
2. Is your solar panel a long-term investment or for short-term use?
Do you not see the point in spending money on accessories that you'll only use a few times? Would you like to be able to travel more regularly and for longer periods of time? Do you want to ensure that you can rely on your equipment when you are out in the field?
3. Are you going on a short or long trip?
Do you want to get deeper into a destination to learn more about it? Do you wish to take a fast excursion to a nearby location?
4. What is the total weight that you’ll be allowed to carry?
Do you have to worry about overcrowding your van or vehicle? Would you like to reduce the weight and size of your luggage? Do you value solar energy and wish to include it in your vehicle.
For the casual camper
The BLUETTI SP120 120W Solar Panel
Technical Details |
Peak Power(Pm) |
120W |
Operating Temperature |
-10℃~65℃ |
Best Working Temperature |
25℃ |
Folding Number |
4 |
Dimension( unfolded ) |
411*1708mm/16*67in |
Dimension( folded ) |
411*427mm/16*16.8in |
Weight |
4.3kg/9.48lb |
As you can see, this BLUETTI PV120 120W Solar Panel is lighter, smaller, and carries a low power rating. It’s very suitable for charging your smart phone, laptop, or iPad. If you are heading away a few times a year, it will be a good choice for you.
Its solar cell has a maximum power of 120W and its total weight is 9.48 pounds only. The adjustable kickstand allows you to adjust its angle at any time to maximize power utilization.
For the frequent visitor
If you are planning travel frequently, then the battery capacity will be your first consideration. A power bank with larger capacity means it can power more devices and has a longer running time. While, it will also mean higher costs, but this is good for your long-term investment.
Bluetti AC200P Poratable Power Station has a large capacity of 2000 watt-hours and five charging methods( AC/ solar panel/ car lighter port/ generator/ lead acid battery). It can be charged within 3.0 hours with tow adapters.
It will be able to power the following appliances:
- Smart phone(10w) - 175~200hrs
- LED lamp(20w) - 75~85hrs
- Fridge(90w)- 17~19hrs
- Electric cooker(200w) - 8~9hrs
For the full-time visitor
If you will spend your time in a long trip, this AC200MAX Power Station + 3*PV200 Panel Combo will be more suitable for you. It includes a power station and 3 fold out solar panels. You can pay less money but buy more products. Power station is used to power your RV, and solar panels can be placed on the roof of your RV and use sunlight to power the power station. In this case, to save your time.
Support for wireless charging is a highlight of AC200MAX power station. You only need to put your phone on the top of AC200MAX vertically (if your phone supports wireless charging), and turn on the DC in mainpage on screen.
In addition, the BLUETTI AC200MAX supports Bluetooth connection and can be controlled by the new BLUETTI Smartphone App (iOS & Android).
How to Maintain Foldable Solar Panels For Camping
For your solar panels to work at their best, they must be maintained. Consider how much dust, tree sap, and bird droppings fall upon your solar panels as you go. The more things you put on your panels, the less efficient they will be because sunlight will have a hard time getting through. Solar panel maintenance is extremely quick and simple. It all boils down to routine cleaning. You won't need any special tools, so you'll be able to keep your panels in top shape while on the road.
Early morning or evening are the best times to clean your panels because they can get very hot throughout the day (and you will get heated in the process!)
What You Will Require:
Bucket, Water, Hose, Sponge, Soft Mop or Squeegee
Maintenance Procedures for Solar Panels
- Using a hose, clean your fold up solar panels.
- Clean the panels with water using a sponge, mop, or squeegee. Anything on the panels' surface will be removed with this method.
- To remove any soap residue, hose them down again.
- Remove any leaves or debris from beneath thesolar panels that may be obstructing the airflow.
Keep in mind that a solar panel system that is inclined will benefit from rain showers naturally, whereas a flat system will require more frequent cleaning. Make sure your solar system is cool before cleaning the solar panel or blanket. Cleaning instructions should be found in the product documentation, as some panels allow soapy water to be used during cleaning while others do not.
Sharp or harsh materials should not be used to clean the solar panel since they may cause damage. You want to avoid scratches on the surface of your solar panel in order for it to perform as efficiently as possible. When cleaning the foldable solar panel for camping, avoid using strong pressure to avoid damaging the cells. Cleaning the surface of a solar blanket after each use will help keep the cells efficient for longer.
Replace parts of your solar panel system as needed or as directed by the owner's manual. Even if the system is only slightly damaged, it can have a significant impact on efficiency, as well as cost you more money in the long term.
Frequently Asked Questions about Solar Panels
1. Can a solar panel power a solar generator?
For anyone looking to harness the clean, renewable energy of the sun, a solar generator is a great option. To use this power source, you can use a solar panel to charge your power station.
2. How do you use solar panels while camping?
Solar panels can be used to charge batteries or solar generators as well as recharge electronics directly. When the sun is shining, certain panels can be directly linked to phones or small gadgets to charge them (panels must be angled toward the sun). Direct sun charging, on the other hand, might be unpredictable. It's ideal to capture energy using a solar panel and store it in a battery (such as a solar controller, battery pack, or charge station), then connect devices to it.
3. Are folding solar panels for camping waterproof?
The majority of solar panels are waterproof or weather-resistant, which means they shouldn't be submerged in water but can be kept outside in light rain. That isn't to say that every panel should be left outside all of the time. Confirm with the manufacturer that the panel will fulfill your requirements.
4. Can a solar panel run a camping fridge?
A camping fridge can be powered by solar panels. You'll need solar panels that match the power usage of your refrigerator, as well as a solar-powered generator. Solar panels are great options for using solar energy to power your refrigerator.
Because they can be used to recharge smartphones and emergency gadgets when you're off the grid, foldable solar panels for camping make journeys safer. Many of them come with built-in LED lamps for use at night, and larger variants can power most 110V appliances. Solar panels are absolutely silent, therefore they will have no impact on the environment. They also use a free resource (the sun) that can be found almost anywhere.
