Shop our productsThe world around us is rapidly changing. Innovations for turning sunlight into clean energy to power our lives is advancing all the time. One such way is to use solar energy to power your garden.
Imagine using carbon free energy to grow and nurture your flowers, fruits and vegetables. You don’t have to imagine anymore – it’s reality. And it’s easier than you might think to do.
So how do you turn your garden into a solar powered sanctuary – without breaking the bank or too much complexity? That’s what this article will show you how to do!
Why Should You Use Portable Solar Power Systems for Your Garden Tools?
If you are an avid gardener, these handy devices can help you power your gardening equipment, so you can spend more time tending to your plants and less time worrying about how to charge up your tools.
Here are quick benefits of portable solar panels and portable solar generators:
- They increase productivity. The more productive you are, the more money you make — and the less time it takes for your garden to become profitable.
- They reduce fuel costs. Portable solar panels and generators use electricity instead of gasoline or diesel fuel, which saves users money over time and also reduces emissions.
- They are efficient at any location — even in bad weather conditions like rain or snow. You do not need direct sunlight for these devices to work correctly; they will still produce power when it is cloudy.
Gardening Essentials You Can Power With Portable Solar Power
Here are some examples of great solar-powered gardening tools and equipment:
Lawn Mower
Anyone who has spent time in the garden knows that mowing the lawn is a necessary evil. However, that does not make it any less enjoyable. The only problem is that you need to be able to mow the lawn regularly, especially if you have a large backyard. If you have ever tried using a lawn mower powered by solar panels, then you know how much easier it is to do it this way.
The solar panel can be installed on top of your home's roof for charging the battery and taking charge of the sun's rays directly. The battery will power up the machine's motor when needed. You can also charge it from an electric outlet if no sunlight is available.
Leaf Blower
The leaf blower is another excellent tool to have in your solar-powered backyard. This is especially true if trees or other plants drop leaves regularly. The leaf blower will help you clear away those leaves so you can get back to enjoying your time outside.
The best part about this tool is that it uses no fuel and only requires electricity from a power source or battery. You can even use a portable solar panel to charge the battery when needed so that you do not need to worry about running out of power on any given day.
Hedge Trimmer
A hedge trimmer is essential in your garden if you want to keep your hedges tidy and looking good. These machines require uninterrupted electricity to work, which can be a problem if you are working on the edge of the grid where power sources are few and far between, and fallouts are likely to happen often. It is best to be prepared for these incidents in these situations, so they do not interrupt your daily activities.
The best way to do this is by using a portable solar generator. This generator will work with your hedge trimmer by powering it up when it needs to work. The best thing about this setup is that you can easily set it up outside and have the device working whenever you need it.
Pond Pumps
Pond pumps are used for various purposes, ranging from water circulation and filtration to maintaining the correct water temperature. Without them, it would be challenging to have a healthy pond in your backyard that is free from bacteria and other harmful organisms. However, they also require a constant electricity supply throughout the day to function correctly. This can be problematic if you live in an area where power outages are expected or if there is no access to a reliable source of electricity.
For this reason, investing in portable solar panels is best so you can use them whenever needed. The panels come with a storage battery and will store energy during the day when the sun is out so that it can be used at night when the sun goes down. These panels will allow you to plug your pond pump into them anytime, so you would not have to worry about being limited when your area is experiencing a power outage.
Yard Lights
Whether you are trying to hang out with friends and family or simply work outside at night, you want to ensure that plenty of light is available for you. In fact, some areas may need a lot more than others—if you are hosting a party, you will want to have enough lights for safety purposes so people can see where they are going. Similarly, if your backyard has unforeseen obstacles like trees or rocks, you would not want to run into them at night because it is too dark.
To make sure that these yard lights work when it is dark, connect them with portable solar panels. When you choose solar power for yard lights, you do not need to worry about installing them underground or buying wiring. Plus, there is no risk of someone tripping over them and getting injured since these portable solar panels are very lightweight. With these bright lights powered by solar panels, you can ensure that it will always be safe for family members or friends in the solar-powered backyard late at night.
Bug Zappers
One of the main reasons people enjoy having a backyard is because they can use it as a place to relax and unwind from their daily lives. To do this, however, you need to ensure that your yard has a peaceful atmosphere without disruptions. This may be difficult if you have an area infested with bugs like mosquitoes or flies.
To prevent these pests from ruining your time outdoors, consider using bug zappers. These devices will attract them to their light source and then kill them by electrocuting them with electricity. When used alongside portable solar panels, these bug zappers do not require wiring or installation work, so they can be placed anywhere in your yard without causing any problems.
Water Sprinklers
While it’s not exactly a revelation to learn that water sprinklers can benefit your yard, help promote the growth of grass and reduce the amount of grass that dies due to droughts or other factors, an above-ground sprinkler system will need to be hooked up with a power supply to work. If you lose power, the sprinklers will stop working, and your yard will not get watered. To avoid this problem, you can use a portable solar generator instead.
When choosing a portable solar generator for your sprinklers, make sure that it can handle the amount of pressure, usually around 20 PSI. Also, look at how much power they need; some portable solar generators can only supply enough energy for a single sprinkler, while others can power up multiple ones. Finally, consider how easy it is to use and whether or not there is any maintenance required afterward. If so, will you be able to perform it yourself?
Weed Whackers
Weed whackers are essential for any homeowner who wants to keep their yard looking nice. Weed whackers cut grass, weeds, and other plants in your yard. They have long blades that spin quickly and can be used to make quick work of unwanted vegetation.
A weed whacker is usually powered by gasoline or electricity, but if you want a more environmentally friendly option, you can use a portable solar generator instead. Portable solar generators are ideal for powering weed whackers because they do not require any fuel or cords to operate – just sunlight! The best part about using a solar-powered weed whacker is that your yard will have that professionally manicured look without all of the noise and fumes of regular gas-powered models.
Humidifiers
If you want to convert your backyard into a solar-powered oasis, then you need to consider adding a humidifier to your setup. Humidifiers can help reduce the amount of dust in the air and also help prevent dry skin and other issues. More than that, they can also make your yard more comfortable by making it feel like springtime all year round.
While the question of whether or not to use a portable solar generator for your humidifier might seem like an easy one to answer, there are plenty of factors to consider—from how much power it needs and how comfortable you want your yard to be, to whether or not you want it to have batteries so it can run on its own. The correct answer will vary depending on your individual needs and preferences.
To help make this decision more accessible, there are two things you should look at first: how much power the humidifier will need to run correctly and whether or not you want it to have an inverter so that it can run the fan even when it is not connected to electricity from the grid. A good rule of thumb is that if it requires more than 1 kilowatt per hour, you will probably need an inverter to ensure it has enough wattage to run the fan properly. However, if you have access to batteries—which many models come with—you would not need one.
The gardening tools we have covered are all part of an all-encompassing solution to a significant gardening problem: mobility. Even with a larger structure and highly efficient solar panels, it can still be challenging to power your garden. However, if you have suitable portable generators and solar panels, you can take your cords and hoses to wherever they need to be moved. It will undoubtedly make your life easier, and needless to say, the flora in your garden or backyard will thrive because of it.
Contact Bluetti
Bluetti is the industry leader in solar technology. They put a lot of resources and research into designing high-quality products and are all set to satisfy your solar backyard needs. Bluetti's state-of-the-art portable solar panels and generators can be used to power all kinds of equipment, from lights and lawn mowers to humidifiers.
Whether you want to make your backyard into an urban farm or want some extra light while you putter around the house, the team at Bluetti will be happy to help you find the perfect portable solar system for your needs.
