NIPSCO Power Outage: How to Safeguard Home Power Continuity?
Power Outage
26/10/2023
Power outages are an unavoidable part of life. It's obvious that no one wants to face one, but you can take some precautionary steps to ensure you have a reliable power source. NIPSCO, the leading name in this sector, offers electricity and other services. However, you may face an NIPSCO power outage due to unforeseen circumstances.
Luckily, you can access their friendly website to know about all the outages and be prepared. So, keep reading to dig deeper into outages, battery backups, and other aspects.
Check the latest NIPSCO Power Outage Map
map
You can visit the website "www.nipsco.com/outages/power-outages" for all the information about planned or unplanned power outages in your area.
Follow these steps to find the NIPSCO power outage map:
  • Open and Scroll down the website mentioned above.
  • There will be a map. Now, navigate it to find the outages.
  • Also, you can enter the area in the Search Bar to find information about your area.
  • Moreover, this map is updated every 10 minutes so that the users can find the most up-to-date information.
  • Below the map, there is a Sign Up For Alerts option. You can sign up and receive the latest updates about all the planned and unplanned outages.
Impacts of the NIPSCO Power Outage
Here are some impacts NIPSCO power outage can cause:
The Inability of Temperature Control Devices to Work
Performing regular activity in very hot or cold temperatures is tough. But, it becomes more tough during the outages when heat regulating devices don't work. It may cause lots of issues which may disrupt your day-to-day life. For example, freezing temperatures can lead to pipe bursts, affecting water supply.
Food Loss
Generally, everyone stocks their food essentials in the refrigerator. During outages, the food only remains fresh for a short time. This may cause food wastage. So, if you are aware of the outage, you should turn the fridge to maximum cooling so that food remains fresh.
Water Issues
Water issues are uncommon, but some homeowners depend on water pumps. In this case, there can be a bit of a problem. It's advised to keep some bottles and store water in emergencies.
Emergency Issues
During outages, the failure of laptops, devices, and other equipment may be a hassle. You may have to delay events, virtual calls, etc. It's best to schedule everything once the power is back.
Electronic Damage
During the repair, the electronics at your home may experience a surge, which can cause damage to the devices. It's best to unplug all the devices to keep your appliances safe.
Along with household impacts, long power outages also affect the working, products, and services of businesses, education institutes, hospitals, data centers, and industrial bodies. Therefore, there's a need to be prepared with a battery backup. Please keep reading to know more about it.
Measures to Ensure Household Power Continuity
house
Here are some measures to ensure household power continuity:
Household Power Needs Assessment
The very first step is to assess the household power needs. For this, you can check all your appliances and their power needs. Then, consider their running time, family members, etc. This will help you know how much energy and power a day or month needs.
This calculation will help you get backup solutions that align with your needs. For example, heavy gear like washing machines, microwaves, ACs etc demand high power. You may not run them simultaneously during an outage, but they are important. So, assess your present and future power needs.
Installation of Solar Power System
Solar panels are becoming more and more noticeable on rooftops. The reasons are incentives, the use of clean energy, and convenience. Contact an authorized dealer who knows all the laws, incentives, and processes to initiate it.
 If you know your power and energy ends, you can use a compatible number of solar panels. The solar cells in the panels absorb sunlight during the day to create electricity. It has an inverter that converts stored DC to AC, usable electricity.
Maintenance and Testing of Solar Powered Generator
You must know that solar panels can generate electricity during sunlight hours. During the night or in bad weather, a solar power generator can help a lot. You can bring home a battery solution that can store extra energy produced by panels so that you can access power anytime.
Also, these battery solutions are compatible with the grid and off-grid for recharging itself. However, to be prepared for the outage, you should regularly maintain solar power generators. It's best to initiate periodic inspections. Also, test them for how long they can sustain your needs.
Other Recommendations for Safeguarding Household Power Continuity
Here are some other recommendations for safeguarding household power continuity:
  • Investing in a complete home battery solution is important. They are compatible with many sources, are flexible, expandable, and available in addition to home. For example, BLUETTI offers a great range of energy solutions for all home sizes, outdoor events, and more.
  • You can go with rechargeable lighting to provide lighting solutions for some time.
  • Try to get UPS, which is best for powering power banks, laptops, phones, etc, for a short duration.
  • Invest in energy-efficient appliances that use less energy.
  • It is better to have a stove, heating solutions etc which run on fuels.
  • Always keep emergency lighting solutions handy.
BLUETTI Home Battery Backup Prepare NIPSCO Power Outage
NIPSCO power outages can occur due to unavoidable circumstances. The tip is to stay in touch with the website and alerts. The technicians try their best to restore the power. Meanwhile, you can use a reliable backup source to continue our day-to-day tasks.
One such range of products that can help you have access to power 24*7 is BLUETTI. They feature energy solutions for homes, commercial spaces, solar solutions, portable stations, etc, which are expandable, flexible, and reliable.
Some of them are:
BLUETTI EP900 + B500
bluetti ep900b500
BLUETTI EP900 + B500 Home Battery Backup has a whooping 9,000W power output, which can power all 120V/240V devices. You can expand its storage capacity from 9,920Wh to 19,840Wh.
It features a modular design that can be installed inside and outside as it is IP65 water-resistant. With a premium LiFePO₄ battery, 10-year coverage, BLUETTI APP via WiFi or Bluetooth control, etc., make it an all-rounder.
It also sells extra electricity back to the grid, which makes it more budget-friendly. Moreover, it can be paired with AC units and new and existing solar energy solutions.
BLUETTI AC300 + B300
bluetti ac300b300
BLUETTI AC300+B300 Home Battery Backup is a kit and AC300 has 3,000W AC pure sine wave inverter with a 3,072Wh capacity (expandable). You can scale it with B300 up to 12,288Wh. Moreover, it can handle a surge of 6,000W.
You can charge it in seven ways (AC/Solar/Car/Generator/Lead-acid Battery/Dual AC/AC+Solar). Plus, it has 16 different types of output ports for charging devices. The LiFePO4 battery with 3,500+ life cycles to 80%, a four-year warranty, and App control makes it the best in class. Also, it has a dual charging mode to enhance the recharging. All these flexible options and user experience make it a great addition to home energy needs.
BLUETTI AC200MAX + PV200
bluetti ac200max
BLUETTI AC200MAX+PV200 Solar Generator Kit  is a 2,200W AC pure sine wave inverter with a 4,800W surge. AC200MAX has a capacity of 2,048Wh, which can be expanded with 2×B230 to 6,144Wh or 2×B300 to 8,192Wh.
You can charge it in seven ways (AC/Solar/Car/Generator/Lead Battery/Dual AC/AC+Solar).
It has 16 different types of output ports for charging devices. Moreover, dual charging of Solar and AC can give an output of 1400W. Using a LiFePO4 battery with 3,500+ life cycles to 80%, smart monitoring control, and a great four-year warranty makes it another amazing solution.
Tips for Surviving in NIPSCO Power Outage
Here are a few tips to stay safe in the NIPSCO power outage:
  • If you receive any bad weather alert, you should fill your cars, bring food, stock up on essentials, and stay safe.
  • Check the website for planned outages.
  • Create an emergency kit with batteries, flashlights, and other lighting solutions.
  • Power all your rechargeable devices.
  • Turn your refrigerator's power to maximum so the food stays fresh for a long time.
  • It would be best if you charged your power stations full.
  • Only perform the most important electricity-related task during the outage from an external power source.
  • You can take out fuel-based stoves, grills, heating solutions, etc.
  • Unplug all your devices from the sockets.
  • Place an emergency medical kit handy.
  • Don't visit the basement area if it's flooded.
  • It would be best to keep some cash handy in an emergency.
  • Stay in touch with the alerts and the official website for all the updates.
NIPSCO power outages can occur due to inevitable circumstances. To lessen the effects, you can bring home a backup supply. These valuable additions work on and off the grid and store ample energy during outages. Moreover, they are environmentally friendly, smart, flexible, expandable, and beneficial.
