Shop our productsDo you use an air fryer? Dependable little things they are - making you sumptuous delights without putting strain on you. However, that is not all that there is to them, is there?
While they offer remarkable cooking services, it is at the expense of electricity bills. Thus arises the question: exactly how many watts does an air fryer use?
Read on as we understand air fryer wattage, the factors affecting air fryer power consumption, and calculate the power usage of air fryers. Lastly, we will explore amazing solutions for your electricity bills and offer tips for efficient air fryer usage.
Don’t miss out on reading such an informative piece!
Understanding Air Fryer Wattage
When discussing the power consumption of an air fryer, there are some terminologies you will always encounter; you cannot divorce yourself from it. Therefore, before proceeding, let us first have an understanding of these terms.
Watts (W):
Watts is essentially a unit of power. When we say how many watts does an air fryer use, it is denoting how much electricity your appliance is consuming per second.
For example, suppose your air fryer is 1,500W. It means that it uses 1500W of power at its peak performance. You can find the wattage of appliances listed on their product label or manual.
Watt Hours (Wh):
Watt-hours are another unit of power. It denotes the amount of electricity/power your air fryer actually uses while running. It is measured by multiplying the wattage and the time an appliance is running in hours.
Appliance | Power Consumption (Watts) | Daily Usage (Minutes) | Daily Cost (Pence) | Monthly Cost ($) |
Air Fryer | 1500 | 30 | 15 | 45 |
Oven | 3000 | 60 | 30 | 90 |
Microwave | 1200 | 15 | 6 | 18 |
Toaster | 800 | 10 | 3.5 | 10.5 |
Coffee Maker | 900 | 20 | 7.5 | 22.5 |
Slow Cooker | 250 | 240 | 30 | 90 |
Instant Pot | 1000 | 40 | 13.5 | 40.5 |
Electric Kettle | 1500 | 10 | 5.5 | 16.5 |
Blender | 600 | 10 | 3.0 | 9.0 |
Rice Cooker | 500 | 30 | 5.0 | 15.0 |
Electric Griddle | 1500 | 30 | 15.0 | 45.0 |
Food Processor | 700 | 15 | 3.5 | 10.5 |
Waffle Maker | 1200 | 10 | 6.0 | 18.0 |
Electric Grill | 1800 | 30 | 20.0 | 60.0 |
Deep Fryer | 2000 | 20 | 15.0 | 45.0 |
Steamer | 900 | 20 | 7.5 | 22.5 |
Dishwasher | 1200 | 90 | 18.0 | 54.0 |
Air Conditioner | 2000 | 180 | 40.0 | 120.0 |
Dehumidifier | 500 | 240 | 30.0 | 90.0 |
Electric Oven | 2500 | 60 | 25.0 | 75.0 |
Factors Affecting Air Fryer Power Consumption
Having understood that watts represent the power consumption of an appliance, we will now look at several factors that affect an air fryer’s power consumption.
1. Size of the Air Fryer
There are three sizes of air fryers available on the market: small, medium, and large. Which size do you own? Due to their differing sizes, small air fryers hold lesser quantities of food than larger air fryers.
For instance, medium-sized air fryers can hold 3 to 5 quarts of food, while larger ones can hold 6 to 8 quarts of food.
Secondly, it is a universal law that bigger appliances require more power. Similarly, if the size of your air fryer is small, it will not guzzle as much power as its larger counterpart.
Size of Air Fryer |
Wattage |
Small Air Fryers |
800W to 1,200W |
Medium Air Fryers |
1,200W to 1,500W |
Larger Air Fryers |
1,500W and 2,000W |
2. Cooking Temperature and Duration
Size is not the only factor that counts. How much watts does an air fryer use relies on other factors as well, for instance, the cooking temperature and duration of cooking.
How do you normally cook food in an air fryer? Do you use higher temperatures or lower? Do you prefer cooking for a longer or shorter duration?
While you might think that these questions are not important, they nevertheless play a significant role in determining exactly how many watts does an air fryer use. This, in turn, affects your electricity bills. After all, a higher cooking temperature and longer duration take up more power.
3. Cooking Method and Frequency of Use
Next, we have your cooking method and how frequently you use your air fryer. As for the frequency of use, it is rather obvious that if you use it frequently, like every day or more than once each day, it will add to your electricity bills.
Second is the cooking method. There are several features available on an air fryer, such as frying, baking, or grilling. Which method you use for cooking also impacts how many watts does an air fryer use.
How Many Watts Does an Air Fryer Use?
Getting to the main question, we will now learn to calculate how many watts does an air fryer use, and how it equates to the monthly electricity bill. There are four essential but easy steps in the process.
1. Energy Consumption (Wh) = Power Rating (W) * Time Used (hours)
First, we will calculate the energy consumption by multiplying the power rating in watts by the time used in hours.
For example:
Let power rating (W) = 1500W
Let time used (hours) = 1/3 hours
= 1,500 * 1/3
= 500Wh
Therefore, the energy consumed by a 1,500W air fryer running for 1/3 hours at a given time is 500Wh.
2. Convert Energy Consumption in Wh to kWh
Next, we will convert the energy from watt-hours (Wh) to kilo-watt-hours (kWh) because this is the unit you need to calculate your monthly electricity bill.
For example:
Let energy consumption = 500 Wh
kWh = Wh / 1,000
= 500 / 1000
= 0.5 kWh
3. Electricity Cost ($) = Energy Consumption (kWh) * Electricity Rate ($/kWh)
To find the financial impact, you will multiply the energy consumption found by the electricity rate in your area.
For example:
Let energy consumption = 0.5 kWh
Let the electricity rate = $0.168 per kWh
= 0.5 * 0.168
= $0.084
This is the electricity cost of using the air fryer once.
4. Monthly Electricity Bill
To calculate the monthly electricity bill, multiply it by 30.
For example:
Let electricity cost = $0.084
Monthly electricity bill = electricity cost * 30
= 0.084 * 30
= $2.52
Therefore, the contribution of a 1,500W air fryer to your electricity bill is $2.52 if you use it every day for 1/3 of an hour.
Power Your Air Fryer Through Solar
No matter how much an air fryer contributes to your electricity bills, you need an alternative power source that will somehow reduce your electricity bills. For it, what better solution than solar power?
Let’s look at some amazing BLUETTI solar power solutions.
The BLUETTI EP500 Solar Power Station is a remarkable solar power station you won’t regret buying.
Key Features:
High Capacity: Boasting a 5,120Wh LiFePO4 battery, it offers you enough stored energy to charge your air fryer and other home appliances effectively at the same time.
Long Cycle Life: You are guaranteed its durability and longevity with its over 3500 cycles to 80% capacity.
Pure Sine Wave Output: Its 2,000W Pure Sine Wave Output will provide you with stable and clean power for your air fryer and other appliances.
In-grid and Off-grid Modes: Featuring both in-grid UPS mode and flexible UPS mode, you will have a continuous power supply, whether on-grid or off-grid.
2. BLUETTI PV420 Solar Panel
You will love the BLUETTI PV420 Solar Panel for its versatile features and portability. It will charge your air fryer for you without any issues, all the while providing clean energy harnessed from solar power.
Key Features:
High Efficiency: Boasting a conversion rate of up to 23.4%, this solar panel is very efficient in converting sunlight into solar power, providing you with a lot of power to power your air fryer and other electrical appliances as well.
Durability: It is both durable and splash-proof, therefore, you can place it outside without worrying about it getting damaged.
Power Output: Providing you with 420W solar power, you are guaranteed fast charging for your air fryer and other electrical appliances.
Compatibility: It is compatible with BLUETTI AC200P, AC200MAX, AC300, AC500, EB150, EB240, EP500, and EP500Pro. Therefore, if you already have these products, you can use PV420 with them without any issues.
3. AC200MAX Expandable Power Station
The BLUETTI AC200MAX Expandable Power Station is another impressive product with tempting features you do not want to forgo.
Key Features:
High Power Output: It has a 2,200W AC Pure Sine Wave Inverter, along with a 4,800W surge power, allowing you to easily charge an air fryer, and even those appliances requiring high starting watts.
Large Capacity: It features a 2,048Wh LiFePO4 battery, providing you with ample energy storage even for extended use.
Expandable: It is expandable up to 6,144Wh with two B230 or 8,192Wh with two B300.
Multiple Recharging Options: There are seven ways to recharge it - namely AC, solar, car, generator, lead battery, dual AC, and AC + solar. Convenient, right?
Find out the best portable power station to buy.
Tips for Efficient Air Fryer Usage
Finally, we will look at some tips and tricks to further help you boil down how many watts does an air fryer use.
1. Adjust Cooking Settings
As discussed above, high temperature and longer duration equal high power consumption and thus higher electricity bills. Therefore, you need to adjust your cooking settings and time so that you avoid it.
2. Preheat Efficiently
Preheating your air fryer is one effective method of avoiding longer cooking duration. So, opt for that. However, at the same time, you must also ensure not to preheat for a very long time as that, too, consumes greater power.
3. Maximize Cooking Batches
Another thing you can do is cook multiple cooking items simultaneously. This will reduce your cooking duration, and you will be free from cooking early. Killing two birds with one stone.
Final Words
In conclusion, we have now understood that watts represent how much total power your air fryer draws per second, while watt-hours denote their energy consumption according to how long they run.
Several factors affect your air fryer power consumption, including the size of the air fryer, temperature setting and cooking duration, and your cooking method and frequency of use.
You can calculate the power consumption of your air fryer by multiplying the power rating by the time used. Divide it by 1,000 to convert the units. Then, multiply energy consumption by electricity cost in your area to get the financial impact. Multiply by 30 to get the monthly bill.
You can opt for solar power to reduce your electricity bills. When doing so, the BLUETTI EP500 Solar Power Station, the BLUETTI PV420 Solar Panel, and the AC200MAX Expandable Power Station are great options to consider.
Lastly, some tips for energy-efficient air fryer usage include adjusting cooking settings, preheating efficiently, and maximizing cooking batches.
