Shop our productsSolar batteries store excess electricity, allowing you to use it during power outages and at night. Most are portable and lightweight, meaning you can transport them with ease. Premium units come with several charging methods and output ports for multiple devices. So what are BLUETTI batteries? Let’s find out.
What are BLUETTI Batteries?
BLUETTI batteries are lithium iron phosphate (LiFePO4) batteries offering much-needed power backup solutions. Whether you want to use them for backup or off-grid living, they got you sorted. They come in different sizes ranging from compact and portable units to robust and movable options.
BLUETTI batteries are a viable investment for your solar system, offering power for days and even weeks when combined with BLUETTI solar panels. What’s more? Our larger units allow you to qualify for the 30% federal tax credit. But that’s not all, you can connect the batteries to an existing solar system, meaning you don’t need expensive rewiring.
Many solar systems will provide ample power during peak sun hours and then provide none during the night. But that’s not the case with BLUETTI batteries. With them, you can store excess power generated during the peak sun hours. It means you can use it at night or during a power blackout.
Furthermore, the batteries allow you to benefit from net metering since you can sell excess electricity to your utility company. BLUETTI has batteries for all needs. If you want to go camping, the ultra-portable and lightweight batteries got you sorted. Looking for a whole house battery? The robust larger batteries are your best bet.
And you are not limited to charging BLUETTI batteries using solar panels. They provide over five charging methods including AC outlets, lead acid batteries, and generators. With BLUETTI batteries, you can rest assured your devices will keep running during prolonged power outages.
What are BLUETTI Batteries Made of?
BLUETTI batteries are made of lithium iron phosphate (LiFePO4). Also referred to as LFP, they are a newer subset of lithium-ion batteries. Lithium-ion batteries power most modern devices. From smartphones, laptops, to EVs, they provide high energy density in a compact design. And this is one chief reason why BLUETTI uses LFP in their batteries.
Besides, they have a longer lifespan, they are safer, more efficient and lightweight than conventional batteries. They are also an ideal option for power stations since they have maintenance-free design. With no moving parts, they require no lubrication or replacing components. And unlike conventional lithium-ion batteries, they don’t have nickel or cobalt, meaning they are environmentally friendly.
With high discharge rates, high efficiency, longer lifespan, and fast charging, LiFePO4 is the perfect option for robust and practical batteries.
How Can You Use BLUETTI Batteries?
So, what can you use BLUETTI batteries for? Let’s find out.
Backup Power
The obvious reason for using BLUETTI batteries is for backup power needs. For example, the BLUETTI EP500Pro Solar Power Station | 3,000W 5,120Wh provides ample energy to power most of your appliances. The power station has a 5120Wh capacity, meaning it can power small and large appliances simultaneously.
And you don’t have to rely on solar panels to charge it. You can use other options such as AC outlets and generators. This means you can keep it fully charged for extended periods. Like other BLUETTI power stations, it has a LiFePO4 battery. As mentioned, you’ll enjoy high energy density, efficiency, and fast charging.
If you are looking for backup power at home or for outdoor activities, this is the perfect choice for you.
Source of Power When Camping
While camping entails disconnecting from your everyday life, your devices need to be functional for communication, cooking, and other purposes. This is where BLUETTI power stations come into play.
You don’t need to visit a local store or restaurant to recharge your devices. Just get yourself a portable power station and you are good to go. BLUETTI batteries can also power camping gear such as electric stoves and coffee makers.
Source of Clean and Renewable Energy
Let’s face it, global warming is wreaking havoc globally. From receding glaciers to rising sea levels, the use of fossil fuels has led to severe climate changes. One way to mitigate this is to use renewable power sources such as solar power stations.
Along with solar panels, BLUETTI batteries allow you to use energy from the sun, which does not emit greenhouse gasses, reducing your carbon footprint. The best part is that the sun's energy will never get depleted.
An Alternative to Conventional Generators
Gasoline generators are not only noisy but also pollute the environment. They produce greenhouse gasses that lead to global warming. And not all residential areas encourage installation of gasoline generators. Installing them can be a daunting task since you’ll need a permit from local authority and a space away from your house. This can be time consuming and expensive.
With BLUETTI batteries, you don’t need extensive paperwork. In fact, most residential areas encourage residents to use solar batteries. They are also quiet during operation,meaning you can install them in your house. But that’s not all, they don’t require a different installation space. You can install them in your basement, garage, or tight spaces and you are sorted.
For Energy Independence
It’s every homeowner's dream to reduce their electricity bills. With utility companies increasing rates year on year, reducing your dependency on the power grid remains the most viable option. And using solar batteries is the most practical approach.
Coupled with robust solar panels, solar batteries can help you achieve energy independence. They allow you to store electricity, which you can use at night when the electricity rates are at their highest. Moreover, you can sell any excess electricity to your power grid. This not only saves you money but also earns you extra cash.
What Sets BLUETTI Batteries Apart From its Competitors?
Why should you choose BLUETTI batteries? Here are concrete reasons.
LiFePO4 Chemistry
As mentioned, BLUETTI batteries utilize LiFePO4 chemistry, providing much needed reliability and performance. LFP has many benefits including:
- Longer Lifespan: LFP batteries have a longer lifespan than conventional lithium-ion batteries. For example, BLUETTI batteries have over 3500 cycles, meaning you can use them for over a decade.
- Maintenance -free: LiFePO4 batteries do not require active maintenance to improve their performance. Furthermore, they have no memory effects allowing you to store them for extended periods. This is unlike lead acid batteries that need special maintenance.
- Compact and Lightweight: Thanks to their high power density, BLUETTI batteries come in compact and portable designs. This allows you to handle and transport them with ease.
- High efficiency: LiFePO4 batteries have fast charging capabilities reducing downtimes. They also have a high discharge rate, providing bursts of power in a short amount of time.
Modular Design
Another reason to buy BLUETTI batteries is their modular design. This allows you to expand their capacity to meet your energy needs. For example, the BLUETTI AC500 + B300/B300S | Home Battery Backup, which has a 3072Wh capacity, can be expanded to 18432Wh. All you need are six B300S expansion batteries.
With this capacity, you can rest assured of an uninterrupted power supply for up to six days. And since it is equipped with a 5000W pure sine wave inverter, it can work with all appliances - small and large. So, if you want to increase or reduce the power supply in your house, consider buying this model.
Smart Control
Unlike its competitors, BLUETTI power stations come equipped with smart app control. You can monitor or control the power station via Bluetooth or WiFi. Whether you want to adjust settings or monitor the charging rate, you can do so from the comfort of your bed or sofa.
Multiple Charging Options
You don’t have to worry about downtimes with BLUETTI batteries. They offer multiple charging methods. You can use solar panels, AC, or lead acid batteries. This ensures the batteries are fully charged whether there’s a power outage or not.
The BLUETTI AC300 + B300 | Home Battery Backup provides up to seven options: AC, lead acid battery, solar, generator, car, dual AC, and AC with solar. As you can see, you are not limited to one method. But that’s not all, you can use AC and solar simultaneously, offering faster charging.
What devices can BLUETTI batteries power?
They can power most household appliances depending on their capacity. That said, they can power small devices like smartphones and laptops and larger units such as refrigerators and AC systems.
How long does a BLUETTI battery last?
A typical battery has a cycle of over 3500, meaning you can use it for up to 10 years.
As you can see, BLUETTI batteries afford you much-needed power backup for your home use. Besides, you can use them for outdoor activities like camping. When buying one for your home use, consider your power needs and choose one with a modular design.
