Shop our productsThe team at Bluetti are constantly on the forefront of technological innovation, Bluetti EB70S portable power station is testament to that.
Our newest portable power station, the Bluetti EB70 is a small, compact powerhouse weighing a feather-light 21 pounds whilst still being able to produce a hefty 716Wh of uninterrupted power.
The elegant Bluetti EB70 with its convenient foldable handle design is among the most compact powerstations to break into the 700W range market.
The sturdy casing houses ultra-durable LiFePO4 battery cells which are capable of 2500+ charge cycles.
Additionally, the EB70 can be fast charged with Bluetti PV200 solar panel in only 3 hours.
In summary, if you happen to be living the #vanlife, then Bluetti EB70 will suit every single one of your explorist needs.
1. Bluetti EB70 Portable Power Station Specifications
Bluetti EB70 has been built to last with the legendary LiFePO4 technology, battery cells with the capability of being discharged more than 2500 times.
The specific lithium-ion battery found in the EB70 has 716Wh of capacity, enough power to meet the everyday needs of camper or traveler on the go.
Built into the design are four continuous AC outlets capable of running 700 watts all at once with a surge protection of up to 1400 watts.
Additionally, there are two 100-watt USB-C PD 3.0 ports. These are the ports you could use to electronic devices such as your laptop or smart phone.
Finally, we have decided to include a wireless charging pad once again, you will find this smart pad molded right into the top of your Bluetti solar generator. The smart pad is capable of charging many modern wireless electronic devices – effortlessly.
2. Bluetti EB70 Premium LiFePO4 Battery Chemistry
The EB70 houses one of the safest battery technologies on the market today. The LiFePO4, lithium iron phosphate.
The LiFePO4 battery chemistry has ensured safety, essentially double that of the more traditional NCA and NCM batteries. In fact, you could even puncture the battery without it catching fire.
The cathode material in LiFePO4 batteries is not toxic, which means they do not pose any negative health hazards or environmental concerns.
Additionally, LiFePO4 batteries weigh less than half of a lead-acid battery of similar capacity, so no more lugging your Bluetti solar generator around. The EB70 is super light and portable.
3. Bluetti EB70 Recharge Options
The Bluetti EB70 power station is able to support three ways of recharge:
- 200W Via wall outlet, recharge time is 2.9 hours from 0 - 80%.
- By a vehicle, doing so also takes 2.9 hours for recharge.
- By Bluetti’s 200 Watt solar panels, recharge time takes about 4.5 hours.
4. Bluetti EB70 Use Options
The portable solar generators from Bluetti not only charge your electronic devices via clean energy, but they do also so in a quiet manner.
They are not like heavy, bulky, and noisy gas-fired generators, in fact quite the opposite. They are able to power your needs quietly, steady, and safely without any unbearable noise or toxic fumes
This makes Bluetti portable power station EB70 especially sought after for fishing trips, camping adventures, workshops, picnics and yachts, not to mention campervan road trips.
5. Bluetti EB70 Price
The Bluetti EB70 is packed with 716Wh capacity and a 700W pure sine inverter.
In terms of price, the EB70 is extremely competitive at $549. Especially when you consider that the Jackery 518Wh/500W and the Ecoflow 576Wh/600W cost the same amount for much less performance.
6. Conclusion
Please feel free to contact us via email if you seek more information on the Bluetti EB70 portable solar generator: service@bluetti.com
7. FAQ
1. Why choose BLUETTI EB70?
🔋716Wh Battery Pack (LiFePO4 w/ up to 2500 charge cycles)
⚡Pure Sine Wave AC Outlets x4, 700W
⚡2*100W USB-C PD Outlets (200W in total)
⚡Max 200W Solar/AC/Car Input
⚡0-80% within 3 Hours
⚡ 100% Regulated 12V DC Outputs
2. What devices can the BLUETTI EB70 charge or power?
Please double-check the rated power of your electronics first. The maximum rated output power of the EB70 is 700W, which means the inverter will shut off if the overall power of your devices exceeds 700W.
3. How long will EB70 keep my device powered up?
Working time (estimate) = (716Wh*0.85) / device's operating power Please keep in mind that actual working time may vary depending on the situation.
