Shop our productsAmong multiple variables of solar generators, the popularity of 2000-watt solar generators is growing. Whether your needs are for home power backup or off-grid energy solutions, 2000-watt solar generators have something for everyone.
However, due to the availability of other large generator models, there is a meager understanding of what 2000-watt solar generators are, what they can run, their household uses, and what the best models available in the market to choose from.
To help you navigate through all this, here is a comprehensive guide to 2000-watt solar generators.
Fully Understanding 2000 Watt Solar Generator
Solar generators are devices that capture sunlight and convert it into electrical energy. Their multiple types are available depending on their power and functionality.
Talking specifically about 2000-watt solar generators, these are units that can power devices of up to 2000 Watts. However, for a more precise understanding, let's deconstruct its different parts.
- Solar panels: Each 2000-watt solar generator comes with a specific number of solar panels to capture the sunlight. These numbers vary depending on the required amount of energy.
- Inverter: Next to solar panels are inverters. They convert DC current supplied by solar panels into AC current, which is stored in batteries or consumed directly by appliances.
- Batteries: Batteries are the power storage house of 2000-watt solar generators. As evident from their name, for 2000-watt solar generators, the minimum battery capacity is 2000Wh, which usually can be expanded up to 6000Wh and 8000Wh.
- Charge controllers: They are important yet optional parts of 2000-watt solar generators. They control the amount of current supplied and stored in batteries, eventually dealing with issues of overcharging and discharging.
The parts mentioned above make these solar generators reliable, efficient, and compatible for various operations. However, the battery and charge controller are optional, as they can be removed for easy portability and direct use.
What Can a 2000-Watt Solar Generator Run?
The running of electrical appliances through a 2000-watt solar generator depends on their power requirements. Appliances need two types of power. One, to start, is usually high and known as surge power. The second is the running power or actual power of the appliance. For example, portable refrigerators consume around 80-100 watts for running, but their surge power could be around 400- 500 watts.
With the above-said, a 2000-watt solar generator can run all the appliances that have their running and surge power below 2000W.
Here is a list of various home appliances that you can run with a 2000-watt solar generator.
Home units
2000-watt solar generators can support the power needs of all the necessary home appliances. This includes lights, small ACs, TVs, microwaves, and other such devices.
Furthermore, it can also run big ACs and heating units, but it's recommended to know about the power needs first.
Kitchen Gadgets
The power requirements for kitchen appliances usually lie below 2000W. So, a 2000-watt solar generator could be your reliable partner in running nearly every kitchen appliance, including coffee makers, portable ovens, toasters, dishwashers, stoves, blenders, etc.
Electronics
Whether it's your laptop, smartwatch, mobile phone, PSP, tablet, or camera, a 2000-watt solar generator could effectively recharge all your tech gadgets.
However, for running multiple devices simultaneously, it's better to add the power consumption needs of all connected devices and then check if your generator can cater to this or not.
Outdoor units
2000-watt solar generators are best for off-grid camping and other recreational activities. They are compact, easily portable, and can run a number of outdoor equipment, including electric grills, speakers, portable ACs, small refrigerators, lightning systems, radios, etc.
Repair Tools
Most repair tools, like circular jaws, drills, sanders, jigsaws, etc., have power consumption ratings below 2000 watts, so these solar generators are reliable to power such devices.
It's important to note that run time and how many devices can be powered simultaneously depends on multiple factors, including the battery capacities, production of electricity at any specific time through solar panels, and power consumption of these gadgets.
To further understand if a 2000-watt solar generator is enough for your household needs, let's move to the next section.
Is a 2000 Watt Solar Generator Enough for Your Household Needs?
You see, the utmost goal of any solar installation is to maximize savings by cutting the costs of energy bills. We have discussed above that a 2000-watt solar generator can efficiently run various devices. But is this unit enough for all your household power needs?
This fundamental question comes with intricate patterns and needs investigation of multiple parameters to address this query. In the first place, calculate the energy production capacity of your solar unit. You can simply do this by multiplying the efficiency rating of your solar panels. For example, if you have 10 solar panels, each with a power generating capacity of 200W, your per-hour production will be 2000W.
Secondly, calculate the energy consumption patterns of your household at a specific time. This means how many devices, like fans, lights, and other appliances, run at a specific time and how much watts they require.
For this, add the watt power of the appliance mentioned on their labels. If it is given in volts and amps instead of watts, you can use the equation below to convert volts and amps to watts.
Volts X Amps = Watts
Now, you can compare your energy production with your usage to know if a 2000-watt solar generator is enough for your household needs or not.
It must be noted here that solar panels generate power only during peak hours, which are 4-6 hours, depending on your geographical location. If you want to completely rely on a 2000-watt solar generator, then the solar panel's power production should double your energy needs. In this case, the extra energy will be stored in batteries for use when sunlight is not available.
What if your needs are more than 2000 watts?
Well, for this, efficient strategic energy management is your way to go. This means You can distribute the appliance use throughout the day according to the generator’s output capacity. Additionally, shifting to appliances that use less energy could further boost the suitability of a 2000-watt solar generator with your household.
Best 2000-Watt Solar Generator We Recommend
Solar generators are a wise investment that can effectively help you cut your energy bills with a minimized carbon footprint on the environment. However, the upfront costs are high and require prudent decision-making.
We have studied multiple products and selected these 3 best variables of 2000-watt solar generators for you. Review them to choose what aligns best with your requirements.
BLUETTI AC200P + 3*PV200
This 2000W unit is a pure AC sine wave inverter with a surge power of 4800W to support nearly all your appliances. With a 2000Wh output capacity and 17 output ports, it can easily run multiple devices simultaneously.
But this is not all. Its LiFePO4 battery offers 3500+ charge cycles. It means this comes with a shelf life of around 10 years, with each charge cycle every day. Furthermore, it can be charged through 7 current streams. Its eco-friendliness and quite free operations indeed make it your perfect partner anytime, anywhere.
BLUETTI AC200L+3*PV200
In this fast-paced world, speed is everything, and so is the charging speed of BLUETTI AC200L.
This portable power station has an output power of 2400W with a powerlifting mode of up to 3600W, and the system can be charged from 0-80% only within 45 min.
In case you need more power storage capacity, the unit battery capacity is expandable to 8192Wh and can be charged with 6 different charging streams, including AC, solar, car, generators, lead battery, and AC+solar.
The system operations are quiet and highly efficient. Its control management through the BLUETTI smart app, Bluetooth, and Wifi makes this unit a true masterpiece.
BLUETTI AC200MAX + 3*PV200
With a 2200W pure sine wave inverter, 4800W surge power, and 2048Wh output capacity expandable up to 8192Wh, AC200MAX has the solution to all your needs. The system is also integrated with LiFePO4 battery with 3500+ lifecycles.
The unit is 7-way charged with a max solar input of 900W and fast charging input of 1400W with AC+solar. Again, like other exceptional products of BLUETTI, this can also be controlled by the app, making its use more smart and convenient.
Lastly, what attracts me the most about this product is its price match guarantee. This means that if you find any competitor product less than this within 30 days of purchase, you can claim the extra amount.
The Reasons We Recommend the BLUETTI Solar Generator
With each passing day, the landscape of portable energy solutions is evolving. In a market brimming up with brands and products and everyone claiming to be the best, it's overwhelming actually to choose the best.
In such a scenario, BLUETTI is the name of compatibility, efficiency, and convenience with thousands of satisfied customers around the globe. Here are the salient features that set BLUETTI apart from its competitors.
- Price match guarantee: Price is the most fundamental concern for every consumer. Most BLUETTI products come with a price match guarantee to verify that none of the other brands is offering such value at a lower price than BLUETTI.
- Quality: The quality of BLUETTI products is the basic feature that makes them stand out from the competitors. All products are manufactured from premium quality materials and come with a 5-year hassle-free warranty.
- Convenience of use: Easy-to-use products are desired by every customer. BLUETTI solar generators are integrated with top-notch technological advancement and can be operated through smart apps, making their use convenient.
- Compatibility: In the realm of electronics, each product is specific and needs to be operated according to guidelines laid out by the manufacturer. BLUETTI solar units offer a range of output ports and converters that support the needs of every gadget without compromising their overall efficiency.
- Compact size: While manufacturing solar units, BLUETTI ensures that they have a compact and sleek design. This not only makes them easily portable but also adds to the beauty of your home.
- Environment-friendly products: All BLUETTI products are integrated with LiFePO4 battery type to set the seal on clean energy and zero carbon footprints.
Related articles: What Size Generator to Run a 2000 Sq Ft House?
What Can I Run with a 2,000 Watt Generator?
2000-Watt Portable Indoor Generator for Home Emergency
Can You Run a 2000 Watt Solar Generator 24/7?
Solar generators produce their energy by converting solar radiation. This means their energy production is directly proportional to the availability of sun. It is evident that the sun is not available for 24 hours, so can you run a 2000-watt solar generator 24/7?
The one-word answer could be yes, but it requires large battery backups and prudent energy management. You see, during the peak hours of the sun, it produces sufficient power that could be stored in batteries for further use during the night or when enough solar radiation is not available.
Most solar generators have a single built-in battery of 2000Wh capacity. However, some models like BLUETTI AC200MAX and BLUETTI AC200L allow the addition of external batteries to increase the energy storage capacity. Depending on your energy consumption patterns, you can install extra batteries to run your home 24/7 with a 2000-watt solar generator.
Final Thoughts:
The 2000-watt solar generator could be your reliable companion whether you need power in a blackout or want to shift entirely to solar energy to cut your energy bills.
However, fulfilling all your energy needs 24/7 through these units is challenging as whole-house energy consumption could be more. Still, with prudent energy management and the addition of extra batteries, this is an achievable goal. Just make sure that you are opting for a reliable and efficient unit, like the products offered by BLUETTI.
