Shop our productsSolar power stations are considered as a very significant green energy source. There has been an explosion of new solar technology that will allow you to take your power with you, no matter where you go.
Solar-powered generator stations are the best way to ensure that there is always electricity available when needed most. Whether you're in the middle of nowhere or at home, these generators can provide power to meet all your needs without relying on fossil fuels or other sources of energy. So let's look at some of the advantages of using portable solar power stations.
13 Pros of Solar Power Stations
1. Lightweight and Portable
One of the biggest problems of other types of solar power generators is that they are too large and bulky to carry around. This makes them difficult to transport and use at any location where you need power, rather than your home or business. The beauty of portable generator stations is their compact size – they can easily be carried along for camping trips, road trips, or even to events where power is needed.
2. Versatile
Solar-powered generators can be used for a variety of purposes. Whether you need to charge your phone, laptop, or run appliances in an emergency, these generators have you covered. Some even come with built-in fans and lights to make them more versatile and useful in a wider range of situations.
3. Affordable
Portable solar power stations are not only much efficient and versatile than other solar generators, but also much more affordable. You can find quality portable generators for as little as $200 – which is a fraction of the cost of other solar power generators on the market today.
4. Cost-Efficient
What’ more, they're also much more cost-efficient in the long run. Unlike generators, solar generators don't require any additional costs or maintenance. In addition, the solar generator will provide free electricity as long as you own it.
5. Green Energy
One of the biggest problems with traditional power sources is that they are not environmentally friendly. However, solar generators do not require any harmful chemicals or fossil fuels to function, which means you won’t negatively impacting the environment when you use your generator.
6. Safe to Use
Solar generators are some of the safest generators on the market. Unlike conventional generators, solar-powered generators do not produce any harmful fumes or sparks. These make them perfect for various situations, including indoors and around children and pets.
7. Free Energy
The main benefit of using a portable solar power station is that you'll never have to pay for electricity again. Once the generator has been paid off, it's free energy from then on! This makes them play an active role in emergencies when there might be an extended loss of power.
8. Low Maintenance
Solar generators require very little maintenance – making them one of the most low-maintenance power sources on the market today. There is nothing to maintain over time besides keeping your equipment clean! This means you’ll never have to worry about costly repairs or replacement parts.
9. Low Noise
Solar power stations make very little noise as they operate. Some models are completely silent – making them ideal for both indoors and outdoors. Having a quiet solar generator standby is necessary during emergencies if you want to keep peace in mind without being drawn attention from other noise around you.
10. Self-Sustainable
Solar generators are completely self-sustainable compared to other generators that rely on fuel or batteries. Once they have been charged up, they will continue to provide power as long as the sun is shining. Perfect for a variety of scenarios especially when you need continuous power without having to worry about running out of power.
11. Various Options Available
Solar generators come in various shapes and sizes, so you can easily find the suitable one to fit your specific needs. Whether you need a small generator for charging your phone on camping trips or a large one for powering appliances during an emergency, there is sure to be a solar-powered generator that's right for you.
12. Reliable Backup Energy Source
In addition to all of the other benefits listed above, solar generators also make great backup energy sources. If you experience a power outage or need power in an area where there is no traditional grid access, a solar generator will be able to provide the electricity you need.
13. Dependable, Affordable, and Innovative Energy Source
There are many reasons to choose a portable solar power station as your go-to energy source. They're affordable, dependable, and environmentally friendly. With so many options available on the market today, it's easy to find the ideal solar generator for your needs!
What are the best solar generators available?
There are many options in the market when it comes to solar generators. All you have to do is narrow down your choices and compare the different features of the generators and then choose the one to satisfy your needs.
BLUETTI EB55 537WH/700W PORTABLE POWER STATION
This product is perfect for people who’re looking for a small source of power and those who don't want to spend large sum of money on the solar power station. This model is particularly great for outdoor use and can provide power to most small residential appliances. In addition, the battery is very efficient, allowing it to store more energy than models with comparable batteries.
Features:
- 400W input, less than 2 hours to get fully recharged
- Power 13 devices simultaneously
- 1 piece of 15W wireless charging pad
- 5Lbs, easy to carry
This is another cost-effective option when it comes to solar power stations. You might think that it is an expensive product; however, if you consider the long-term costs, you will realize that getting this solar power station will reduce your energy bills, and low maintenance is needed, so you will save a lot of money in the long run.
Running time (AC200MAX):
- LED Light Bulb(20W): 75~85hrs
- TV(25W): 20~22HRS
- Fridge(80W): 19~20hrs
- Slow cooker(200W): 8~9hrs
2048Wh × DOD × η ÷ (load W) = charging time(unit: h)
Note: DOD refers to the battery discharge depth,η refers to the local inverter efficiency, DOD=90%, η =90%
BLUETTI EP500 5100Wh/2000W Power Station
This is one of the most unique and innovative solar power stations on our list with a large solar power capacity. This model also has a built-in LCD screen that makes it easy to monitor the status of your solar power station.
The most killing part is 24/7 UPS. That means when the power grid fails, EP500 will automatically become your basic load home energy source.
These are just some of the many different portable solar power stations available on the market today. When shopping for this type of product, be sure to consider your needs and what you plan to use the generator for. Do not choose a solar power station that is either too expensive or does not meet your capacity requirements.
Final Words
Solar generators are the future of energy storage. Not only are they more environmentally friendly, but also a lot more affordable than traditional methods of generating electricity. So whether you're at home or on the go, solar-powered generator stations provide an easy and efficient way to access to power whenever you need it.
1. What are the 3 main pros of solar power stations?
Solar power stations have many advantages. The three priority advantages include:
Low Cost of Production:
Once solar energy is installed, the only cost that incurs is the money you spend on maintenance.
No Pollution and Eco-Friendliness:
Solar panels don't release any harmful emissions into the atmosphere like traditional energy generation do (such as coal and natural gas).
Reduces Energy Bills:
Installing solar panels can help reduce your energy bill by a significant percentage. This is because you can produce your electricity other than rely on the grid.
2. What can you run with a solar generator?
You can run many electric appliances including lights, fans, laptops, etc. However, if you're looking to power something larger like a refrigerator or air conditioner, you will need a more powerful generator.
3. Are solar generators reliable?
Sure. They can work under all weather conditions and don't require any outside energy source. Once you have a generator, all you need is sunlight, and the electricity will be stored and available when needed most.
4. Can you charge a solar generator with a gas generator?
Yes. You can charge it by gas generators, solar panels, AC wall outlets, and car ports.
