14 Ways to Put Portable Solar Panels to Use in Your Home
solar panels
15/09/2023
Considering portable solar panels for your home? These handy devices have various uses — from charging your portable devices to saving you money on your monthly electric bill.
Portable solar panels are built to withstand the elements, so if you find yourself in a situation where you need power, and you do not want to run an extension cord or deal with the local power grid, a portable solar panel may be just what you are looking for.
In this post, we showcase fourteen innovative ways people use portable solar panels around their houses, and how you can do the same.
How You Can Use Portable Solar Panels in Your Home
Portable solar panels are great for off-the-grid applications, but they can also be used to supplement your home's existing power needs. Here are 14 ways you can use portable solar panels in your home.
1. Security Cameras
If you have security cameras outside your home, they will stop working when there is no power. If a storm knocks out your electricity, you will need an alternative way of powering these devices so that you can see what is going on outside your home. This is especially important if there is a break-in or another crime. Portable solar panels are perfect for this application because they are easy to place wherever you need them most.
2. Water Sprinklers
In addition to powering your outdoor security cameras, portable solar panels are also ideal for powering other devices that need electricity. One of the most popular uses of portable solar panels is to power garden water sprinklers. Many people have their sprinklers set up so that they come on automatically. The problem with this type of setup is that if there is no power in your home, you cannot run the sprinklers manually either. Using a portable solar panel allows you to keep your garden watered even when there is no power available.
3. Garden Lights
Portable solar panels can also be used as an alternative power source for garden lights. This is especially useful if you have a large garden or plants that require special care throughout the year, such as greenhouse plants. These devices allow you to move your garden lighting around as needed instead of having them stuck in one place as traditional lights would be all year round.
4. Car Battery
Portable solar panels are an excellent way to charge your car. You can use these portable solar panels to charge your car in a few different ways. The first way is by plugging your car charger into the portable solar panels and then plugging it into your car's cigarette lighter or 12-volt outlet. The second way is by connecting the portable solar panels directly to your battery with clamps, then connecting clamps from the panels to the battery terminals on your vehicle.
5. Coffee Maker
Coffee makers are another standard device that requires electricity to work correctly. If you need hot coffee in the morning but do not want to wait until after the power comes on, then portable solar panels may be the answer! These units come with all the necessary components needed to start making coffee immediately after opening them up and plugging them into an outlet. They also include adapters so that they can be used with any coffee maker and other appliances, such as microwaves and refrigerators, so that you can keep them running during blackouts.
6. Bluetooth Speakers
portable solar panels for home
Bluetooth speakers are another great use for portable solar panels. They do not require much power to run, but if you want to listen to music outside or on your deck, having a solar panel will allow you to do so without having to worry about running out of battery life from your phone or other devices. You can place your phone on top of the panel, plug in your speaker wirelessly through Bluetooth, and then enjoy yourself knowing that you will have music playing until sunset without worrying about charging anything up.
7. TV/Computer
You can also use portable solar panels to power televisions and computers if you need to keep them running during an outage or storm. This means you would not have to worry about losing access to critical information or entertainment options while the power is down and out. Portable solar panels are handy for ensuring that children do not lose access to their favorite shows and movies when they cannot watch them on television or computer screens due to a lack of electricity.
8. Automatic Gate and Fence Openers
A portable solar panel can easily be used for this purpose if you have an electric gate or fence opener that needs a regular charge to work correctly. You only need to place one of these panels on top of each post where your gate or fence opener is located so that it can soak up as much sunlight as possible. In most cases, this will give you enough extra power to open and close your gate or fence whenever necessary without worrying about running short on juice.
9. Small Hardware Tools
Portable solar panels can also power small tools around the house that do not require much energy to operate but are essential for daily life. For example, if you need to use a drill or jigsaw for an hour or two and do not want to keep running back and forth from your garage or basement to the job site with extension cords and power adapters, then it makes sense to buy a portable solar panel that can charge up during the day while it is sunny and then recharges those tools at night while they are being used at home or wherever else.
10. Pool Pump
If you have a swimming pool at home, you know it requires lots of maintenance and care to keep it clean and functional. The best way to ensure that your pool is clean and ready for use is by using a pool pump, which circulates water through the system to push out debris and dirt while also bringing in fresh water from an external source.
A portable solar panel can be used to power these pumps, allowing them to run all day long without having to worry about running out of power or having to worry about finding a power source nearby.
11. Ventilation Fans
A portable solar panel can also come in handy if you have an exhaust fan in your bathroom or kitchen. These fans often ventilate the home and remove excess moisture from the air. While these fans do not require much energy, the problem is that they need to be connected to an outlet or power supply at all times to keep them running efficiently.
The good thing about portable solar panels is that they can charge up during the day when it is sunny outside and then use that stored energy to power your ventilation fan at night when it is dark inside, and you want to ventilate your home. This will allow you to save money on paying for electricity every month, as well as reduce your carbon footprint on the environment by using fewer fossil fuels such as coal or natural gas.
12. Solar Water Heater
A portable solar panel can also be used as a water heating system in areas with no gas or electric lines available or where it is too expensive for residents to connect their homes to these utilities. These systems provide heat through sunlight and convert it into energy that is then stored in batteries for later use at night or on cloudy days.
13. Dishwasher
Another common use for portable solar panels is to power dishwashers. If you have an older home that does not feature energy-efficient dishwashers, it might be worthwhile to invest in a portable solar panel so that you can run your dishwasher at night when there is no electricity being consumed by other appliances or electronics.
14. Outdoor Barbecue Grill
If you love having barbecues in your backyard during weekends with friends and family members, then having an outdoor barbecue grill can be the best way of attracting more people into your home because everyone loves grilled food. However, this will only work if you have enough propane gas cylinders to power up your grill before cooking anything on it. If you do not want to invest in this option, then buying a portable solar panel is great.
By doing so, you would no longer have to worry about running out of gas or having a bad experience with charcoal briquettes that get lighter fluid on them which could cause severe burns. A portable solar panel will allow you to cook in your backyard without worrying about running out of fuel for your grill.
Benefits of Portable Solar Panels in Your Home
Here are some benefits of using portable solar panels in your home:
Low Maintenance
One of the best advantages of portable solar panels is their low maintenance. There is no need to plug them in or recharge them like with traditional electrical systems, so they do not require any extra work on your part other than setting them up in an area with sunlight. This makes them ideal for people who do not want to deal with complex systems that require maintenance or upkeep.
Cost-Effective
Portable solar panels are cost-effective compared to other types of solar panels available in the market today. They do not require any installation or wiring process, and hence they can be used by anyone without any hassle or complications involved in the process. It is important for you to consider this fact while buying a portable panel because it would save money on electricity bills which are pretty expensive these days in most countries worldwide.
Portability
Portable solar panels are easy to carry around. They have a lightweight structure and can be folded into a small size. You can move them from one place to another with ease. In addition, they are very flexible, and you can use them wherever you want.
Environmentally Friendly
Another benefit of using portable solar panels is that they are environmentally friendly because they do not produce harmful carbon emissions during operation. They are also 100% renewable energy sources which means that once you have purchased your system, it will never run out or need replacing like traditional forms of energy do over time.
The Bottom Line
In sum, portable solar panels have plenty of potential uses in and around the home. If you’re interested in learning more, be sure to check out our website Bluetti. Our portable solar panels are a cost-effective alternative to home solar energy generation. They can be used as a supplement to other energy sources, such as generators and batteries, since they can store power and add it to your existing source when needed.
