Shop our productsCertain little gadgets might use surprisingly large amounts of energy when it comes to electricity-using equipment. Blow dryers, often known as hair dryers, have the capacity to consume higher power than much bigger equipment, including small freezers or space heaters.
Knowing how much energy your blow dryer uses might be useful if you're trying to figure out how to reduce the amount of money you spend on power bills.
How Many Watts Does a Hair Dryer Use?
The majority of hair dryers have a wattage number on them that indicates how much power they use in an hour. The wattage is often listed on the product label, the packaging, or the owner's handbook.
A hair dryer's wattage can vary significantly based on its features and kind. However, the majority of conventional hair dryers made for domestic usage have a power consumption of 1,200–1,875 Watts. Professional-grade hair dryers can be rated at 2,000 Watts or greater in terms of wattage. Hair dryers with higher wattages can dry hair more quickly and work well on longer or thicker hair.
Does a Hair Dryer Use a Lot of Electricity?
Indeed. When in use, it consumes electricity in one of the most wasteful ways possible. Every electric dryer or heater uses a resistive load to produce heat from electricity. Heat is a result of electricity doing work in most electrical equipment. These were comparable to earlier incandescent light bulbs. More light is produced than with a hairdryer; however, it becomes quite hot and ineffective quickly.
A 1500W hair dryer uses 12.5A of power in a standard 120V home outlet. An outdated 60W incandescent lightbulb consumes 0.5A. Hence, in this instance, 25 times the power of the 60W light bulb.
How Much Electricity Does a Hair Dryer Use?
Recognizing how much power is used by common household gadgets, such as a hair dryer, may assist in controlling energy use and lower utility bills. The amount of energy used by a standard hair dryer, which uses about 1,800 watts, may be computed using the hair dryer's daily operating time.
This breakdown demonstrates how the energy use of a hair dryer accumulates over different periods, helping you better understand its impact on your electricity bill.
Time Period |
Calculation |
Energy Consumption (kWh) |
Daily |
1.8 kWh×0.16 hours |
0.288 kWh |
Weekly |
0.288 kWh/day days |
2.01 kWh |
Monthly |
0.288 kWh/day×30 days |
8.64 kWh |
Annually |
0.288 kWh/day×365 days |
105.12 kWh |
How Many Solar Panels Does It Take to Run a Hair Dryer?
Obviously, with increasing electricity costs, no one can afford to use a hair dryer regularly. So, we have come up with an ultimate solution for you.
BLUETTI PV120 Solar Panel
To theoretically cover the energy needs of using a hair dryer, a robust system like BLUETTI PV120 Solar Panel is needed.
Key Features:
Good Efficiency: The Monocrystalline solar cells used to make the panels offer efficiency rates up to 23.4% allowing the panels to convert a significant portion of sunlight to energy. The more the efficiency the more power is generated.Monocrystalline solar cells are known for their high efficiency and longevity.
Long-lasting Coating: Using ETFE (Ethylene Tetrafluoroethylene), coating is made that is durable and enhances the longevity and performance of solar panels. This coating is resistant to corrosion, high UV radiation, and harsh weather conditions. It also has self- cleaning properties, thus reducing the amount of maintenance.
Foldable & Portable: These panels are designed for convenience and versatility. As panels can be easily folded, their transportation becomes easier. This is particularly useful for outdoors and setup. Their portability doesn't make them less efficient or less durable.
Compatibility: The panels are integrated in such a way that they can be compatible with most of the systems available in the market. The inclusion of MC4 connectors makes it easier to connect panels to other power systems.
12-month Warranty: The one-year warranty provides peace of mind and trust amongst customers. This warranty reflects our confidence in the quality and durability of our product, offering assurance that solar panels will work as expected. If any issues arise within the warranty period, customers can rely on support and service to resolve them.
What Size Battery Do You Need to Power a Hair Dryer?
A battery with a usable capacity of at least 10 kWh and a power rating of 4-5 kW is required to power a hair drier. One of the most reliable options is the optimal BLUETTI AC240 Portable Power Station.
To provide a power source to a sensitive hair product like a hair dryer a powerful battery is required. BLUETTI AC240 Portable Power Station is the primary choice. The 2400W AC output can power multiple high-wattage devices simultaneously without exceeding the system's capacity.
Key Features:
Water and dust resistant: The IP65 rating mentioned on the battery indicates that the battery is protected against dust and water. It means this battery can handle harsh weather conditions without compromising performance.
2,400W AC Output / 3,600W Power Lifting Mode: The 2400 AC output to devices can help power multiple appliances simultaneously. The powerlifting mode can temporarily boost output capacity to handle appliances that require higher startup power.
Expandable Batteries: If the battery is expandable to 10,136Wh means storage capacity can be increased, allowing longer period usage during low sunlight or increased energy demand. This makes these batteries reliable battery power backup sources.
Parallel connection: Multiple units can be linked to increase both the storage capacity and power output. 4,800W / 120V Power. This allows the system to provide double the power output, which is suitable for running larger appliances or a higher number of devices simultaneously at 120V.
0-80% Recharging: Fast recharging capability is useful, particularly in scenarios where quick turnaround times are needed to ensure continuous power supply.
1,200W Max. Solar Input: This high solar input capacity allows for faster recharging using renewable energy, making it more efficient and eco-friendly. It ensures that the system can harness and store as much solar energy as possible.
Smart Control & Monitor: As we live in the world of technology, the batteries can be operated with BLUETTI App which supports both bluetooth or wifi connection. Battery status, battery levels as well as settings can be adjusted and notifications about system performance from a smartphone or other connected devices can be received easily.
Seamless EPS: EPS (Emergency Power Supply) functionality allows the system to switch seamlessly to battery power in the event of a grid outage, with a switchover time of just 15 milliseconds. This rapid response ensures that connected appliances experience no noticeable interruption,
Does More Watts Mean Better Hair Dryer?
Yes, a hair dryer with a greater wattage often has more power and can dry hair more quickly.
But hair dryers with greater wattages also use more electricity. A high or low wattage hair dryer should be used based on your hair type and preferences.
It's critical to grasp a hair dryer's wattage as it will enable you to select the ideal model for your hair type and drying requirements. While lower-wattage models could be more appropriate for thin or fragile hair, higher-wattage hair dryers are often more potent and can be more successful for thick, coarse, or hard-to-dry hair.
On the whole, it really depends upon the type of hair and the time you are using the hair dryer.
The heat produced by the hair dryer may use a lot of electricity. It doesn't really matter how much power an appliance consumes when it's turned on because it all relies on how long you use it. Keep in mind that kilowatt-hours, or the total amount of electricity used over time, determine your energy bill.
Making the switch to solar power offers a viable way to gradually reduce or even eliminate your electricity expenses. You may lessen your need for conventional grid electricity and run your home appliances sustainably by using the sun's plentiful energy.
But it's important to do your homework and get quotes from reliable solar contractors before switching to solar power. This guarantees that the choice you make is well-informed and catered to your unique requirements and situation.
For your house, our BLUETTI solar panels and solar power stations provide a dependable and effective approach to going solar. Our products are made with cutting-edge features like long-lasting construction, expanded battery alternatives, and high-efficiency monocrystalline cells to save you money on power bills over the long run and lessen your environmental impact.
Make the move to solar power now to take advantage of clean, renewable energy sources and to improve the sustainability and curb appeal of your house. With the increasing costs of electricity day by day, having a solar system in the house is the only way out to save yourselves from the bomb of electricity bills.
