Shop our productsBy now, you are likely quite familiar with all the different battery types out there, and in particular the LiFePO4.
Understanding LiFePO4 BMS
Overcharge
Overtemperature
- Voltage
- Amperage
- Capacity
- C-rating
Remember: Power (W) = Voltage (V) x Amperage (A)
That's right, it won't.
That's because: Power (W) = 12V x 100A = 1200W
However, if you use a 250A BMS, your maximum power output of your system becomes 3000W: Power (W) = 12V x 250A = 3000W
24V battery pack: Power (W) = 24V x 100A = 2400W max power output
48V battery pack: Power (W) = 48V x 100A = 4800W max power output
Here's example:
Your battery pack has 200Ah of capacity and a maximum C-rate of 0.2C. Then your BMS should be able to handle at least 40A because: 200Ah x 0.2C = 40A max, delivered for 5 hours
