Shop our productsIf you’re planning a camping trip, but have to take your CPAP therapy and it's worrying you, this guide is for you. Camping with a continuous positive airway pressure (CPAP) machine may seem to be an overwhelming task, but it is as easy and feasible if the trip goes on your mind along with proper accessories.
To guide you in planning your travel, we shall take through the things that you should know and aspects to be taken into consideration before camping with a CPAP machine. We’ll discuss how to power up and other issues about camping, as well as taking your CPAP machine off the grid.
Is There a Way to Run a CPAP While Camping?
When a CPAP machine is accompanying you on an outdoor camping trip, the need to continue therapy in the wilderness becomes apparent. Lucky for you, there are two main ways to sleep under the stars while still benefiting from your CPAP treatment.
Choose a Campsite With Power
One of the easiest and most comfortable ways to power your CPAP during camping is by choosing a campsite that has power hookups. Much modern camping is now equipped with electricity, enabling the seamless connection of CPAP devices without concern for battery longevity. This alternative offers the homely comfort of a regular sleeping pattern, and also presents an opportunity to indulge in more luxuries such as air conditioning systems plus electronic gadgets. Picking out a campsite with power supply is not just one initiative toward balancing your camp life with CPAP therapy but also preparing for any eventuality that may occur during the trip.
Take Your Therapy Off-Grid
With those who want a more thrilling and remote off-the-grid camping experience, it is completely possible to run a CPAP machine without depending on any external power sources. Portable power stations, camping generators or solar panels are among the portable power solutions that can help you maintain your CPAP. By having a dependable power supply, you are free to select camping areas that do not have traditional campsites. Nevertheless, proper planning and testing of your off-site power system before leaving the comforts of civilization is very important to avoid unwanted surprises. Moreover, the need for additional batteries arises when using a CPAP machine with features such as a humidifier which can speed up power draining.
Two Ways to Power Your CPAP Off-The-Grid
While camping out in nature using a CPAP machine, going off-grid does not necessarily imply giving up on peaceful slumber. There are two simple ways to power your CPAP off-the-grid.
Using A Portable Power Station
By investing in a portable power station that you can haul everywhere, it becomes easier to run your CPAP machine off-the grid. However, such portable and mobile devices have a range of outlets to include AC power that can also work with CPAP machines. CPAP users can charge portable power stations before their camping trip and use them to provide continuous electricity for the whole night. These stations are convenient because they have the capability to power several electronic devices, giving you enough sources of energy for your CPAP device and other camping needs. A reliable power station that can supply enough energy to support your CPAP machine is necessary for smooth and uninterrupted sleeping in remote areas.
Using A CPAP Battery Pack
CPAP-specific battery packs are specially designed batteries that can be used with the devices to power them without depending on conventional electricity facilities. As these lightweight and portable battery packs are necessarily small, they can be easily carried around during camping. With your battery pack connected to the CPAP machine, you are not under any constraints of being plugged in power outlets. It is recommended to make sure that the battery pack is compatible with your CPAP model but if you are planning a long-term off grid adventure, carry an extra pair of batteries. CPAP battery packs provide a convenient and effective option, allowing you to enjoy the peace of being in nature without sacrificing your sleep apnea treatment.
Related articles: How Can I Power My CPAP While Camping?
How to Power CPAP While Camping? [7 Tips]
3 Portable Power Stations for Camping with CPAP
BLUETTI AC180
Here is the BLUETTI AC180: a comprehensive portable device suitable for both inside and outside use. With a 1,800W capacity and up to 2,709 Watts at powerlifting mode, it is ideal for high-powered loads. At 17 kg, it merges power with portability to serve your mobile demands.
The AC180 has built-in AC outlets and USB-A ports, which are used for multiple purposes. Consider going on a camping trip with it – powering the CPAP machine over night, providing restful sleep in peace and quiet of nature.
Here’s the green approach – use solar power to charge your AC180. Within three hours of sunlight, it becomes fully charged with the maximum of 500W input and is an efficient way to unlock renewable energy.
Safety is a high priority, due to the durable LiFePO4 batteries that work beyond 3500 recharge cycles. BLUETTI AC180 is your pass to energy freedom – a future proof solution.
BLUETTI AC200L
Introducing BLUETTI AC200L – a groundbreaking machine with super-fast speed charging, high output power, no noise generation and the most energy efficient in its class. It is your ideal use for daily electricity requirements.
Forget about unpleasant nights spent on a camping trip and think of AC200L optimizing CPAP equipment for peaceful sleep. They pair seamlessly with B210, B230 and B3 Expansion batteries offering a combined capacity of 8192 Wh – enough power for all your daily needs.
In surpassing competitors, the AC200L has set a new bar for 2kWh generation products that enable quick device charging. Harness up to 1200W power from solar sunlight – a huge increase in productivity, ensuring your devices are always powered. Enter a new age of energy convenience with the BLUETTI AC200L
BLUETTI AC70
BLUETTI AC70 – the beast that provides 1,000 Watts of continuous power with more than one slot for diverse types of equipment. The BLUETTI App has no problem with power lifting mode handling as much as 2000 watts effortlessly. When given an input of 500W solar, it is able to recharge within two hours ensuring that you are never left without power in the wilds.
It goes even faster with the Turbo Charging at 950W. Its LiFePO₄ battery works well even after more than 3000 charging cycles. The clever Battery Management System protects it from the damages, transforming AC70 into your faithful power reserve for uninterrupted weekend breaks away. For CPAP enthusiasts, the AC70 becomes their power source making them sleep in peace during camping.
The Benefits Of Using A Portable Power Station for Camping
Comfort And Convenience
Given the fact that comfort and convenience are what people seek when they go camping, access to electricity is an important requirement. When you escape into the natural world, a portable electric generator enables you to appreciate what modern life offers.
And consider what it would be like to wake up surrounded by the sounds of nature and make a fresh cup of coffee with an ease that doesn’t require lighting a fire or using propane camping stoves.
Provision of an Eternal Source of Power
In essence, on their own portable power stations are akin to an enormous battery that offers ample storage for electricity needs and can supply enough juice to run all your essentials throughout the weekend of camping. For extended camping expeditions, we suggest using a mobile solar power station paired with portable foldable units to get unlimited access to clean energy derived from the sun throughout your adventure.
Clean And Quiet Alternative
Some of the campers carry with them a gas-powered generator which can be used to provide power for either their RV or campsite. Gas generators are indeed noisy and produce toxic gas emissions, such as carbon monoxide. This damages your own camping experience, in addition to the fact that a noisy generator disturbs neighboring camps. Instead of using a gas-powered generator, we suggest replacing it with a portable power station and solar panels so that the campsite is quieter, safer and cleaner. They deliver as much power as a gas generator, are quite convenient to recharge and produce virtually no air pollution.
Compact And Portable
However, you might feel hesitant about purchasing a portable power station for camping – it’s just one more gadget that takes up space in your already overflowing car with sleeping bags as well coolers and those things called ‘camp chairs’. However, you may be amazed at the small size that a PPS can have. The BLUETTI’s small to medium models take up less space than a regular cooler.
It is clear to see that you do not have to cancel your upcoming camping trip on the grounds of using a CPAP machine or stop using a CPAP device in order to travel. What you need is to find a way of powering your CPAP machine when out there. And any of the options we have suggested here can be used. Henceforth, you are able to take your CPAP therapy with you as you have a great time outdoors.
