How Many Watts Does PS4 Use?
18/11/2024
Are you wondering how many watts does PS4 use? Well, based on the type, a PS4 can use 5 watts f or PS4 Silm on Standby Mode, and it can go up to 155 wattages in intensive gaming, especially with PS4 Pro. It all depends on the type of PS4, your usage, and the different modes.
How Many Watts Does A PS4 Use?
To understand how many watts does PS4 use, we need to understand what a PS4 is and how it works first. PS4 stands for Play Station 4, which is a gaming playstation developed by Sony Interactive Entertainment. A part of the PlayStation video games console series, PS4 comes after PS3 and before PS5.
Despite PS5 gaining popularity, PS4 is still much loved. Let's break down the maximum wattage that PS4 uses. The classic or original PS4 has a maximum rating of 250 watts, while the slimmer version is rated at 165 watts, and the Pro version has a maximum of 310 watts.
Wattage for 3 Versions of PS4
p4s
Let's break down each type of PS4, how they differ, and how many watts the 3 different types of PS4 consume.
Original PS4
Released in November 2013, the original PS4 is a dynamic gaming console with distinct sharp corners and edges and a matte-glossy finish. It features an 8-core AMD "Jaguar" processor and 1.84 TFLOPS AMD Radeon Graphics, which means the best pixels ever!
PS4 usually allows peak usage wattage of 150-165W and total memory storage space of 500GB or even up to 1TB in special editions. Plus, it has a distinct power and eject button configuration. However, its biggest drawback was the noise.
PS4 Slim
With a 40% smaller body, the PS4 Slim has most of the Original PS4 hardware components, but it features a quieter fan and 5GHz Wi-Fi support. Moreover, it offers a much easier hard drive replacement option and a total storage space of 1 TB. Coming with the tactile project and eject buttons, the PS4 Slim allows a peak wattage of around 100 watts while in use.
PS4 Pro
Sony goes one step ahead with their PS4 Pro to create stunning visuals and give you an unrivaled gaming experience. It offers beautiful 4K resolution in games and even upgrades lower resolution games to 4K clarity. Furthermore, it gives you faster load times and allows up to 160 peak wattage when in use, especially when working with 4K games.
How Many Watts Does the PS4 Use in Different Modes?
The table below illustrates the 4 different modes of a PS4 and how many watts does PS4 use in different modes.
PS4 Mode
Wattage
Standby/Rest Mode
0.47W
Idle on the Main Menu/Login Screen
85.6W
Streaming Mode
99W
Gaming Mode
120W
Gaming in PS4 with PS VR
144W
These values can vary based on your use, and the duration you use PS4 for. Plus, if you let it stay idle when not using, or turn the power off, it also determines how many watts does PS4 use.
How Many Watts Does A TV and PS4 Use?
p4s
On average, most TVs use between 27 to 147 watts, and similarly, a PS4 uses between 45 to 145 when in use. So, it puts us at around 250 watts when both are used together. Here, we assume a typical TV use around 57 watts.
In reality, the number of watts that a TV and PS4 use together depends on the type of TV and its wattage level. For example, if you're using a simple 75-inch OLED TV with your PS4 for intensive gaming, the total wattage could be around 270 watts.
In contrast, if you're pairing a 50-inch LED TV with PS4 Pro, the total wattage can easily land at 235 watts.
Wondering why?
A 50-inch LED TV uses 75 watts to run, while a PS4 Pro uses around 160 watts during play, and we average it to 120 watts. We add the two: 75 watts + 160 watts = 235.
Let's be honest: you won't be using it in full force, so you can average the PS4 wattage at 120 watts, and that gives us 195 watts to run both TV and PS4 together.
How Much Electricity Does A PS4 Use Per Month?
How many watts PS4 use per month depends on the duration of use. If you're actively using it, a PS4 may consume around 145 watts per hour, but if it's idle, it can use around 185 watts per hour.
Let's say you use your PS4 3-4 hours daily. Simply multiply your duration by hourly wattage, and then multiply by 30 (total days in a month).
For gaming, you use around 145 watts per hour, so if we take this value, it will be 145 x 4 x 30 = 17.4kWh. For streaming at 90 watts per hour, it will be 10.8kWh.
Simply multiply this value by the cost of electricity in your region. Let's assume it is 2 cents for gaming and 1 cent for streaming.
So, for gaming, the monthly cost will be 17.4kWh x 2 cents = $2.40, and for streaming, it will be $1.08.
If you use PS4 for both gaming and streaming daily, take that into account when calculating the total and for idle time, too.
Can you Use a Solar Generator to Power PS4?
Do you love gaming, but the bills are racking up? Not to worry! You should consider switching to another source of energy to power your PS4. Solar generators are a great alternative, and a typical solar generator kit comes with solar panels, a battery, and an inverter.
BLUETTI AC60
Portable Power Station
IP65 rating for water and dust protection
Check Discount
Before selecting a solar generator, you need to understand how many watts does PS4 use. If you're playing a demanding game, the PS4 will use 160 watts. But adding a 50-inch LED TV (75 watts) and headphones (5 watts) may take the wattage to around 940 watts, especially if you typically play for 4 hours.
This estimated wattage can be lower or higher based on your use, and you should make sure your battery and inverter can cater to your PS4 before selecting a Solar Generator.
Best Alternatives of Electricity to Power a PS4
Wondering what Solar Generator to pair with your PS4? We've got you covered. Below are 3 BLUETTI Solar Generators that work seamlessly with all types of PS4 with energy to spare.
bluetti ac180
The BLUETTI AC180 Solar Portable Power Station is durable with LiFePO₄ batteries that make them long-lasting with 3500+ charge cycles. Moreover, it's a quiet generator and eco-friendly since it generates electricity via solar power. It allows you the option to plug in 11 different devices at the same time through USB ports and flexible rechargeable options.
Key Features:
1,800 W High Power Uplift Capacity: Long story short, it can provide 1,800 watts continuously for running your devices. Plus, it offers 2,700 watts in short bursts in Power Uplifting Mode for devices that require higher initial wattage.
1,152 Larger Battery Capacity: Its battery allows you to store up to 1,152 watts, which means it can run your appliances when there's rain or a cloudy day.
Rapid Recharging: This Solar Generator recharged from 0 to 80% in just 45 minutes. With this quick recharging, you can get it ready for use pretty quickly for your PS4.
bluetti ac200max
The BLUETTI AC200MAX Expandable Power Station offers energy storage of 2,048Wh, and you can simply think of it like a big battery that stores energy to run all your devices. Plus, you can recharge your battery with solar panels, a car, a generator, or even combine two outlets for faster recharging. For example, you can charge it in 2 hours when using both wall outlet and solar panel together.
Key Features:
High Capacity & Expandable: With a battery of 2,048 W, it can provide 2,200W continuous power and 4,800W when the device is first turned off or for shorter bursts. If a 2,048Wh battery isn't sufficient for your needs, you can also attach external batteries to increase storage to 8,192Wh.
Long-Lasting Battery: LiFePO4 batteries are durable and long-lasting and can be charged for 3500+ cycles, and they make the power station a lot more durable.
4-Yeat Warranty Plan: If anything goes wrong, it comes with a 4-year warranty from BLUETTI, and it's compact and even portable despite the 61.9Ib.
bluetti ep500
The BLUETTI EP500 Solar Power Station is a huge portable battery that can store 5100Wh energy, and it can continuously run 2000W. It has cool tech features like a smart touchscreen and remote control via the BLUETTI App.
High Capacity to Run Multiple Devices: Since it stores 5,100Wh, it can run continuously at 2000W, which means it can run a 1500W toaster with other small household devices easily. Great for events like camping and barbeque, where you need to connect multiple devices at the same time.
Flexible Recharging: It comes with several recharging options, like solar, which makes it sustainable, but you can connect to the grid via a wall outlet. This way, it will always be ready for use. Plus, with 1200W solar, it rapidly recharges.
Durable and Portable: LiFePO4 makes it long-lasting, and its structure is built to last and tested for safety. Moreover, it's also portable, perfect for camping and other outdoor events.
Do you love gaming on PS4 but want to cut down on energy costs? No worries, you can simply connect your PS4 with a Solar Generator. Solar Generators can allow you to game freely without worrying about electricity costs for hours on your Play Station 4.
It's sustainable, but make sure to choose a product that can handle your PS4 wattage for multiple hours for a seamless experience.
AC200L
01/04/2025
