What is mAh – Does a Higher Mah Battery Last Longer?
15/12/2023
Have you been scratching your head over “What does mAh on batteries mean? Well, this question deserves your attention. When buying a battery, you should know what mAh means and how this terminology impacts the capacity of these batteries to charge other devices. Does a higher mAh battery last longer, or what?
In this blog, we will uncover comprehensible answers to these questions. Read on to find out more about the definition and importance of mAh and the products that can supply mAh for your household needs.
What is mAh?
battery
Before we dig deeper into the topic, let's acquaint ourselves with this basic terminology. When we speak of mAh, we are referring to a battery’s capacity to generate electricity. It is short for milliampere-hour, which represents the capacity of the battery to source electric current in an hour before it dies off.
Let’s suppose mAh is the gas trunk of your car. The amount of gas you can store in your trunk is its capacity. The larger the capacity of the trunk, the larger you can store the gas and the longer distance you can cover before refueling. Similarly, if you are to ask, “Does a higher mAh battery last longer?” Yes! That’s true. The higher mAh battery will last longer and will charge your devices for a longer period.
There you go! Now you have the basic introduction of what mAh is. It is important that you understand this terminology. That way, you will be able to select the most suitable power generators for your home or outdoor adventures.
You can find out how much a battery will source you with electric current using the following formula:
mAh = Wh x 1000/ V
You can read the battery capacity (Wh) in the manual book or nameplate of a battery. For instance, if a battery has a Watt-hour of 200 Wh and requires a voltage of 5 volts, the mAh will be:
mAh = 200X 1000/ 5
        = 4000 mAh
That said, now you have a battery that will supply 400 milliamps of current to your household or other outdoor devices every 10 hours. That way, it will be easier for you to select the best device for your home.
Why is mAh Important?
If you are going shopping for a battery-powered device, you must consider looking at its mAh. That way, you will be able to align the battery-supplied electricity with the electrical consumption of your household. When you know the mAh, you can better select a battery that can cover all your electricity needs at home.
For instance, if you are willing to buy a battery that can supply electronic appliances like refrigerators, you need to buy a battery with a higher capacity. As a result, you are making sure that all your devices can run for hours before your battery goes off.
One thing worth mentioning here is that mAh can tell you all about the performance of solar generators that you need to know.
Related articles: What Is mAh (Milliamp Hour): Understanding Battery Capacity
How To Pick The Right Battery Backup For Your Home?
What Impact Does Mah Have on Battery Life?
The mAh does not represent the life cycle of the battery, but a battery with high mAh and good quality usually lasts longer. In addition to this, the battery with higher mAh takes a longer time to recharge compared to the other batteries.
The mAh is the unit for the storage capacity of the battery. The higher the mAh, the more energy a battery can store which means the battery can power your household for a longer period.
bluetti battery
Yes, a battery with higher mAh lasts longer compared to the one with lower mAh. The number of mAh represents the capacity of the battery to store power. For instance, a battery with 1000mAh can store energy of 1000 milli-amperes and can supply 1000 milliamperes of energy in one hour or 500 milliamperes of energy for two hours, and so on.
However, if a device consumes more power, a battery with higher storage capacity will deplete faster. On the other hand, some devices are energy efficient, and they can run for longer periods of time.
Tips to Choose the Best Device by mAh?
You already know how important mAh is for you to make informed decisions when shopping for electronic devices. Here are some of the tips you should keep in mind when choosing a device based on its mAh:
1. Consider Your Household Energy Consumption
Above all the other things, it is crucial that you determine your electronic needs. You should know how much electric supply you need for your household. You don’t want to purchase a device that cannot meet your supply requirements. Hence, you should know what electric capacity you need to supply your appliances.
2. Compare the mAh Ratings
After you have determined your mAh needs, you can now go through various mAh options and choose the one that fits your criteria. You can now go by the devices or batteries that have enough capacity to align with your needs.
3. Consider Customer Reviews
It goes without saying that you should check the customer reviews and feedback before you purchase a product. You must know the pros and cons of the device you are about to purchase.
BLUETTI Offers Optimum Mah-Bearing Devices
With BlUETTI, you can experience a spectrum of mAh options with a wide range of devices it offers. Here are some of the devices that you can go for:
  • BLUETTI AC200MAX Expandable Power Station
The BLUETTI AC200MAX Expandable Power Station comes with smart control, and one can use the application on their cellphone to control the power station remotely. Here are some of the specs of the product:
2,200W AC Pure Sine Wave Inverter (4,800W Surge): This portable power station is capable of supplying 2200 watts of power continuously with a pure sine wave, which is crucial for sensitive electronic devices.  However, this device can handle transient power surges of 4800 watts, which is needed to start up a demanding appliance with higher power requirements.
2,048 Wh Capacity: This power station has a total capacity of supplying 2,048 watts power of electricity in an hour. With this capacity, you can use this device to supply energy for an extended period of time.
LiFePO4 Battery with 3,500+ Life Cycles to 80%: BLUETTI uses a lithium iron phosphate battery, which is enough to tell that the battery will be long-lasting. You can charge your battery for 3500 cycles and use it until it discharges. Despite this overuse, the battery will still be 80% efficient.
Expandable Up To 6,144Wh with 2×B230 or 8,192Wh with 2×B300: This expandable option helps to expand the capacity of this power station. You can extend the power capacity up to 6,144Wh after attaching two batteries of B230. On the other hand, you can expand the power capacity up to 8,192 Wh when attached to 2 batteries of B300.
Smart Control & Monitor in BLUETTI App: This means you can monitor the power station remotely through the BLUETTI app on your mobile phone.
  • BLUETTI EP500Pro Solar Power Station
bluetti ep500pro
The BLUETTI EP500Pro Solar Power Station comes with a LiFPO4 battery, which is a trademark of longevity in terms of power stations. You can also remotely control the device through your mobile application.
5100Wh LiFePo4/3000W PSW Inverter, 3500+ Cycles to 80% Capacity: This power station has 5100 watts-hour of power capacity and can supply 3000 watts of sine wave swiftly. This battery can recharge and discharge for 3500 cycles, and it will still be 80% efficient. You can use this device for the long term and for 3500 cycles with only a 20% regression in the efficiency of the device.
Movable Power Station: If you are an outdoorsman and keep planning outdoor activities, you need a power station with the convenience of portability. This BLUETTI power station is portable, and you can carry it around with you to fulfill your plans.
In-grid UPS Mode & Flexible UPS Mode (24/7): The power station can act as the uninterrupted power supply for your household when there is a power outage or electric shutdown.  You can use this power station for your 24/7 electric supply, even in off-grid areas or where electricity is unavailable. This power station is a good option for an uninterrupted supply of electric energy, even in areas that are far from the electricity grid.
Multiple Devices Can Be Loaded Simultaneously: The power station comes with multiple outlets and ports to supply multiple electric devices at once. You can now charge your phone and supply your refrigerator and television at once using the multiple pot options provided by this BLUETTI portable power station.
Flexible Recharging Way To Keep Your EP500Pro Always On: You can recharge these power stations through multiple sources. For instance, you can recharge this battery through solar panels, a car charger, or an AC grid.
Thus, this device offers you the freedom to recharge it through any accessible source. With this freedom, you can charge the battery and use it even in emergency situations where the electric supply is usually hard to access.
Smart Touch Screen: This device comes with a smart interface, which makes it easier to use the device. You can keep a record of several features like input, output, and status of the power station through this smart touch screen.
The BLUETTI PV200 Solar Panel is a good match for this power station. You can charge this power station using this 23.4% efficient monocrystalline solar panel. With their ETFE coating, these solar panels last longer. You can fold these panels and carry along this duo of solar panels and power stations for your outdoor adventures. These solar panels grace you with 12 months of assurance and mental peace.
Wrapping Up
By now, we presume your confusion over “Does a higher mah battery last longer?” is clarified, and you know which battery will work for you based on a number of factors. You can choose from the two BLUETTI batteries suggested that apply to your household needs. Plus, you can also supply your outdoor adventures with electricity via batteries.
