Shop our productsFor outdoor photographers and adventurers, the BLUETTI Handsfree 2 Backpack Power Station is the ultimate gear companion. Combining a high-capacity power station with a 60L backpack, it offers hands-free charging for your devices while you explore. Whether you're hiking through rugged terrain or capturing the perfect shot, this all-in-one setup ensures you never have to worry about running low on power. With the innovative BluePack backpack, your gear and power are organized in one place, while the ultra-slim Handsfree power station provides reliable energy on the go. Ready to charge up your adventure? This is freedom in a backpack.
Key Features and Specifications:
Complete Freedom with BLUETTI Handsfree
When you’re out exploring, keeping devices charged can be a challenge. The BLUETTI Handsfree All-In-One solves this by combining a high-capacity Handsfree power station, modular BluePack backpack, and optional portable solar panels. Whether hiking, photographing, or discovering new trails, this setup brings reliable, hands-free power every step of the way. -
BluePack Backpack – Gear and Power in One Place
Designed with outdoor photographers in mind, the BluePack backpack simplifies packing by combining storage for power, photography equipment, and other essentials. No more fuss over limited battery life or juggling bulky bags – with high capacity and modular design, the BluePack seamlessly integrates storage for essential gear. Equipped with an ultra-slim Handsfree power station, it’s your all-in-one companion, delivering power and storage that meets every outdoor challenge.
- Effortless Organization with Modular Backpack Design
- Power Storage Compartment: The backpack’s power compartment securely houses the Handsfree power station, reinforced with sturdy support panels to safeguard against bumps and shocks on rough trails.
- Photography Gear Compartment: Organize your cameras, drones, and other tech essentials. Adjustable dividers let you set up this section to suit your needs, keeping your equipment safe and accessible.
- Personal Essentials Compartment: Dedicated space for clothes, ID, medication, and other essentials ensures that everything is packed and ready for extended trips.
Multifunctional MOLLE System for External Storage
The BluePack is designed to be as versatile as your adventure: - Dual Rows of Webbing: The MOLLE system allows you to attach essential tools and accessories for quick access.
- Multiple Hooks: Attach items like tents, sleeping bags, or solar panels to these external hooks.
- GoPro Shoulder Strap Mount: Capture every moment with a GoPro mount on the shoulder strap, allowing for hands-free recording as you trek through diverse landscapes.
Flexible Capacity and Expandable Storage
With two capacity options, BluePack meets various travel needs: - BP1 Backpack: 42L capacity with Handsfree 1 Backpack Power Station, perfect for 1-3 day trips.
- BP2 Backpack: 60L capacity with Handsfree 2 Backpack Power Station, ideal for longer 3-5 day adventures.
Easy Access with 180° Opening Design
The backpack’s 180° zipper allows you to open it fully, making it easier than ever to pack and access items on the go. This “grab-and-go” design means your equipment is always ready when you are, so there’s no time wasted fumbling with gear. -
Handsfree Power Station for All-Day Energy
Pairing the Handsfree power station with two or more battery packs guarantees power throughout the day. Equipped with BLUETTI’s fragmented solar charging technology, the Handsfree can detect sunlight and charge efficiently. If clouds block the sun, charging will automatically pause and resume when the sky clears, giving you up to 30% more battery life. -
Portable Solar Panels for Sustainable Charging (Optional)
When hooked up to portable solar panels, the Handsfree system takes energy efficiency to the next level: - Flexible Charging: You can connect multiple solar panels in parallel to boost charging power. Each panel (PV60L: 60W, PV120S: 120W) features a USB-A port and two Type-C (100W) ports to directly charge your power station or devices.
- Compact and Lightweight: Folding down to the size of a 16-inch laptop, this panel is ultra-portable and doesn’t weigh you down.
Travel-Friendly Design with High Load Capacity
The BluePack is built for the long haul. With an ergonomic, breathable design and MOLLE system, it offers comfort while supporting a load of up to 30 kg. So, whether you’re scaling mountains or covering rugged terrain, you’ll stay comfortable and supported. - Rugged, Waterproof Protection
Each component of the Handsfree All-In-One system is designed to withstand the elements:
IP65 Waterproof Rating: The entire system, including the portable solar panel, features an IP65 waterproof rating, making it ideal for various outdoor environments.
BluePack Backpack: The BluePack backpack is fully designed for waterproof protection, with waterproof fabric, waterproof zippers, and a rain cover, ensuring the bag can withstand moderate to heavy rain, providing full protection against the elements.
Powerful and Adaptable Outputs
Handsfree power stations are equipped to meet the demands of heavy-duty tech: - Handsfree 1: Rated at 300W, with a 600W boost mode to support devices with high power requirements.
- Handsfree 2: Boasts a 700W rating, with a boost mode reaching up to 1200W for professional-grade equipment.
Versatile Charging Ports for Any Device
The Handsfree power station provides five output ports: - One AC Outlet for standard plugs.
- Two Type-C Ports (100W each) for high-speed charging.
- Two USB-A Ports for added versatility.
Durable, Long-Lasting Battery Cells
With advanced LFP (Lithium Iron Phosphate) cells, the Handsfree All-In-One system is built to last. It offers 4,000+ charge cycles, ensuring it will serve you for over a decade of adventure. These cells have an extremely stable chemical structure, protecting against overheating and fires, even in extreme temperatures from -20°C to 40°C. -
BLUETOPUS AI-BMS – Smart Battery Management
BLUETOPUS AI-BMS is an intelligent battery management system that automatically regulates charging and discharging. It prevents overcharging, overheating, and other risks to ensure safe power supply no matter where you are. -
Fire-Resistant Casing for Extra Safety
The Handsfree power station’s casing is made from fire-resistant materials, adding an extra layer of safety in high-temperature environments. This material resists ignition, keeping your power station safe even when things heat up. -
Multi-Method Charging – Power Up Anywhere
The Handsfree All-In-One supports six charging methods, so you’re never far from a power source. Recharge via wall outlet, solar panels, car charging, combined wall and solar, gas generator, or even lead-acid batteries. With such versatile options, you can keep your devices powered no matter where your adventure takes you.
Why Choose BLUETTI Handsfree Backpack Power Station:
1. Stay Powered on Your Photography Expeditions
For outdoor photographers, every moment counts, and so does the power to capture it. With the BLUETTI Handsfree Backpack Power Station, you can charge up to 5 devices at once while on the move. From drones to cameras, smartphones to laptops, the quick-access ports make it easy to power all your gear without ever missing a shot. Whether you're trekking through the forest or climbing a mountain to find the perfect vantage point, this backpack keeps you connected and charged, ensuring your devices stay ready for the next frame.
2. Keep Energized on Your Hiking Adventures
Trekking through remote trails can be exhausting, and the last thing you want is to run out of power halfway through your hike. The BLUETTI Handsfree Backpack Power Station is built for the long haul, offering reliable power to your devices while you walk, climb, and explore. The lightweight, ergonomic design and MOLLE system let you carry essential gear like water bottles and first aid kits without adding unnecessary bulk. When it’s time for a break, you can easily power up your phone or GPS to track your progress or call for help if needed. Charging on the go has never been this easy!
3. Empower Your Camping Trips with Uninterrupted Power
Whether you're setting up camp in the woods or spending the weekend at a remote campsite, the BLUETTI Handsfree Backpack Power Station is the perfect companion for your outdoor excursions. Charge your camera, phone, and even small appliances all at once—without worrying about limited outlets or carrying bulky power banks. The external attachment system also lets you hang solar panels to recharge while you're off exploring or taking a nap by the fire. With up to 5 devices charging simultaneously and a lightweight, durable design, this backpack ensures that power is always within arm's reach, keeping you ready for every adventure.
What’s Inside the Box?
When you unbox your BLUETTI Handsfree Backpack Power Station, here’s what you’ll find ready to take on your next adventure:
BLUETTI Handsfree Portable Power Station
Your ultimate energy companion, designed to keep your devices powered up while you're on the move. It's sleek, portable, and built for the outdoors, ensuring you never run out of juice.
BP Backpack
The heart of the Handsfree system. A high-capacity, ergonomic backpack that not only stores your gear but also houses your power station. With quick-access ports and flexible storage, it's your perfect adventure partner.
AC Charging Cable (1.8m/5.9ft)
Power up your Handsfree station at home or in your car with this long AC charging cable. Stay charged before you head out into the wild.
Everything you need to know to get started. This guide walks you through the setup, usage, and care of your BLUETTI power station, so you can hit the ground running.
Warranty Card
Your peace of mind is important. This card ensures you have coverage in case anything goes wrong with your new power station.
Solar Charging Cable (MC4-XT60, 1.5m/4.9ft)
Stay off-grid longer. With this solar charging cable, you can easily recharge your Handsfree station using solar panels, ensuring you’ve got power no matter where the sun shines.
With BLUETTI Handsfree All-In-One, you’re always ready for the next adventure, whether it’s capturing the perfect shot, staying connected from the wilderness, or just enjoying the peace of being off the grid.
