Shop our productsThe dependence on power is unquestionable whether you’re in an industrial setting or living in a suburban household. Even small power disruptions can put a halt to your daily routine. Facilities with critical power needs, like medical and data centers, are especially prone to disastrous consequences during power outages. It can be a matter of life and death or cost billions.
The best solution for power outages is an uninterruptible power supply (UPS). It provides steady power whenever the grid supply disconnects. The transition is within milli-seconds, and your appliances keep running without shutting down.
Do you also plan to install an uninterruptible power supply (UPS) system? We’ll tell you everything you should know before embarking on the hunt for the best UPS system.
What is an Uninterruptible Power Supply?
An uninterruptible Power Supply is a system that acts as an automatic backup during power failures. Whenever the primary supply disconnects, the system activates in a flash. It provides backup through batteries that charge on grid power or other energy sources like solar power, diesel generators, etc.
The system consists of an inverter-converter device and battery packs. It’s integrated with the electrical installations in your facility. You may find solar panels connected to the system to recharge the batteries. The solar panels offer greater energy independence by eliminating the need for a grid supply. The UPS device acts as an intermediary that converts AC power to DC power and vice versa.
The system stays in stand-by mode and turns on automatically in the event of power cut. The system capacity depends on battery output measured in ampere-hours. The type of batteries, inverter-converter device, and output quality account for efficiency. Some systems also provide protection from surges and fluctuations. Above all, your equipment stays safe and runs optimally on pure sine wave input when using an uninterruptible power supply.
What Does an Uninterruptible Power Supply Do?
There are three main functions of an uninterruptible Power Supply. It provides automatic power backup, protects from surges and fluctuation, and acts as an inverter-converter. Let’s explore each of these functions.
Automatic Power Backup
The uninterruptible Power Supply’s primary function is to provide an automatic power backup. Imagine a sudden power cut due to any reason. Your appliances, equipment, and everything else that runs on electricity will turn off. If you are in a critical facility like a medical or data center, the losses can be colossal. You can avoid such a situation with an uninterruptible Power Supply, it activates automatically the moment power is cut.
360-degree Protection
An Uninterruptible Power Supply provides pure sine wave output and maintains specified voltage levels. It prevents electrical damage and potential malfunctions in your appliances. The system also protects your equipment from surges and voltage fluctuations. It absorbs the surges and keeps your facility running in optimal conditions.
Inverter-converter Function
An uninterruptible Power Supply is mainly an inverter-converter device. If you install solar panels to experience energy independence, you can integrate them with the UPS. It will convert DC input from solar panels to pure AC output. There would be no need for an additional device. In the same way, it converts 110V AC supply to 12V DC to charge the batteries.
Types of Uninterruptible Power Supplies
Uninterruptible Power Supplies can be of multiple types. We’ll explore specific categories of UPS systems differentiated on their power backup characteristics.
Double conversion or online UPS
A double conversion or online UPS operates in two-way simultaneously. It converts AC input into DC output for batteries and then converts DC input from batteries to AC output for your facility. As a result, conversion time becomes zero as the system feeds already converted power. It eliminates the risk of voltage fluctuations and power quality issues.
Standby or off-line UPS
This system comes into action in the event of a power outage. It stays in standby mode and only converts AC-to-DC to recharge the battery packs. Whenever a sudden power outage occurs, the system activates to provide power backup. The conversion time is in milli-seconds and doesn't cause a shutdown.
Line-interactive UPS
Line-interactive UPS is not a full-fledged backup supply but rather a support backup. It can power devices for a few minutes until the main supply resumes. The system is helpful during changeovers to avoid shutdowns. The facilities using line-interactive UPS have other power backups and keep this system as an additional layer of protection. It also maintains voltage levels for optimal run.
What Are the Advantages of Uninterruptible Power Supply?
Power losses are frequent and unexpected. It can occur due to harsh weather, unscheduled maintenance, or several other reasons. The one good solution to power loss is an Uninterruptible Power Supply. Let’s discover what other advantages it could offer.
Reliability and Convenience
Uninterruptible Power Supply is a 100-percent reliable solution. It provides power backup without needing to shut down anything. You can have seamless power connectivity and stay worry-free. It’s also convenient due to its automatic operation, it will turn on itself during a power disconnection.
Protection and Improved Quality
When connected to grid supply, fluctuations and surges are quite common. They can impact electrical appliances and cause malfunctions. The Uninterruptible Power Supply offers protection against surges and fluctuations. It also maintains voltage levels and provides pure sine wave output. Your devices and appliances can run seamlessly in optimal conditions.
Easy Installation and Operation
Installing an Uninterruptible Power Supply requires professional assistance. However, the installation process is seamless. There’s no need for changes in existing electrical lines. The system doesn’t consume much space. And it can be installed within a day or two. Moreover, Uninterruptible Power Supply operations are automatic and don't require human intervention.
Maintenance-free Solution
The best part about Uninterruptible Power Supply is that it’s completely maintenance-free. Other power solutions like diesel generators and solar panels require maintenance for optimal use. The most you would do for Uninterruptible Power Supply is maintain batteries in case you’re using lead-acid ones.
How to Choose an Uninterruptible Power Supply?
Selecting the right Uninterruptible Power Supply system can be hectic if you lack key information. Let’s analyze factors that are critical when choosing an Uninterruptible Power Supply;
Backup Capacity
The first and foremost factor is the backup capacity. You should calculate your power needs in ampere-hours. It can be calculated by multiplying the wattage of each appliance with expected hours of usage during power loss. The Uninterruptible Power Supply capacity should be greater than what you calculate. It’s because power outages are unpredictable and can last longer.
Battery Types
The Uninterruptible Power Supply system’s efficiency largely depends on battery types. You should purchase advanced quality batteries with high life cycles, good charging time, and AC/DC efficiency. There are a variety of options available in the market. The lithium-ion batteries are quite popular and prove effective for uninterruptible power supply systems. Also, consider maintenance and battery care.
Power Quality
Always go for systems that provide pure sine wave output and maintain specified voltage levels at standard frequency. Power quality is crucial because it has a direct impact on electrical appliances. If the power output is low quality with distorted waveform, your appliances can malfunction and fail to run optimally.
Advanced Features
Select a Uninterruptible Power Supply system with advanced features for added convenience. You should look for remote monitoring through a mobile application or LCD display control. Other features may include eco-mode for power saving in case battery levels drop. All these features increase the stability of the system.
Type and Installation
You should be mindful of your needs and select appropriate UPS types: Double conversion UPS, Standby UPS, or Line-interactive UPS. The installation requirements can vary for different models. You should check with the supplier to see if your facility has appropriate provisions for easy installations.
Do You Need Home Battery Backup with UPS?
Remember, UPS cannot go without home battery backup. A UPS is a device that takes power from battery backup to run your household or facility during electricity disruptions. The battery backup consists of a number of batteries that recharge from UPS and feed power back to the UPS.
If you need a 360-degree solution for an Uninterruptible Power Supply, there’s no better option than BLUETTI home battery backup systems. BLUETTI is a tech-revolutionary company that offers power solutions to embrace energy independence. Their home battery backup systems stand out with hi-tech features and high efficiency. Let’s discover more;
Enjoy uninterruptible power connectivity with BLUETTI EP900 + B500 Home Battery Backup. It has an enormous expandable capacity of up to 12288 Wh. The system can power your entire home during long electricity disconnections. You can connect it with solar panels through the AC coupling option for complete energy independence.
The BLUETTI EP900 + B500 Home Battery Backup provides 120V / 240V voltage options to power every appliance. It comes with advanced LiFePO batteries having high lifecycles and efficiency. You can install the system indoors and outdoors at your convenience. It has smart control options through a user-interactive mobile application.
The BLUETTI EP900 + B500 Home Battery Backup is a game-changer for households. It provides 10-20 kWh capacity with a max output rate of 9 kWh. It can power both 120 or 240-volt appliances. The device has hi-tech LiFePO batteries with an intelligent battery management system for high efficiency.
The BLUETTI EP900 + B500 Home Battery Backup is IP65 rated to ensure durability and enable indoor/outdoor usage. The system integrates seamlessly with the solar system and grid supply. The installation is easy and hassle-free, and you can get the system up and running on the same day. It can be controlled through mobile applications with advanced features.
We’ve got you covered with everything about uninterruptible Power Supplies. You are in a good position to select the right UPS system for your needs. You can calculate your backup requirements and get an appropriate system installed. The BLUETTI backup systems are superior options with affordable price tags. Go and explore the market to hunt down the best UPS system!
