LiFePO4 BMS: What is it, How to Choose?
10/11/2025
By now, you are likely quite familiar with all the different battery types out there, and in particular the LiFePO4.
Understanding LiFePO4 BMS
Overcharge
Overtemperature
View of the LiFePO4 battery pack with the BMS board | Download Scientific  Diagram
  • Voltage
  • Amperage
  • Capacity
  • C-rating
Remember: Power (W) = Voltage (V) x Amperage (A)
That's right, it won't.
That's because: Power (W) = 12V x 100A = 1200W
However, if you use a 250A BMS, your maximum power output of your system becomes 3000W: Power (W) = 12V x 250A = 3000W
24V battery pack: Power (W) = 24V x 100A = 2400W max power output
48V battery pack: Power (W) = 48V x 100A = 4800W max power output
Here's example:
Your battery pack has 200Ah of capacity and a maximum C-rate of 0.2C. Then your BMS should be able to handle at least 40A because: 200Ah x 0.2C = 40A max, delivered for 5 hours
