Shop our productsReady to hit the open road and live life on your terms in an RV but worry about how to do it? In the past, you had to really rough it out. But not anymore. Solar products make the RV lifestyle safer and a whole lot more comfortable. Now you can top off your battery. Keep your phones, computers and tools charged up. And you can even keep the coffee warm all thanks to solar power innovations.
With just the right solar items, used the right way, you can make the RV lifestyle so much easier, especially if you have others joining the ride. If you’re looking to further reduce your overall expenses, then knowing how solar integrated with RVs will be a boon to you. But the trick is knowing how. And that’s what this article will cover.
Powering RV with Portable Solar Panels: Overview
Portable solar panels are designed to be used with RVs and other small boats that do not have access to shore power. They typically come with a built-in charge controller, which prevents overcharging the battery, and an inverter, which converts the DC produced by the portable solar panel into AC. The AC electricity can power appliances in your RV using standard household extension cords or adapters.
Inexpensive models produce only enough electricity for minimal use — perhaps powering a cell phone or laptop — but more expensive models can have enough energy to power appliances such as lights, televisions, and air conditioners.
Common Applications of Portable Solar Power for RV
Using solar power for RV is a great way to reduce your power bill and help the environment. Here are some examples of off-grid living in an RV where you can use portable solar power.
Power Your Refrigerator
A refrigerator is an essential appliance in any home, but it is especially critical in RV living when you are not near a convenient power source. You may have to travel miles away from your campsite before finding a place to plug in your fridge, which can be dangerous if a storm or some other emergency requires evacuation.
If you want to keep your food fresh for more extended periods and avoid losing any of your perishables, a portable solar panel can generate enough energy for a small fridge to run for days without needing additional charging or refueling from an external source.
Charge Your Cell Phone
Access to a portable solar panel is essential if you want to keep your phone charged at all times, especially if you spend most of your time outdoors exploring nature or traveling across the country in an RV. Without access to electricity, it would be almost impossible to stay connected with loved ones back home or find help in an emergency if something went wrong while driving across the country in an RV.
Keep the Lights on While Camping at Night
Portable solar panels are a great way to power your appliances, but they can also be used to keep the lights on while camping at night. This is an essential feature if you are staying in an RV park that does not have electricity.
Choosing the Best Portable Solar Panel System for RV
There are a lot of different options when it comes to portable solar power for RV, but not all of them are equal. Here are some things that you should look for when choosing the best portable solar panel for your needs:
Compatibility
There are several things to consider when installing a portable solar power system on your RV. The first is whether or not you have enough room on your RV's roof to accommodate a suitable-sized solar panel. If you have enough space, you can use an off-the-shelf solar panel kit that includes everything you need. This is an excellent option if you are not interested in getting too technical with your installation and want something that works without hassle.
Moreover, not all RVs are made equal. If you have a motorhome or trailer, or even if it is just an old camper van, there is no guarantee that it has the right kind of roof for installing portable solar panels. Before buying one, take some time to research whether or not your specific model can safely accommodate them.
Power Need
The amount of power required depends on the type of RV and the number of people living in it. For example, if you have a camper van that sleeps four people and wants to run a microwave and coffee maker simultaneously, you might need a solar panel that can produce up to 100 watts or more. If you are camping with just two people in an RV that sleeps one person, then a 60-watt solar panel should be enough for basic needs.
Quality
The quality of your solar panel can make a big difference in how much power it produces, how long it lasts, and whether or not it will last through any weather conditions. Look for a reputable brand that has been around for a while and has excellent customer service if something goes wrong with your product.
Knowing what kind of guarantee and warranty comes with your portable solar panel before you buy it is essential. Some companies offer lifetime warranties on their products, while others only offer 90 days or less. You should also check whether they offer free repairs and replacements if something goes wrong with your panels during this period, as well as whether or not they have any easy return policies in place if you do not like how something works out for you after buying it online or elsewhere.
The capacity of the portable solar charger is a crucial thing to consider as well when choosing one for your RV or camper van conversion project. Different brands use different technologies and configurations with their chargers, so you must read their specifications carefully before buying one to know what capacity it has. Solar panel capacity is measured in watts (W) or joules per hour (J/h). The higher the wattage, the more energy a panel can generate per hour.
Portability
A good portable solar panel should be easy to carry around wherever you go without having to worry about breaking down on the road or having issues with weight restrictions when flying into an airport with one in tow. It should also be lightweight enough so that you do not need another person helping you carry it around if there is no one about to help out with this task but yourself and your family members traveling with you on vacation.
Price
The price of your portable solar panel should be in line with the quality. It is important to remember that you get what you pay for. If you buy a low-quality solar panel, it will not last very long and will not produce as much power as its higher-priced counterpart. However, purchasing an expensive solar panel may not be worth the investment if you are only going to use it occasionally or have limited space in your RV.
Important Considerations for Off-grid living in Your RV with Portable Solar Power
Learn About the Battery Bank and How It Works
A battery bank is the heart of any off-grid system, and it is what makes a living in an RV possible. Without a battery bank, your lights would go out every time the sun went down. The batteries are rated for amp hours (AH). The more AH they can provide, the longer they will last. Most solar panels are wired into the RV's battery bank with a disconnect switch that allows you to turn off the power if needed. You can also use your generator as an alternative power source when you are not using solar energy or if there is no sunlight available during certain times of day or year.
Understand How an Inverter Fits into the Equation
Inverters are the brains of your solar system. They convert the direct current from your panels into alternating current that you can use in your RV. Inverters come in two types: modified sine wave and pure sine wave.
Modified sine wave inverters are the least expensive option, but they do not provide as clean a power source as pure sine wave inverters. They are also less efficient than pure sine wave inverters and have a shorter lifespan.
Pure sine wave inverters produce a more consistent voltage and alternating current (AC) frequency. They have better efficiency than modified sine wave inverters and last longer — but they cost more upfront and require a bit more maintenance over time.
The next step is explore Bluetti's solar products to support your RV adventure. Feel free to reach out to customer service if you have any questions regarding our products.
Shop Bluetti for all your solar needsShop products from this article
