How Many Watts Does a Freezer Use?
Home Appliances
12/03/2026
Budgeting up your monthly expenses? Want to know what sum of your monthly salary goes to your freezer bills? How many watts does a freezer use?
Well, deep freezers in your homes can consume anything from 80 watts to 900 watts. However, this consumption can vary depending on the model used. The older the model of the freezer, the more energy it consumes. Several other factors, like size, usage, and place of usage, can also affect energy consumption.
Factors That Affect Electricity Consumption
freezer
Usually, the wattage consumption is mentioned on the nameplate of the freezer. But keep in mind that this figure might not apply in your case. The consumption can vary with the temperature of the geographical area you are living in and the usage of freezers.
Freezers are not always functioning at their peak. They go through 3 phases, which are start-up cooling, active cooling, and idle cooling. The energy consumption fluctuates during these three phases.
When the freezers are actively cooling, the system is at its peak wattage consumption to lower the internal temperature. After the optimum temperature for the freezer is reached, the energy consumption drops. At this very time, the compressor, the evaporator fan motor, and the condenser motor need no power. Thus, the watt power required by the freezer will drop instantly.
Phase
Power Consumption
Idle/ Standby
0-50 watts
Start-up
150-200 watts
Active cooling
60-100 watts
These are for modern and latest freezers, but for older versions, the active cooling can be between 100-300 watts and the Start-up between 300-800 watts.
How many Watts Does a Freezer Use?
If you are using the latest model of the deep freezer, it will consume, on average, between 200 and 300kwh every year. Now, if you want a monthly consumption of the deep freezer, we are here to break it into monthly calculations of how many watts a freezer uses.
You can calculate how many watts a freezer uses by finding out the wattage used by the freezer in the manual. Use the wattage mentioned in the manual with the hours used per day.
For daily consumption, use the formula:
Daily Consumption (Wh) = Wattage (W) x hours run per day (h).
For the monthly consumption, multiply the daily consumption by 30 days:
Monthly Consumption (Wh) = Daily Consumption (Wh) × 30 (for a 30-day month).
On average, the latest model of deep freezer consumes 20 kWh to 25 kWh every month. Furthermore, extending the same calculation to find out the per-day consumption, divide the monthly consumption by the number of days of the month.
For example, by dividing the 20kWh by 30 days, we get 0.67kWh to 0.83kWh of energy per day.
How Many Watts Does a Microwave Use?
How Much Does It Cost To Run A Deep Freezer?
freezer
The deep freezers of the modern age are pretty budget-friendly. They will cost you almost $33 to $42 for a year. If this calculation is split into monthly costs, it turns out to be $3 to $3.50. When you do this calculation for daily consumption, it becomes $0.09 to $0.11.
If you wish to calculate the customized monthly cost of a deep freezer, just multiply the monthly electricity consumption by $0.14. It is the current residential rate for electricity consumption in the USA. That is how easy it is to calculate how many watts a freezer uses.
Does a Freezer In the Garage Use More Electricity?
If you are using your freezer in the garage where the temperature is extreme, the energy consumption can escalate as high as 50 %. When there is a hotter temperature outside, it takes a lot for the compressor to maintain a lower temperature in the freezer.
Your compressor will have to work harder in extreme temperatures to lower the inner temperature to zero degrees Fahrenheit. Thus, it consumes even more electricity, almost 50% more than the usual electricity.
As a result, your electricity bills rise in summer. However, in extremely cold temperatures, your freezer’s thermostat may confuse the external temperature with the inner temperature. It might undertake the external temperature as the temperature of the inside when it is not.
Yes, you may panic here because the false temperature regulation can affect your meat and the stored food in your freezer. Your food will thaw up, and in the long run, the frost may grow around the insulator.
What is more upsetting is that this cycle of freezing and thawing up can sometimes lead to damage to insulation. When the insulation of the system is damaged, it directly affects the thermostat, and it has to overwork to maintain the optimal temperature.
To combat such issues, you must keep your garage insulated or air-conditioned. Furthermore, a tip that really works is to invest your money in buying a new freezer for your garage. The latest freezers come with various solutions to such problems.
How to Saving Electric Costs?
You can reduce your electric costs in certain other ways, but the best choice to go with is to use renewable energy sources like solar generators. You can give an efficiency boost to your freezer by keeping it in a spatial place or by avoiding frequently opening and closing the door. However, if you have an old model of the freezer, these tricks might not work for you.
You can opt for long-term solutions like deploying sustainable sources of energy. Here are some of the best solar generator picks to power your freezers.
BLUETTI Elite 200 v2 Power Station
The BLUETTI Elite 200 V2 Expandable Power Station provides a steady flow of 2600W of electricity with short bursts of energy ranging up to 3900W (via Power Lifting mode for resistive loads like heaters). It comes with an automotive-grade LiFePO₄ Battery, which can be charged and discharged 6000+ times, and it will still retain 80% capacity. After you have charged the battery 6000+ times and consumed all the energy for each cycle, the efficiency of your battery will decrease only to 80%.
Key Features:
  • 2,073.6Wh Capacity: Not only can you use the power station to power your freezers and other sensitive electronic devices directly, but you can also store energy. The battery can store up to 2,073.6 Watt-hours.
  • No Expansion Needed – All-in-One Design: This model focuses on high capacity in a compact, non-expandable unit (unlike some modular systems). Its built-in 2073.6Wh provides ample storage for most needs, powering devices efficiently without add-on batteries required.
  • Smart Control & Monitor in BLUETTI App: You can download the BLUETTI app and control your power station smartly.
BLUETTI Apex300 + 2*B300K Home Battery Backup
This BLUETTI APEX 300 Home Battery Backup is capable of providing you with a smooth flow of electrical energy up to 3840 Watts and a short burst of 7680 watts of power (via Power Lifting mode for resistive loads). It comes with a LiFePO₄ battery that can be charged and discharged for 6000+ cycles, and it will still retain 80% capacity. After you have charged the battery 6000+ times and consumed all the energy for each cycle, the capacity of your battery will decrease only to 80%.
Key Features:
  • 2,764.8Wh High Capacity (Built-in): The unit features a built-in battery that stores 2,764.8 Watt-hours of energy right out of the box—enough to power essential appliances during outages. Besides, you can further enhance the storage capacity by adding up to 18 B300K expansion batteries (or in scalable configurations with multiple units). With expansions, the system can reach up to 58,000Wh of energy.
  • Multiple Ways to Recharge: You can charge the battery through various methods, including home outlet (AC), solar panels, car alternator, generator, lead-acid battery, and more—offering flexible options for any situation.
  • 3840W Max. Fast Dual Charging (Solar + AC): This device can charge super fast, especially when using dual charging: combining AC input (up to 3840W) and solar input (up to 2400W max) for rapid recharges, getting to full capacity in as little as around 60-80 minutes depending on conditions.
BLUETTI Elite 400 Solar Power Station
bluetti ep500
BLUETTI Elite 400 Solar Power Station is a massive battery that can store energy up to 3,840Wh (watt-hours). It features a durable LiFePO₄ battery that lasts far longer than expected. You can charge and discharge the battery for 3,000+ cycles, and it will still retain 80% capacity. After 3,000+ cycles of full use, the battery capacity decreases only to 80%.
Key features:
  • 2,600W Pure Sine Wave Output (with 3,900W Power Lifting/surge for resistive loads): It delivers a smooth, continuous flow of 2,600 watts of energy and can power multiple sensitive devices reliably, from refrigerators to power tools.
  • App Remote Control and Smart Touchscreen: This portable power station can be remotely monitored and controlled through the BLUETTI app (via Wi-Fi & Bluetooth). The intuitive smart touchscreen display makes it easy to operate and check status at a glance.
  • Multiple Devices Can be Powered Simultaneously: This device supports up to 9 output ports (including multiple AC outlets), so you can supply power to several devices at once without issue.
  • UPS Backup: In the event of a grid failure, the Elite 400 switches to battery power in ≤15ms, automatically becoming the energy source for your household's critical loads to keep essentials running seamlessly.
Do you struggle to manage your freezer’s monthly energy consumption? If yes, calculate the monthly electricity expenditure of your freezer and control the expenses. Calculate how many watts your freezer uses and multiply your daily hours of usage by the wattage mentioned in the manual.
You can reduce the expenditure by shifting to the latest model of the freezer and using BLUETTI solar power stations. Use the solar panels and produce the energy to load your devices. That way, you can reduce your electricity bills.
