4 Best Solar Generators for RV in 2024 Reviewed
Product Reviews RV / Motorhomes
12/01/2024
More and more people are settling into alternative lifestyles, with full-time RVing becoming more popular. It's the kind of lifestyle infused with freedom and adventure, something far removed from the standard stationary home.
However, challenges are bound to arise amid the appeal of a nomadic lifestyle on wheels. Energy production is a huge challenge that needs solutions for RVers. Fortunately, the advancements in portable solar power systems provide promising channels for off-grid power.
2024 has a varied landscape of RV solar generators. Finding your way through this sea of choices is a personalized process to help meet every individual's off-grid energy needs. Let's search for the best solar generators to find your perfect sidekick that powers your travel.
BLUETTI AC500 + B300S
bluetti ac500b300s
AC500 & B300S, an innovative expandable power system, is set to change how you harness solar energy. With a powerful 5000W inverter, this solar power system provides the highest pure sine wave output and has an impressive surge capacity of up to 1 kWh. Anything you plug in will run at its fullest function and capacity.
Charging the AC500 system is seamless regardless of your location. The AC500 can charge through a wall outlet or with solar panels, providing an effective input rate of up to 8000W. Charge it before you go on your camping trip so that you still have power even when everything else fails.
AC500 is compatible with B300S battery and connection of 12×B300S batteries takes the capacity to whopping 36,864Wh, significantly reducing reliance on grid power and minimizing electricity costs.
What seals the deal? The BLUETTI solar generator kit consists of  solar panels. BLUETTI monocrystalline magic with 23.4% rated conversion efficiency converts the sunlight into power effortlessly. These panels outshine polycrystalline ones with a slick 95% transparency. BLUETTI Solar panels are the best of efficiency and reliability to elevate your energy game.
Apart from home use, the AC500 & B300S system is a lifesaver for RV enthusiasts. This solar storage system provides continuous and dependable power for your RV, enabling a more enjoyable road trip. Power your gadgets like a gas generator without the expense of fuel, noise, and pollution. Whether at home, camping, or driving an RV, the AC500 is your safe and environmentally friendly partner.
BLUETTI AC200P + 3*PV200S
bluetti ac200p
Meet the BLUETTI AC200P + 3*PV200S, your reliable off-grid powerhouse designed for homes, worksites, wilderness adventures, road trips, or your backyard. The 2000 Wh capacity of this solar generator takes ordinary features to a new level with the addition of a High-Speed charger for an RV port, which comes at 15W, and wireless ports that allow quick recharging. Alongside other common outlets, including AC ones, it comes with USB A & C charges on both sides, cigarette lighter charging entry points, and DC Port.
The AC200P's lithium iron phosphate (LiFePO4) battery has a tremendous 3,500+ life cycle and promises to have almost a full decade's lifespan of one cycle per day. The AC200P, with a state-of-the-art battery management system (BMS), carefully monitors every aspect of its performance and protects your devices from any dangers that may occur in usual use.
Versatile and powerful, the BLUETTI AC200P can power various appliances such as blenders, ice coolers, radios, and projectors. In addition to its typical uses, this solar generator is perfect for RV fans. It is a reliable power source and makes a smooth journey in RVs more enjoyable.
And how about BLUETTI PV200 solar panels? These panels come charging at turbo speed not only to recharge but also to efficiently absorb the energy. 23.4 percent conversion rate collects an amazing 2kWh energy per day and gives enough juice to operate your gadgets all through the day. The secret? Monocrystalline solar cells and multi-ETFE layers layered provide superior efficiency along with a lifespan that never ends.
BLUETTI EP500Pro
bluetti ep500pro
Imagine being able to lighten up your whole party, power family camping trips, run the workshops in the cabin or even supply all of your houses during those unexpected outages. The BLUETTI EP500Pro is truly a class leader in solar power stations. This beast can handle anything with a powerful 5100Wh LiFePO4 battery pack and a 3kW rated pure sine wave AC inverter.
With up to 15 outlet sources, the EP500Pro powers laptops and air conditioners as easily as electric vehicles, so you can always have control. Foldable solar panels from BLUETTI unlock the full power of the EP500Pro. These solar panels are made from monocrystalline cells that convert 23.4% sunlight to electricity conversion and work great in any weather condition. Don't worry about scratches and water splashes. They are ETFE coated and have an IP65 junction box.
The EP500Pro is a reliable power station for RV enthusiasts and an ideal travel and road trip companion. Its versatility and strong characteristics suit anyone needing a dedicated mobile power supply. Their built-in dual-core microcomputers and internet connectivity make firmware upgrades a breeze, so you never have to worry about your EP500Pro falling behind in innovation. In the sphere of solar generators, there is no "best" but only "better," and BLUETTI EP500Pro, in this sense, represents perfection.
BLUETTI EP800+B500
bluetti ep800
The BLUETTI EP800 is not just an energy storage system. It's the skeleton key to massive savings on peak-hour power, continuous access even when outages occur, and an adventure toward complete independence from the grid.
This versatile tool integrates with your current solar setup or pairs seamlessly with new panels. With AC coupling, the EP800 connects with your existing solar systems without extra work costs in wiring rooftops. What's enticing? BLUETTI's monocrystalline panels boast a 23.4% conversion efficiency. With a slick 95% transparency, it outshines polycrystalline panels, no matter the light level. Elevate your energy game with BLUETTI's efficient and transparent solar power solution.Solar panels can also be optionally connected directly to DC coupling for optimum efficiency.
It is easy to increase its capacity – use 2-4 B500 expansion batteries, the total output of which ranges from 9.9 kWh up to 19.8 kWh, depending on the energy supply you need. The EP800 inverter excels with an astounding production of up to 7600W and flexible voltage options, such as 12 V / or ideally powering your appliances.
EP800 is a game-changer for any RV enthusiast. Due to its adaptability, it is a great travel companion for road trips. Make the most of living off the grid or appreciate nature-packed weekends in a secluded cottage. EP800 offers you the best of both – serenity and quietude like never before, coupled with modern comforts, offering an exciting, memorable RV experience.
What Size Solar Generator Do You Need?
The size of a solar generator you choose for your RV will determine the reliability and efficiency of providing enough power to fulfill all your needs. It would help if you considered your generator's attributes when selecting it.
Assess Your Power Needs
Start by noting all the devices and appliances you will require power for in your RV. Think about the necessity for lights, fridges, and other electronics. To assess your total power requirements roughly, check each item's wattage specifications.
Calculate Daily Power Consumption
 Add up the wattage of all devices you use and calculate an average daily power consumption. This will enable you to know the smallest power capacity that your solar generator should be.
Consider Solar Conditions
Consider average conditions for the amount of sunlight in areas you visit. The generator you need to sustain your stay might be smaller if you are frequently in sunnier regions than when it is mostly cloudy or shaded.
Generator Size Guide
Recommended Generator Size
Up to 500 Wh
1500 Wh or smaller
500–1000 Wh
1500–3000 Wh
1000–2000 Wh
3000–5000 Wh
Over 2000 Wh
5000 Wh or larger
Is It Worth Buying a Generator for Your RV?
rv
If you want to invest in a solar generator for your RV, rest assured that it is worth the investment, as numerous benefits are associated with such an addition. It helps save money while ensuring that our environment remains safe.
Sustainable Power Source
A solar generator uses the sun to capture energy and provides a renewable, sustainable power supply for your RV. This not only lessens dependency on conventional fuel but also aids in creating a cleaner environment.
Cost-Efficiency
Although the initial investment seems big, long-term savings are significant. Solar generators make it unnecessary to purchase fuel frequently, saving money over time.
Quiet Operation
Unlike traditional generators, which often create noise, solar generators run quietly, so the annoying hum of swinging equipment does not spoil a campsite.
Independence
The solar generator gives you energy independence. You're not bound to RV parks or campsites with electrical hookups, meaning the opportunity for remote exploration is available.
Related articles: How Big of a Solar Generator Do I Need for My RV?
What Size Solar Panel Do I Need to Keep RV Battery Charged?
Consideration for Choosing a Solar Generator for RV
Power Requirement
When choosing a solar generator for an RV, consider how much power you need. Find out how much energy your gadgets and appliances use. This directs your generator size selection; a smaller one could be enough for laptops and lights, but a larger one is required to run fridges or air conditioners.
Battery Capacity
The essential will be battery capacity in watt-hours (Wh). Higher capacity means longer use. When looking for a solar generator in an RV, understand the battery capacity and choose one that fits your demands.
Solar Panels
Solar panels are crucial; they convert sunlight into electricity that charges the generator's battery. Select your panels based on wattage, efficiency, and size. Make sure that the battery recharges are compatible and have sufficient power.
Durability And Portability
Durability matters for travel. Thus, an RV solar generator should withstand the journey's challenges. And choose a small, portable generator. Portability is more convenient.
Inverter Type
Inverters convert stored power. In a solar generator, inverter rating is an important factor to consider during purchase; it defines accessible power. A good option is a pure sine wave inverter with clean electricity and wide device compatibility.
Now is the perfect time to load your RV with an advanced solar generator. Nowadays, substantial reductions in the cost of solar technology have made gas-burning generators with heavy carbon footprints obsolete. Modern solar generators, which are small but powerfully large, low-cost options, have become long-term investments for your RV life.
The market provides a wide spectrum of options; thus, finding the perfect generator to fuel your specific RV adventures can be easy. Well, take the occasion to enjoy all that modern solar power has to offer – efficiency and eco-friendliness in RV life.
