How to Choose a Backup Battery for Home Security System?
13/06/2024
Burglars are quite clever, they would cut your power to turn off the security system and break in. But you can plan ahead and install a backup battery for the home security system. Sounds safer? Let’s explore battery backups for security systems, and guide you on how to choose the best battery backup. This blog covers everything about battery backups with expert insights to help you make a good purchase decision.
Do You Need Backup Battery for Home Security Systems?
If your home security system runs on electricity, you must have a backup battery. The power outages can occur anytime that may leave your house unsecured. Imagine, you’re returning back from vacations and find out someone broke into your house but your security alarms never went off. The most probable reason could be that the power supply to your house was cut.
You can avoid such a situation with a battery backup. Even if the power supply is cut, your security system will be intact and running on battery backup. In modern homes, the security system controls the entire house, the doors are automatic, have face recognition or fingerprint scanners,not keeping a battery backup for such systems can be a disaster. You can be locked out of your home until the power resumes.
Power outages are common with the country's aging electrical infrastructure. The electrical failures have increased threefolds in the past few years. Changes in the weather patterns, especially storms are a major reason for long power disruptions. Hence, there’s a critical need to have  battery backup for home security systems.
Here’s why do you need a battery backup for home security systems;
Enhanced Security
You should not risk your security deeming that power outages won’t happen. Keeping a battery for the security system will enhance safety. The system will be running to detect interference and intrusion whether primary power is available or not.
Prevent False Alarms
Most security systems have an inherent feature to go off whenever a power outage occurs. It can create issues for you because the local police station or neighbors would consider it an invasion or security threat.
System Health
Power outages can cause damage to electronics. Many times power outages combine with surges that can be disastrous for your system’s health. There can also be a potential data loss because most systems don’t upload data to memory in real time.
Legal Requirements: Sometimes the local governmental authority may require you to have battery backup for home security systems. When applying for insurance, the company can bind you to install a security system with battery backup.
Guide for Choosing a Right Backup Battery
There’s no rocket science in choosing the right battery backup, all you need is to consider a few critical factors. Don’t forget that your security relies on the system, any miscalculation or misinterpretation can prove disastrous. But don’t worry, this guide can be your blueprint for choosing the right battery backup. Let’s guide step by step to get the perfect backup battery:
Backup Capacity
The first question to answer is how much backup capacity do you need to run your security system. The battery backup is measured in kilo-watt-hours (kWh). Your security system’s equipment must be rated in watts (W) or kilowatts (KW). For instance, the power rating for cameras would be around 20-40 watts.
To check required capacity in kWh, you can multiply the wattage with hours of usage. Let’s say four cameras, 20-watts each, would run for 8 hours max. during a power disruption. The required battery capacity will be 4*20*8 = 640 Wh or 0.6 kWh.
Compatibility
You should also check the compatibility of your backup battery with the security system. The power output from battery backup should meet the voltage and wattage requirement of your system. You can check and compare the power ratings of both devices. In case, the ratings are different, the electrical system won’t run or can malfunction.
The compatibility is a critical factor because it directly affects the system’s operations. When selecting any battery backup, make sure to check the power ratings. Not considering the ratings can lead to a significant loss.
Efficiency
The battery backup efficiency will depend on the battery technology. There are two common types of batteries used for backup, lithium-ion and lead-acid. The lithium-ion batteries are highly efficient and reliable whereas lead-acid batteries are cost-effective. You can get up to 90% efficiency and deeper depth of discharge from lithium-ion batteries
Additionally, the backup efficiency is determined by the battery management system and output from the inverter. The inverter should provide high quality pure sine wave AC output. It runs the devices optimally.
Durability
Durability is another critical factor to consider when selecting a battery backup for your security system. In case, you will keep the battery backup outdoors, it should have IP65 rating to provide protection against rough weather conditions. The temperature sensitivity should also be according to the weather conditions in your locality. Many battery backups lose efficiency when subject to high or low temperatures.
You can also determine durability from overall build quality and maintenance requirements. Battery backup with lead-acid batteries will require frequent maintenance for optimal usage. Not upkeep such batteries will reduce their durability.
Additional Features
Always look for useful features in the battery backup like remote monitoring & control, EPS/UPS option, and multi-recharge facility. These features increase the usability of battery packs making them more practical. Since most security systems are controlled remotely, the battery backup should also have the same option. The EPS/UPS enable automatic on-off during power outages.
Moreover, a multi-recharge facility increases the reliability of the backup system. In case you’re facing longer outages, you can recharge your battery backup using solar energy or any other alternative power resources.
4 Best Backup Battery for Home Security Systems
Let’s explore experts-recommended battery backup packs for home security systems. These backup solutions are engineered by BLUETTI, the world’s top manufacturer of advanced solar technology. The BLUETTI backups stand out with superior quality and market competitive prices. Let’s browse the best BLUETTI backup battery for home security systems:
BLUETTI AC300 + 2*B300 Home Battery Backup
The BLUETTI AC300 + 2*B300 Home Battery Backup is an efficient backup for advanced security systems requiring high power input. It has an expandable capacity of up to 12288 Wh. The battery backup has EPS mode enabled for uninterruptible operations in case of power outages. The backup has highly efficient LiFePO4 battery packs to ensure durability and longevity.
You can control and monitor the battery backup via smart BLUETTI mobile application. The battery backup supports multi-recharge for enhanced reliability. You can use solar power or even car generators to recharge the batteries. It also allows fast recharging, you can recharge with up to 5400W input rate from solar and grid supply.
BLUETTI AC500 + B300/B300S
The BLUETTI AC500 + B300/B300S can be your ultimate home security power solution. It will keep powering your house during long power disruptions. The battery backup has an expandable capacity from 3,072Wh to 18,432Wh. It comes with advanced LiFePO4 battery packs known for their efficiency with 3500+ cycles. The battery backup has EPS mode to run on standby mode. You can recharge the battery packs using different power sources.
The battery backup offers remote control and monitoring via smart BLUETTI mobile application. It has seamless bluetooth and Wi-Fi connectivity. You can also use manual controls as per your convenience. The overall design is sleek and portable to reduce space consumption.
The BLUETTI EP800+B500 Home Battery Backup is designed to fulfill your complete power needs 24/7. It has an enormous capacity of 9920Wh to keep powering your home during power outages. The battery backup can run independently on solar power with input of 9000W. It comes with LiFePO4 battery packs for high reliability. The battery packs are temperature resistant with high efficiency and durability.
You can control and monitor the backup system using the smart BLUETTI mobile application. It updates in real time and shows all stats about recharging, battery levels, etc. The battery backup is IP65 resistant for indoor and outdoor usage. It has a sleek design and allows plug-and-play integration with existing electrical infrastructure.
The BLUETTI EP900 + B500 Home Battery Backup is a beast holding enormous power to keep your home up and running. It has an expandable capacity from 9,920Wh to 19,840Wh. You can use 9kW of load at single time with this battery backup. The advanced LiFePO4 can take up all loads seamlessly due to their high efficiency and durability. The battery backup integrates with existing electrical infrastructure without needing additional installations.
The battery backup has Wi-Fi and bluetooth connectivity enabled for control through smart mobile applications. Additionally, BLUETTI provides 10-year warranty with the system as testament to its superior quality and long lasting products.
Now that you understand the cruciality of battery backup, it’s time to enhance your security and ensure foolproof protection. Considering the factors discussed in the guide, you can select the best battery backup for your system. When it comes to home safety, you should avoid risks and take every step to keep your premises secure.
What are you thinking of? Make your selection from the BLUETTI range and enjoy peace of mind. Your security system will be in a good position to prevent theft with battery backup. It’s like being one step ahead of burglars. The BLUETTI battery backup offers greater control with mobile connectivity and seamless operation with EPS mode. Elevate your home security system now!
