Worldwide solar energy is vital for sustainable energy efforts , as solar trackers plays an essential role in fixing efficiency. By increasing energy capture, these systems helps move solar panels to follow the sun.
The two major types of solar trackers are: single axis and dual-axis, with the latter being more accurate that means the second type of solar tracker that is mentioned, known as dual-axis tracker, is more preferable in following the sun as compared to the first type, which is the single-axis tracker.
While there is a higher cost at first, but it can help you to recover the initial costs faster by extra energy produced by them. Also, for homeowners, utility companies, and businesses it can also work for long-term savings.
Are you also wondering about what is the purpose of a solar tracker? Let’s further discuss this in detail, which will definitely help you!
What Is a Solar Tracker?
As technology has a significant role in increasing benefits of solar energy, Nowadays, solar tracker is a key innovation. They are typically made from materials such as aluminium for the frame, steel, gears, include motors, and control systems for movement.
For the electricity generation and higher efficiency these devices helps to move solar panels that follows the sun’s path which keeps themat the best angle. As it is mentioned above, the two main types of trackers, from both of these types, single-axis and double-axis, the double-axis is more useful which follows both the daily and seasonal movements of the sun.
Compared to fixed panels, the main advantage of solar tracker is it’s potential increase in energy output. However, you can also face challenges such as their maintenance, higher complexity, and their initial costs.
What is the Purpose of a Solar Tracker?
A solar tracker increases your energy output by 25%, and exposure to sunlight allows the solar panels to follow the sun’s path of movement. From Bluetti, you will get a variety of solar panels, including PV120 if you have a small setup, PV200 for a balance between size and power, and PV350 if you need a large amount of energy.
These panels provide you with solutions for off-grid power and emergency backup by operating with Bluetti’s portable power stations.
Let’s check the key features of Bluetti Solar Panels!
BLUETTI PV120 Solar Panels
Key Features
High-efficiency monocrystalline Solar Cells:
BLUETTI PV120 solar panels enable maximum power output in small areas by giving you 23.4% efficient output, making them an optimal solution if you want a smaller installation.
Durable ETFE Coating:
PV120 solar panels are durable in harsh weather because of the long-lasting ETFE coating on them. Your energy output will also be increased because of enhanced light absorption.
Compact and Portable Design:
PV120 panels have a foldable design allowing you to easily transport and store them whether you are camping or traveling. It serves as a convenient source of energy for you in an emergency.
Universal Compatibility with MC4 Connectors:
Bluetti PV120 panels can easily be integrated into your existing solar system as their MC4 connectors are compatible with most solar generators.
One-Year Warranty Coverage:
You will get a 12-month warranty covering defects in materials and workmanship. In this way, Bluetti gives you satisfaction and peace of mind.
2. BLUETTI PV200 Solar Panels
Key Features
Exceptional Efficiency with Monocrystalline Cells:
BLUETTI PV200 panels allow you to generate more energy even under limited sunlight with their 23.4% efficiency due to Monocrystalline Cells.
Enhanced Durability with ETFE Coating:
The lifespan and reliability of PV200 are increased using ETFE coating. It protects against harsh environments and enhances light absorption and efficiency.
Conveniently Foldable and Portable:
You can carry and set up PV200 panels anywhere due to its compact foldable design. It provides you with power anywhere without any bulk.
Broad Compatibility with MC4 Connectors:
You can expand your existing solar system without compatibility issues by installing PV200 panels due to their MC4 connectors.
Comprehensive 12-Month Warranty:
Bluetti expresses its commitment to quality and customer satisfaction by offering you a 12-month warranty covering defects and issues.
You need to click on the link mentioned below to check out a detailed review of Bluetti products!
3. BLUETTI PV350 Solar Panels
Key Features
Superior Conversion Efficiency:
To power your high-demand application, PV350 provides you with optimal energy production due to a higher conversion rate. It generates reliable energy even if you have low sunlight in your area.
User-friendly setup with Integrated Kickstand:
The integrated kickstand design of BLUETTI PV350 panels allows you to easily set it up for temporary or permanent installations. You can easily adjust it to maximize its exposure to sunlight.
Robust and Splash-Proof Construction:
The durable and splash-proof PV350 panels allow you to choose it for outdoor activities and harsh weather. It makes sure that you have a safe source of energy.
Compatibility with Multiple BLUETTI Models:
The Bluetti PV350 panels can be inserted into your existing BLUETTI models due to their compatibility with the range of power stations.
Compact, Foldable, and Portable Design:
The foldable and compact design of PV350 panels is easy to set up Whether you're heading to a remote location or setting up a backup power source at home.
How Much Does a Solar Tracker Cost?
The cost of a solar tracker can totally vary on factors such as size, type, and complexity. Due to their simpler design, the single-axis is less expensive than the dual-axis. Single-axis trackers ranges from a few hundred to a few thousand dollar.
On the other hand, double-axis trackers range from several thousand dollars or they can cost even more. Dual-axis trackers can be more expensive than single-axis, but they are more efficient.
It ranges from $500 to $1,500 per panel, prices for your residential areas which includes installation also. And for commercial-grade solar trackers, it can range from $10,000 to $50,000 per tracker unit.
By making tracking systems more cost-effective, larger installations can benefit from economies of scale.
Is a Solar Tracker Worth It?
If you want to know about the worth of solar tracker, it totally depends on the factors such as energy needs, financial outlook, and location. As compared to other fixed panels, solar trackers can increase energy production.
These trackers are more effective in areas where the increased energy production balances out the installation costs with high solar insolation.
While trackers have higher upfront costs, the ROI may be favorable in sunny regions due to mechanical systems.
Over time, maintenance for trackers with moving parts it can lead to higher costs. Mostly, in some areas, there are discounts and rewards that can help you pay for some of the costs of getting solar panels.
These trackers can work better in sunny spots, as they are like machines that move the panels to follow the sun.
Well, it depends on you whether getting a solar tracker can be a good investment for you or not, how much it will costs upfronts, what rewards you can get. Lastly, if it is a good fit for your energy goals and budget.
Pros and Cons of Using a Solar Tracker
Are you going to install a solar tracker? Let's examine its advantages and disadvantages. These are the pros and cons of installing a solar tracker. This will help you in making an informed decision.
Pros |
Cons |
1. Increased Efficiency: Solar trackers change your solar panel angles according to sunlight throughout the day, increasing your energy output. 2. Reduced Space Requirement: Solar trackers reduce the number of needed panels, giving you more output per panel. 3. Improved Performance in Lower Light: Trackers enhance energy production during early mornings and late afternoons due to enhanced orientation. 4. Potential for Higher Financial Returns: You can have faster ROI and greater savings due to enhanced energy output. 5. Adaptability: You can future-proof your setup for the whole year by installing dual-axis trackers. |
1. Higher Initial Cost: The solar trackers will cost you more than fixed solar panel systems because of their need for additional mechanical components. 2. Increased Maintenance: You need to regularly maintain the moving parts of solar panels to keep them working. 3. Complexity in Installation: You need to have more specialized knowledge and skills to install solar trackers. 4. Weather Sensitivity: Trackers can be affected by severe weather conditions demanding higher repair costs from you.
To Track or Not to Track?
Deciding whether to implement solar trackers in a solar array is a significant decision that depends on various factors. The benefits of solar trackers include increased energy output, efficiency in limited spaces, and adaptability to seasonal changes.
However, drawbacks include higher initial costs, maintenance requirements, and complexity in installation. The choice to use solar trackers depends on project site conditions, budget, and the importance placed on maximizing output.
Large-scale projects in sunny regions may find the benefits outweigh the costs, while smaller systems or areas with less sunlight intensity may not justify the additional expenses and complexity. Ultimately, the decision to track or not to track should be made after careful consideration of energy needs, local conditions, and financial goals.
Solar trackers can be a good investment for you by knowing all the factors that are explained in detail. While they offer benefits such as increased energy efficiency, reduced energy costs, and quicker return on investment, they also come with drawbacks like higher initial costs and maintenance requirements.
