mAh Explained: What Milliamp-Hours Tell You About Battery Capacity
mAh, or milliamp-hours, measures electric charge: how much current a battery can theoretically deliver over time. It does not directly tell you stored energy, charging speed, or maximum output current. To compare batteries with different voltages or estimate runtime, convert mAh to Ah and then to watt-hours using the battery's nominal voltage.
Battery labels often place a large mAh number beside voltage, watt-hours, or output ratings, which makes the figures easy to mix up. The useful question is not simply whether one battery has more mAh. You need to know what mAh measures, how voltage changes the energy represented by that number, and how losses and load behavior affect the runtime you actually get.
What Does mAh Mean on a Battery?
The mAh meaning on a battery label is milliamp hours (milliamp-hours), a unit used to measure electric charge capacity. It tells you how much charge a battery can theoretically deliver over time.
So, what is a milliamp hour? One milliamp-hour (1 mAh) represents a current of 1 milliamp flowing for one hour. For example, a 5,000 mAh battery could theoretically provide:
500 mA for 10 hours
1,000 mA for 5 hours
These examples illustrate how battery capacity relates to current and time. Actual performance depends on the battery and operating conditions.
Since 1,000 milliamps equal 1 amp, 1,000 mAh = 1 Ah.
In general, a higher mAh rating means a battery can store more charge and potentially power the same device for longer. However, mAh alone does not indicate charging speed or the maximum current a battery can deliver.
How Do mAh, Ah, and Wh Relate?
mAh and Ah both measure battery charge capacity, while Wh measures stored energy. The difference is that Wh also accounts for the battery's voltage.
Unit |
What It Measures |
Key Relationship |
mAh (milliamp-hours) |
Charge capacity, commonly used for smaller batteries |
1,000 mAh = 1 Ah |
Ah (amp-hours) |
The same charge capacity, expressed in a larger unit |
1 Ah = 1,000 mAh |
Wh (watt-hours) |
Energy stored in a battery |
Wh = Ah × Voltage (V) |
For example, two batteries can both have a capacity of 5,000 mAh (5 Ah) but store different amounts of energy:
At 3.7 V: 5 × 3.7 = 18.5 Wh
At 12.8 V: 5 × 12.8 = 64 Wh
Both batteries have the same charge capacity, but the higher-voltage battery stores more energy. Therefore, the mAh unit is useful for comparing batteries at similar voltages, while Wh provides a better comparison of stored energy across different voltages.
How Do You Convert mAh to Ah and Wh?
Converting mAh to Ah and Wh takes two simple steps. You only need the battery's mAh rating and its nominal voltage (V).
Step 1: Convert mAh to Ah
Divide the mAh value by 1,000.
Ah = mAh ÷ 1,000
Step 2: Convert Ah to Wh
Multiply the Ah value by the battery's nominal voltage.
Wh = Ah × V
For example, let's convert a 20,000 mAh battery rated at 3.7 V:
mAh to Ah: 20,000 ÷ 1,000 = 20 Ah
Ah to Wh: 20 × 3.7 = 74 Wh
The battery therefore stores approximately 74 Wh of nominal energy. By comparison, the BLUETTI Elite 10 offers 128 Wh of capacity, providing about 73% more stored energy, along with 200 W AC output. For weekend trips or short power outages, this combination makes it a practical option for charging electronic devices and powering compatible small plug-in appliances that a USB-only power bank cannot support.
- 200W AC Output / 128Wh Battery Capacity
- 10ms UPS for Seamless Backup
- 6 Output Ports for Multiple Devices
- Full Recharging in 70 Minutes
- 3,000+ LiFePO₄ Battery Life Cycles
Here are more examples for comparison:
Battery Capacity |
Nominal Voltage |
Capacity in Ah |
Energy in Wh |
10,000 mAh |
3.7 V |
10 Ah |
37 Wh |
20,000 mAh |
3.7 V |
20 Ah |
74 Wh |
10,000 mAh |
12.8 V |
10 Ah |
128 Wh |
Important: Always use the battery's nominal voltage when converting mAh to Wh. If the battery already lists its capacity in Wh, no conversion is needed.
Why Does Advertised mAh Differ From Usable Charging Capacity?
The advertised mAh rating usually refers to a battery's nominal capacity at its internal voltage, not the amount of charge delivered through its USB output. The usable capacity differs mainly because of voltage conversion and energy losses.
For example, consider a 20,000 mAh power bank with a nominal battery voltage of 3.7 V:
Stored energy: 20 Ah × 3.7 V = 74 Wh
Usable energy: 74 Wh × 85% = 62.9 Wh
Equivalent capacity at 5 V USB output: 62.9 Wh ÷ 5 V × 1,000 = 12,580 mAh
This means a power bank advertised at 20,000 mAh might deliver approximately 12,580 mAh at 5 V, assuming 85% conversion efficiency. The actual figure depends on the device and charging conditions.
In short, the advertised capacity is measured at the battery's internal voltage, while the usable output depends on the output voltage and conversion efficiency. A lower USB-side mAh figure does not necessarily mean the battery's advertised capacity is incorrect.
How Can You Estimate Battery Runtime From Its Capacity?
Battery runtime depends on the energy available in the battery and the power your devices consume. To estimate how long a battery will last, use this formula:
Runtime (hours) = Battery Capacity (Wh) × Usable Energy Factor ÷ Average Power (W)
For example, suppose your router and LED lights consume 50 W combined, and 85% of the battery's rated capacity is usable after conversion losses.
Take the BLUETTI Elite 30 V2 as an example. With a battery capacity of 288 Wh, its estimated runtime would be:
288 × 0.85 ÷ 50 = 4.9 hours
- 30dB Quiet Operation at 200W
- 10ms UPS Response Time
- 8 Ways to Recharge
- 3,000+ Life Cycles to 80% Capacity
- Ideal for Daily Use and Outdoor Adventures
If you use the BLUETTI Elite 100 V2 to power the same devices, its larger 1,024 Wh battery would provide an estimated runtime of:
1,024 × 0.85 ÷ 50 = 17.4 hours
- Easy-to-Carry: Only 25lbs with a 17L design and hidden handle
- 4,000+ Life Cycles to 80% Capacity
- Lightweight and Portable (Only 25 lbs)
- Ideal for Camping and Home Backup
These examples show why runtime matters when choosing a portable power station. A compact model may be sufficient for short interruptions, while a larger battery provides longer backup for the same devices. Actual runtime will vary with power consumption, conversion losses, temperature, and battery condition.
mAh tells you electric charge, not complete battery performance. Use mAh for like-for-like comparisons at similar voltage, convert to Ah by dividing by 1,000, and use Wh = V x Ah when you need energy or runtime. Keep output power, charging speed, usable energy, and maximum current as separate specifications. For larger battery systems, Wh and W usually provide clearer planning information than mAh alone.
Frequently Asked Questions
Typical capacity is an average or expected production value, while minimum capacity is the lower value the manufacturer commits the battery to meet under specified test conditions. Manufacturing variation means individual cells are not identical. For conservative runtime planning, the minimum figure is safer when it is available, especially after allowing for conversion loss and aging.
