Camping is no doubt a favorite experience for most outdoor enthusiasts. And one type of camping you should try is glamping. Glamping uses luxurious amenities like power stations, glamping tents, and high-quality chairs. This article looks at 12 DIY glamping ideas you can employ in your next trip.
1. Use a Glamping Tent
If you are looking for the most authentic glamping experience, you’ll have to get a glamping tent. They are spacious, appealing to the eye, and of high quality. As you’d expect, they come in different sizes and shapes.
One aspect you need to consider when buying a glamping tent is the material. A typical glamping tent has robust poles, thick guy lines, and industry-standard material, serving you for many years. So, make sure to check out the material before making a purchase.
Another aspect to consider is the tent’s size. Think of how many people will be glamping with you. Larger tents are spacious and have a high ceiling, allowing you to accommodate many people. That said, you don’t want to buy a very large tent as this will require more space to install. Besides, carrying it can be a daunting task.
Other factors to consider include waterproofing, ease of setup, flame protection, and tent type.
2. Use a High Quality Source of Power
While there are several ways to power your devices when glamping, you’d want to use a power source that can serve you for an extended period. Notable examples include generators, power stations, or conventional batteries. But you don’t want to use a source limiting how many devices you can connect or charge.
This is where a robust power station comes into play. Power stations are quiet when operating, portable, and easy to use. Furthermore, they allow you to charge several devices simultaneously. And BLUETTI has some of the most reliable power stations ideal for glamping.
Here are a few you can use during your next camping trip.
BLUETTI AC200L Portable Power Station | 2,400W 2,048Wh
A portable and lightweight power station, the BLUETTI AC200L provides ample energy to power appliances when glamping. Whether you want to power a mini-refrigerator, water heater, or a large electric cooker, this power station has you covered. It has a 2,048Wh capacity, serving you for days or weeks depending on the appliances.
And you are not limited to one charging method, instead, you can choose between the six methods including AC, solar, and a generator. Smart control via Bluetooth and WiFi will only bolster your glamping experience. It is quiet, meaning you can use it in the glamping tent.
This is yet another power station you can use when glamping. It features 11 output ports allowing you to connect multiple devices simultaneously. The nimble yet high-efficient power station provides four recharging methods such as AC, solar, car, and a generator. As you can see, you are not limited to a single recharging method.
What sets the BLUETTI AC180 is its fast charging capacity. It can charge from 0% to 80% in 45 minutes. Using the power station allows you to Leave No Trace when glamping since it is eco-friendly and offers a clean source of power. If you are looking for a cost-effective power station, this is the power station for you.
BLUETTI AC2A Portable Power Station | 300W 204Wh
Finally, you can bolster your glamping experience by buying this portable power station. It has a 204.8Wh capacity, which is ideal for running most devices and appliances. And thanks to the 600W
powerlifting mode, you can connect medium appliances with ease. And thanks to the 270W turbo charging, it recharges from 0% to 80% in 45 minutes.
Like other BLUETTI portable power stations, you get four recharging methods including a lead battery, AC, solar, and a generator. You also get a smart control app so you can monitor and control from the comfort of your glamping bed.
3. Use a Glamping Bed or Mattress
Glamping is not about using a thin camping mat, rather, you want to use a comfortable bed or air mattress. Since glamping tents are spacious, you can use large beds or air mattresses. When choosing a glamping air mattress, you need to consider the price since they are more expensive than conventional camping mats.
Also consider the size and weight. Ideally, you want to buy an air mattress that is easy to use and carry. That said, you don’t want to buy a lightweight option that compromises quality. Other factors to consider include the speed of inflation, thickness and height of the mattress.
4. Use Fancy Lighting
If you want luxurious glamping use fancy lights inside and outside the tent. You don’t want to use a flashlight or harsh white light. Instead, use LED fairy lights. Not only are they appealing to the eye but are also energy-efficient. You can also hang lanterns around the glamping tent to create an ambient surrounding.
5. Consider Luxurious chairs
You don’t want to sit on chairs that cause you to get numb or place your cup on the ground. Ideally, it should be stylish, comfortable, and practical. You also need to consider quality and functionality. It should have a cup holder, a relaxing sitting height, and a comfortable back rest.
You may also consider portability. That is, choosing a foldable chair for seamless transportation. If you want more luxury choose chairs with wooden armchairs and cotton seat covers. Alternatively, you can use soft furnishings such as cushions. This will give your tent a more homely experience.
6. Cook Delicious Food
One way to bolster the glamping experience is to cook delicious food and share it with your friends or family. As you’d expect, you want to cook food that you rarely eat.
Preparing BBQ is one of the best glamping food recipes. The aroma and taste awakens your taste buds, especially if you grill sausages and burgers. Whether you are glamping in your backyard or campsite, this recipe is a perfect bet.
Preparing a yummy picnic food in your backyard or campsite. Your imagination is the limit. Whether you want to prepare yummy smoothies or sprawling salads, you can cook just about anything.
7. Enjoy Unique Entertainment
Glamping can also involve engaging in games rather than just sitting down. And there are many entertainment ideas you can adopt.
One entertainment idea is stargazing. Let’s face, rarely do we get the time to enjoy the star-filled skies. Glamping allows you to enjoy watching stars with your friends and family. And if you have apps that show different constellations, you can use this opportunity for learning purposes.
Another ideal game is treasure hunting. The best part is you can play it with your kids, especially during a sunset. But that’s not all, a movie night with friends will surely brighten the mood in your glamping tent.
8. Use Food Jars As Wine Glasses
While you can take normal wine glasses to your glamping site, using washed food jars significantly bolsters the glamping experience. Sturdier and spacious, they allow you to sip your wine for an extended period.
Furthermore, they have lids, meaning you can carry the wine when going for a stroll or hiking.You can even go further and choose food jars with appealing colors.
9. Bring Battery Powered and Scented Candles
Want to bring that romantic vibe? Why not use scented and battery powered candles. The scent they produce combines naturally with luxurious lights. And since they are battery powered, they do not produce gasses that can damage your glamping experience. There are many to choose from and come in different scents and sizes.
10. Use AC/Heating to Keep Yourself Warm
You don’t want to go glamping in a cold tent. While glamp tents are made of high-quality and thick material, they cannot keep off cold entirely. This is where a heater or AC comes into play. The best part is there are portable units, meaning you can transport them with ease. Don’t overheat your tent, otherwise, your glamping experience will be poor.
11. Bring an Eye Mask and Ear Plugs
If you want to sleep soundly, you can use an eye mask or ear plugs. The eye mask blocks out light in your tent while the ear plugs block noise from your surroundings. And you don’t have to break the bank to get practical options. The eye mask should be soft on your eyes while the ear plugs should fit your ears comfortably.
12. Don’t Forget an Extension Cord
While a rarity with most campers, an extension cord allows you to connect different devices and appliances from a single source of power. Whether you want to power the LED lights or a projector, an extension cord got you covered. Consider the plug configuration, size, code designations, and power requirements.
Glamping, unlike conventional camping, requires you to use luxurious devices, equipment, and appliances. It provides a homely experience from your background or a campsite. Use a power station as your source of power. Should you need one, consider buying from BLUETTI.
