Solar Powered Generators
Solar generators, like our AC200L are a great source of backup power for all sorts of outdoor trips.
They are light and portable, allowing you to charge and run various electronic devices via renewable energy.
Plus they are eco-friendly and unlike conventional generators, do not require you to keep loads of fuel on hand.
With all this being said, the question remains: How exactly does a solar generator work?
A solar generator works by collecting solar energy through solar panels and then storing that energy into its built-in solar battery. An inverter then converts that energy into alternating current (AC power) before it is released for use in home appliances and other electronical devices. When combined, these three components make a fully functioning solar generator.
What is a solar generator?
ac200 solar generator for camping
Ultimately, the term solar generator can actually be referred to any technology capable of being powered by the sun’s energy.
However, most commonly, when people use the term solar generator, they are more often than not referring to a portable power station set up, like the ones we sell at Bluetti Power.
These special systems are capable of capturing the sun’s energy via integrated solar panels, which then transport said energy to an internal storage system (usually comprised of lithium-ion technology).
Solar generators may not always be the right setup for large homes however, they can be extremely useful for boats, campervans, or as an emergency backup if your area experiences a blackout.
how does a solar generator work
Battery: A solar generator needs to store the energy it collects from the sun in order for you to use it at a later stage. The battery functions as the storage unit.
Charge controller: Is a vital component of the solar generator, its main purpose is to protect and promote the durability of the battery. Charge controllers usually have various features for charging and discharging based on the certain type of battery and solar panel combination that you are using.
Inverter: This component converts the low direct current (DC) from the battery to alternating current (AC) which can be used to power your everyday household items.
You can read this article to further understand the differences between AC and DC power.
Why solar generators are essential?
Having backup power at your home is becoming more and more essential, as each year a larger percentage of our population rely on these technologies to survive and to stay connected with the rest of the world.
Solar generators are not only used to power smaller appliances like fans, medium sized refrigerators and air conditioners, but they are also useful to provide essential backup power for critical medical devices such as CPAP machines and other at home health monitors.
Solar generators vs gas generators
While fuel generators may work in many of the previous instances mentioned before, they have quite a few drawbacks:
  • Polluting
  • Noisy
  • Rely on fuel
  • Heavy
When you find yourself in an emergency situation like a blackout, hurricane, or flood, it may be quite hard to access any sort of fuel source, this essentially renders your gas generator useless.
Costs of a solar generator
The cost of your solar generator largely depend on the brand and specifications. In general, generators that are able to produce and store more power usually cost more.
The simple reason for this is thanks to the three internal components. The charge controller, inverter and solar battery.
By far the most expensive part of a solar generator is the battery.
What many people don't realize is that lithium really only makes up a tiny part of the battery itself.
In fact the most expensive component of a lithium battery is the cobalt, which acts as the negative cathode of the battery.
Cobalt is alot harder to get than lithium, this is mainly because the metal is mined as a byproduct of other metal mining operations.
See below the price of our solar generators based on the power capacity:
Model Power Price
AC20 200Wh/120W $229,99
AC30 300Wh/300W $299,00
AC50S 500Wh/300W $429,99
EB150 1500Wh/1000W $1099,00
AC200P 2000Wh/2000W $1799,00
5 Benefits of using a solar generator
1. Free clean energy from the sun
2. Low maintenance costs
3. Quiet and clean operation
4. It’s an investment opportunity
5. Light and easy
Should you buy a solar generator?
If your main aim is to power smaller appliances like the ones found on boats or campervans, then a solar generator might just be the perfect choice for you. Given how easy they are to transport and operate, solar generators offer a unique energy solution for those who find themselves on the move in need of extra electricity.
With that being said, there are some drawbacks such as the limited power capacity, slow recharge time, and reliance on the sun. All of which limit the usability of the technology as whole home backup power systems.
For those of you who are interested in a backup energy supply from a renewable power source, we recommend installing a rooftop or ground mounted solar system with a home battery system attached.
What is the best battery for a solar generator?
Batteries used in solar generators are typically made with one of three chemical compositions: lead acid, lithium ion, and salt water. In the majority of cases, lithium ion batteries are the best option for solar powered generators, though various other types of batteries can be more affordable.
1. Lead acid
Lead acid batteries have been used in off-grid applications for decades, making them one of the most tested battery solutions. While they do indeed have one of the shorter life spans than other battery types, they are one of the cheaper options currently on the market.
2. Lithium ion
Lithium ion batteries are lighter and more compact than lead acid batteries. They also last much longer when compared to their lead acid counterparts. The one downside to lithium ion batteries is their high price. However, the cost is justified in the long term as they will eventually pay for themselves.
3. Saltwater
Unlike other the other battery storage options, saltwater batteries do not contain any heavy metals, relying instead on salt electrolytes. Lead acid and lithium ion batteries need to be disposed of with a special process, a saltwater battery however, can be recycled easily. Due to it being a fairly new technology, saltwater batteries are largely untested, and the one company that makes these batteries Aquion filed for bankruptcy in 2017.
Solar power generators are a smarter alternative to traditional gas powered generators, they are fume-free and quiet.
They produce no harmful emissions, and can reduce your carbon footprint and enable flexible indoor/outdoor operations.
We recommend checking out our large selection of solar powered generators, you can do so in our shop here
Alternatively you can read our article covering the most powerful solar generators here.
