Are you a travel vlogger? Do you create video content to share with an audience on social media? It’s a special lifestyle replete with lots of travel, and sight seeing often away from electrical outlets. And the constraint of batteries, adapters and the limit of outlets could hold you back from some videos you want to shoot.
But you don’t have to live with the hassle and constraints anymore. Now you can open the door to a world of limitless possibilities for the perfect shoot. Farther and longer out.
It’s possible thanks to off-grid, portable solar gear for individuals. You can do so much more with solar gear, plus you can save money and feel great about becoming more eco-friendly. One great way to do that is with a portable solar generator.
So how can you use a portable solar generator to expand your career as a travel vlogger? Read on to see how.
The Survivalist Travel Vlogger: Going off the Grid
If you are a travel vlogger, you may not realize how important it is to have a portable solar generator. A lot of people make the mistake of assuming that just because they are in a place with electricity, they do not need one. But as any experienced traveler knows, there are plenty of situations where it is not always so easy to charge your devices — or even find an outlet at all!
If you are unfamiliar with portable solar generators, they are portable power generators that run on solar energy instead of fuel. They come with multiple USB ports so you can charge multiple devices at once and even have enough juice to power small appliances like lamps and fans. The reason they are so helpful is that they allow you to use your devices without having to worry about finding an outlet — something that could be difficult or impossible, depending on where you are.
While some people may think that a portable solar generator is just an expensive toy for the rich and famous, it can be a practical tool for virtually every vlogger. From charging camera batteries to keeping your phone going on long hikes, this device is essential for any travel vlogger.
The best upside to portable solar generators is that they are noiseless. This lets you record videos for your vlog without worrying about background noise.
What a Portable Solar Generator Could Power for a Travel Vlogger on the Go
Here are some common devices that make perfect sense as to why any travel vlogger should consider powering with portable solar generators:
Drone
There are a number of gadgets and devices that a travel vlogger can power with a portable solar generator. The first on the list is the drone.
A drone is one of the most popular gadgets for travel vloggers today. This small yet powerful device can capture amazing aerial footage from above, making it perfect for capturing stunning videos and photos during travels that would otherwise be impossible to get with a regular camera.
However, drones need a lot of juice so that they can fly for a long time without their batteries dying. This is where portable solar generators come in! A portable solar generator is an easy way to power your drone because it does not require much effort on your part. All you have to do is place the device in the sun and let it charge for a few hours.
DSLR Camera
The DSLR camera is the most powerful tool in a travel vlogger's arsenal. It allows you to capture high-definition video and photos, which can be used for your travel vlogs for social media platforms. These cameras can be expensive, so it is vital to pick up a portable solar generator to keep it charged while on the go.
DSLR camera batteries are usually lithium-ion and can last anywhere from two hours to six hours. However, this means you will have to stop shooting during the day if you want to use your camera at night. A portable solar generator can help you charge your DSLR all day long while on the road to continue creating content during your travels.
Lighting Gear
If you are shooting at night or in low-light conditions, having a good light source is essential for creating high-quality content. This can be accomplished using a portable solar generator and some good lighting gear. For example, if you are filming at night, your lights should have rechargeable batteries that you can charge up during the day using your portable solar generator.
Portable solar generators can power many types of lighting, from portable LED lights to studio-quality lights. Just make sure that whatever lights you use are compatible with the portable solar generator's wattage output.
Smartphone
The most obvious gadget a travel vlogger needs to power is their smartphone. It is the most important tool for making short videos, travel vlogs going live, and communicating with your fans and followers while on the road. However, like other devices, smartphone batteries are notorious for not lasting long enough, especially when trying to capture all of your adventures.
A portable solar generator can provide a constant source of energy for your phone, allowing you to maintain your connection to loved ones and the outside world. For example, if your phone dies while hiking in the woods and you have no way to charge it up again, having a portable solar generator allows you to get back up and running.
Laptop
A laptop is another device that travel vloggers need to charge. This is because it is often used for editing travel vlogs and photos and streaming on platforms like YouTube Live. However, laptops use a lot of energy — especially if they have large screens and high-performance components. If you are going to be away from an outlet for long periods, it is important to ensure that you have enough power to keep your laptop running smoothly and safely.
You may get by with just one battery pack, but most laptops need two or three batteries to operate at full capacity. A portable solar generator can be a better alternative by giving you unlimited access to power your laptop while you are in an area with no available power outlets. Connecting your laptop to a portable solar generator and allowing the sun's energy to power your device will spare you the trouble of constantly swapping out the auxiliary battery packs.
Pocket Wi-Fi Device
A pocket Wi-Fi device is one of the most popular gadgets to have on hand while traveling. This device allows you to stay connected while traveling to other countries. These devices will allow you to stream videos, download movies and send emails while you are away from home.
The only downside to this type of device is that they require electricity to charge up their batteries and power the device itself. If you want to use your pocket Wi-Fi device while traveling, a portable solar generator would be perfect for powering these devices. You can place the hotspot on top of the portable solar generator and let it charge up while you take care of other tasks around camp or at home base.
Portable Solar Generator for Travel Vlogging: What to Look For!
There are so many models on the market that it can be challenging to figure out which will work best for your needs.
Here are some things that you should keep in mind when shopping for a portable solar generator:
Portability
The portability of a portable solar generator is one of its most important features. If you travel often, then you must carry an easy-to-handle device with you. The portability of a portable solar generator mainly depends on its weight, size, and design of the handle. You can choose a portable solar generator that is lightweight, small in size and has a comfortable handle so that you can easily carry it around in your backpack or bag while traveling.
Multiple Power Outlets
Another factor that you should look for in a portable solar generator is multiple power outlets. The more outlets available in your portable solar generator, the better it will be for your use. You can charge multiple devices at once with this generator rather than having to charge them one by one through USB ports or other types of adapters used by other generators with limited outlets.
Battery Capacity
The battery capacity is also an important factor that needs to be taken into account when selecting a portable solar generator for your device charging needs. The bigger the battery capacity, the higher its cost. It will also be more efficient at charging devices faster without having any problem with power fluctuations or voltage drops during the device charging time.
So, if you are looking for a portable solar-powered generator for charging your smartphone or tablet multiple times along with other devices during outdoor trips, choose one with at least 2000Wh battery capacity so that it can provide enough charge to run your devices multiple times without any hassle.
Heat Dissipation Technology
One of the core features of a portable solar generator is its ability to dissipate heat efficiently. If you do not have a cooling system installed in your device, it might overheat and stop working after some time due to excessive heat production by its internal components like batteries and semiconductors. To prevent such issues, you need to choose a model with an efficient cooling system installed inside its case – such as smart temperature-activated fans that can ensure your portable solar generator does not overheat.
Durability
It is imperative to look for durability in a portable solar generator because it matters a lot when it comes to traveling and camping. You do not want something that will break down quickly because it would be useless for your purposes. A good portable solar generator should withstand elements and high winds without losing functionality or breaking apart easily.
Therefore, look for something that is durable enough so that it does not stop working easily even if you use it heavily during your trip or camping trip. If possible, try to find customer reviews about the product before buying so that you know more about its durability level and quality standards before buying it for your next trip.
The warranty offered by a brand on their product is one of the most important factors to consider before buying any electrical device. You might think it is unnecessary when purchasing something as simple as a portable solar generator, but it is!
If you are using the product outdoors or in some remote location where there is no electricity source around, then it is highly likely that something might go wrong with your device since you are only relying on a portable solar generator now. Having at least a 2-year warranty on your purchase can save you from a lot of trouble and headaches later down the line.
Plan Your Next Trip
All in all, if you are thinking of purchasing a portable solar generator and you travel frequently, our products are worth the investment. There are plenty of reasons to buy a portable solar generator for your next trip! And if it doubles as an emergency power kit – that’s a bonus!
