What Size Solar Battery Charger for the Boat?
Outdoor Usage
17/10/2023
Do you love long boating trips? It's great fun until your boat's battery runs low. Suddenly, the fun is gone; there's no power to connect with the outer world or at least enjoy a chilled beer. But you can avoid such a situation with a solar battery charger for your boat.
Buying a solar battery charger may be challenging. You must select the right charger and solar panel size for optimal performance. Besides that, understanding solar chargers' features is crucial to make a sound purchase. This guide covers everything on solar battery chargers for boats; it'll help you choose the best solar charger and the best compatible solar panel for your boat.
Types of Solar Battery Charger for Boat
boat
We've categorized solar battery charger types into three broad categories. You will easily know what type will cater to your needs. There are numerous brand options and models in each category available.
  • Trickle Solar Chargers
Trickle charging is used to avoid battery drain when the battery is unused. A constant low current is supplied to the battery at a slow charge rate. The battery stays optimally charged without getting overcharged. Trickle solar chargers are small solar panels directly connected to the battery.
When your boat is parked or its battery is unused, as happens during long trips, a trickle solar charger maintains the battery's charging level. It makes the boat's battery reliable and minimizes power loss risk.
  • Light-use Solar Chargers
This category includes portable chargers that charge low-power DC electronics like phones, coffee machines, etc. If the boat's battery capacity is insufficient for your power needs, you can have a portable solar charger onboard.
Light-use solar chargers are used as an additional power source. They’re more like a live power bank that you can use to charge different electronics.
  • Heavy-use Solar Chargers
Heavy-use solar chargers combine high-conversion solar panels that charge boat batteries. Most modern boats and luxury yachts have these chargers that can power an entire boat, including electrical appliances, equipment, and devices.
Heavy-use solar chargers have built-in regulators to monitor and control the power supply. These regulators keep batteries safe from overcharging and surge currents.
Features of a Solar Battery Charger for Boat
boat
Before going on the hunt for a solar battery charger, you must know what features to look for. Here are the top features that enhance the charger’s performance, durability, and longevity.
Regulator & Monitoring System
Built-in regulators and monitoring systems are two essential features that enhance solar charger's performance. A regulator keeps the power supply to the battery in a safe range; it helps avoid overcharging or overcurrent/overvoltage issues that may affect the battery's health.
Whereas a monitoring system keeps the user in control, it provides essential information like power input, charging time, etc. Usually, this information is displayed over the boat's control panel; the charger's monitoring system would be helpful if it's unavailable.
Waterproof & Reinforced Panel
The solar panels that come with the charger must be marine-grade or waterproof. Most solar panels are only water-resistant, and when they’re exposed to water for longer periods, their PV cells deteriorate. It’s better to choose marine-grade panels to ensure longevity.
Moreover, the solar panel's glass must be reinforced and UV-resistant. The marine environment is harsh for regular glass. It either gets cracked or turns pale. Choosing a suitable solar panel is better to avoid performance and durability issues.
Installation & Adjustments
Always check your boat configuration and choose solar chargers accordingly. Selecting flexible chargers is better because they're easily installed on curved surfaces. Some chargers are easy to install and have mounting hardware, while others do not.
The solar charger must also have an adjustable tilt for better sunlight coverage. When installing a solar charger, you should be mindful of wind resistance. These considerations are crucial to prevent issues later.
Expandability & Compatibility
Solar chargers are expensive; you should check for expansion options, and your power needs may grow. If you install more battery packs, the charger should have the option to add more solar panels to increase power capacity.
Compatibility is also crucial when selecting solar chargers. Ensure the charger matches your boat's battery type and voltage requirements.
What Size Solar Panel Do I Need for a Boat?
solar panel
Solar panel size mainly depends on your boat's battery capacity. You should also consider other factors to accurately determine the right solar panel size. Here's the step-by-step guide to go with:
  • Calculate Energy Consumption
Your daily energy consumption in watt-hours helps determine the right solar panel size. It helps estimate how much power you'll ideally need. Energy consumption is the usage of different equipment in hours multiplied by their rated power. For instance, if you use 12 watt LED light for five hours a day, the total energy consumed will be 60 watt-hours.
The solar panel's output is also rated in watt-hours. A 200-watt solar panel will provide approximately 800-1500 watt-hours per day. Hence, you can determine the size of your panel based on your daily energy consumption.
  • Estimate Sunlight Hours
Sunlight hours are the time during which the solar panel generates electricity. The solar panel's output depends on sunlight. If you estimate the sunlight hours in your region, you'll know how much output a panel will provide you.
When estimating sunlight hours, you'll include provisions for rough weather conditions and other factors affecting solar output. It'll help you estimate sunlight hours more accurately.
  • Battery Capacity
The solar panel will also charge your boat's battery. The solar output must be enough to power the equipment and charge batteries simultaneously. A 100 Ah battery will need 800-1000 watt-hours for full charge. You can check your boat's battery capacity and estimate the power required to charge it.
A slight miscalculation can leave you without water. You must accurately calculate the power needed to charge batteries to prevent issues.
Make sure to follow these steps before determining the size of the solar panel for your boat. Try to select the panel rated at least two times more than your daily power consumption. In case you've miscalculated, there won't be a problem. Plus, you'll have peace of mind and extra power at your disposal.
Benefits Of Solar Battery Charger For Boat
Solar battery chargers are comparatively more advantageous than conventional power sources used on boats. Here are the key benefits that solar chargers offer:
Cost-saving
Solar chargers are a one-time investment. Solar energy is free to use. There are no fuel costs or other expenses associated with solar chargers.
Maintenance-free
Solar chargers don’t require any maintenance except for the solar panels that need to be cleaned occasionally.
Environment Friendly
Solar chargers have zero emissions. They help protect marine environments as they're clean and quiet and harness sustainable solar energy.
Increase Battery Life
Solar chargers increase battery life as they do not overuse battery charging cycles. Unlike other charging methods, solar chargers prevent constant cycling when batteries are charged.
Safe Boating with BLUETTI Solar Power System
Elevate your boating experience with the BLUETTI solar power system. You can enjoy home comfort on your boat with constant access to clean energy. BLUETTI allows you to power all your appliances and equipment seamlessly with a range of portable power stations and battery backups.
bluetti ac200max
Getting started with BLUETTI AC200MAX + 3*PV200, a 2048-watt-hour solar generator kit that comes with three 200-watt solar panels. This solar system will redefine your boating experience. It has built-in batteries to run all your appliances and equipment onboard. The power station has an integrated control panel and is highly portable and lightweight. A smart mobile app can also control and monitor the entire system.
The system has an expandable capacity of  8192 watt-hours; you can expand as your power needs grow. It also supports multi-way recharge; there is no need to worry about changing weather. The system's highlight is the fast-recharge technology— it gets powered in no time.
bluetti ep500
Next is our power beast, the BLUETTI EP500 + 3*PV200. It has an enormous 5100-watt-hours capacity to power your boat all day long. With an advanced LiFePo4 battery pack, it offers 6000+ charge cycles. The system has next-level portability; it's sleek in design with wheels for easy maneuverability. Taking it on board won't be a problem.
The system comes with three 200-watt solar panels. It has a built-in touchscreen control panel and a smart control option through a mobile phone. The device is like a full-fledged power grid, compatible with both AC/DC appliances. It can also charge your boat's batteries seamlessly while powering your appliances.
bluetti ac180
Finally, our showstopper is the highly compact and powerful BLUETTI AC180 Solar Portable Power Station. It has 1152 watt-hours and can power all your handy equipment and recharge your devices. If you have a small boat, it is space-saving and can fit in your storage compartment. The power station is rechargeable on solar and home supply; it supports fast recharging and gets ready to use within 45 minutes.
The BLUETTI AC180 Solar Portable Power Station has 11 AC/DC ports to connect multiple devices simultaneously. It uses advanced LiFePO4 batteries known for their durability and longevity. All-in-all, this device is the best power source to use during boating adventures.
Solar battery chargers are efficient and reliable compared to conventional chargers. They're safe and don't pose any hazards or fire risk. You can also save money using these chargers and keep the environment clean and green. Next time you go on a boating adventure, install a solar battery charger for added comfort.
