Shop our products
High electricity tariffs are a challenge to any power user, more so during peak hours which are usually very expensive. You may be surprised to learn that by gaining a better understanding of Time Advantage Rates offered by Alabama Power, you may be able to better control your energy expenses. You can also manage your usage patterns to benefit from cheaper rates during off-peak hours. In this post, we will look at these rates in detail, discuss how they apply, and provide some insights on how to manage your energy usage to the best effect. Learn how to make time work for you with Alabama Power.
What are Time Advantage Rates?
Time Advantage is a flexible tariff plan that allows the rates to vary depending on the time of day, the season, and your electricity usage. Like the standard billing rate, Time Advantage also has a monthly base charge added to the cost of the energy consumed.
Another important aspect of Time Advantage is the implementation of the economy pricing periods. These are usually the periods when the consumption of electricity is low for instance in the evening, at night and during the weekends. This enables you to enjoy the power at a cheaper rate than the normal rate during these off-peak hours hence saving a lot of money. Notably, these economy pricing periods can be scheduled to cover about 90% of the hours in the year, thus offering you the best chance to save money.
Time Advantage Pricing Hours
Time Advantage Pricing Hours is an effective pricing strategy that provides customers with a unique method of controlling their energy expenses. In this plan, the electricity tariffs change depending on the time of the day in order to influence the customers to use electricity during off-peak times when the tariffs are high. Normally, off-peak hours are in the evening, at night and during weekends and this comes with considerable saving potential. This pricing model is also useful in cutting down the energy bills and also enhancing the energy efficiency of the grid. Customers can also save on their electricity bills by using electricity intensive items such as washing machines, refrigerators, and dishwashers during the off-peak hours. Consumers who engage in the Time Advantage Pricing plan are able to manage their energy costs better and thus help create a more sustainable energy environment.
What Can I Start Doing to Benefit from the Time Advantage Rate Plans?
The Time Advantage rate plan saves money but it is smart energy management that has to be done. Here are some effective strategies:
Minimize Energy Use During Peak Hours
Emphasis is placed on the conservation or elimination of energy usage during the summer peak period of 1 pm to 7 pm, from Monday to Friday.
Thermostat Settings
During the peak hours, adjust your thermostat to a range of 78-80 degrees to save energy and money.
Optimal Appliance Usage
Some of the big appliances that should be run in the mornings, at night or on weekends include the washer, dryer, pool pump and the dishwasher.
Programmable Thermostat
Programmable thermostat should be installed and used to control the temperature and ensure that it is optimized.
Ceiling Fans
Use more ceiling fans in the rooms to enhance circulation of air and reduce the use of air conditioners.
Water Heater Timer
Install a timer on your water heater so that it does not heat water during peak hours.
Pool Pump Timer
It is recommended to set a timer on your pool pump to switch off during the peak hours to reduce energy consumption.
Stagger Appliance Use
Under the Time Advantage – Demand Rate Plan, avoid using major appliances during peak hours to reduce overall energy consumption and maximize your savings.
What Can I Do to See Additional Benefits from the Time Advantage Rate Plans?
Saving energy is easy, but there are several other ways that you can take to ensure that you save even more energy. Here’s how you can enhance your efforts:Here’s how you can enhance your efforts:
Invest in Energy-Efficient Appliances
Replacing old appliances with energy-efficient ones is one of the most effective ways of cutting down the energy usage. Choose those products that come with the ENERGY STAR logo which ensures that the products have passed the stringent energy efficiency standards set by the U. S. Environmental Protection Agency. Not only do these appliances use less energy but they also usually have extra functions that can be used to save even more energy.
Improve Home Insulation
Improving the insulation of your home is one of the most basic things that you need to do to reduce energy loss. Insulation also makes sure that your heaters and air conditioners run effectively to regulate the temperatures without putting a lot of stress on your HVAC system. Insulate your attic, walls, and floors, and also caulk areas that are prone to air leaks.
Upgrade to Insulated Windows and Doors
The flow of air through windows and doors is one of the main reasons that many homes lose a significant amount of energy. Replacing the doors and windows with new insulated double glazed ones can help to minimize heat exchange between the inside and the outside environment. This not only assists in regulating the indoor climate but also cuts down on the workload of your heating and cooling systems thus decreasing your electricity costs.
Modernize Your Heating and Cooling Systems
Heating and cooling systems that are old may not be as efficient as the new models that are in the market. It is possible to achieve significant energy savings by replacing old systems with high-efficiency ones. Consider units with high SEER for air conditioning and AFUE for heating systems. Maintenance of these systems also helps to ensure that they work at their optimum levels.
How Long Do I Have to Stay Under a Time Advantage Rate Plan?
The Time Advantage rate plan comes with a 12-month service agreement. However, you have the freedom to cancel the plan in accordance with our electric service rules and regulations. If you choose to cancel before the full 12 months is up, then any electricity used after cancellation will be charged at the normal tariff. If the standard rate is higher than the amount you paid for the Time Advantage plan, then you will be charged the additional amount. This policy is fair and gives you the opportunity to take advantage of the Time Advantage plan and still have the freedom to go back to normal rates in the event that the situation changes. Goal of Alabama Power is to offer our customers the best of both worlds: low costs and the ability to make changes.
What Are Peak Hours and Off-Peak or Economy Hours?
Peak Hours
June 1 – September 30: The peak hours are from Monday to Friday, 1 p. m. to 7 p. m., CST.
November 1 – March 31: These times are Monday to Friday from 5 a.m. to 9 a.m. CST.
Off-Peak Hours
All other times, apart from the defined peak hours, are considered off-peak hours. This also encompasses the working, that is weekdays, and the off working days, which are the weekends and holidays, and their rates are cheaper.
Economy Hours
Major holidays like New Year, July 4th, Labor Day, Thanksgiving Day, and Christmas are considered economic hours. If any of these holidays is on Sunday then the following Monday will also be observed as an economy hour day.
Embracing Renewable Energy: How Solar Generators Complement Alabama Power's Time Advantage Rates
However, to enhance the energy management, it is recommended to use Alabama Power’s Time Advantage Rates in combination with solar generators. Solar generators are hence very effective in that they help in cutting the costs of grid electricity and especially in the peak hours. When added to the Time Advantage Rates, the use of solar energy can help to save a lot of money in the long run and make a positive impact on the environment. Here are BLUETTI recommendations for solar power:
BLUETTI AC300+B300 Home Battery Backup
In terms of renewable energy, the BLUETTI AC300 home battery backup is ideal for residents of Alabama. It is compatible with up to four B300 battery packs, with 3072Wh capacity each, so the total backup capacity is 12,288Wh. The AC300 has an inverter of 3,000W AC pure sine wave and a surge capacity of 6,000W. The battery system used is LiFePO4 which guarantees more than 3,500 charge/discharge cycles to 80%.
The features included are 240V split phase bonding and 24/7 UPS home backup. It recharges with seven replenishment options, solar and AC, and a maximum solar input of 2,400W. The sunny climate of Alabama makes the BLUETTI AC300 perfect for managing energy consumption with the help of Alabama Power Time Advantage Rates.
BLUETTI EP500 Pro Power Station
The BLUETTI EP500Pro solar power station is one of the best units in terms of power and features. It has a long lasting LiFePO4 battery of 5,100Wh that can power essential appliances for hours. It has a 3,000W pure sine wave output and 15 outlets to allow for multiple devices to be powered at once.
Its four wheels for easy mobility makes the EP500Pro perfect for home use, or for use on the road, in a car or on a camping trip. Some of the features are a touch panel that is easy to use and an application that can be installed on a mobile device. Designed with ruggedness in mind, it has internet capabilities for firmware update and can do more than 3,500 charges. EP500Pro is a reliable device that can fulfill all your power requirements with great versatility.
BLUETTI AC500 + B300S solar generator kit
The BLUETTI AC500 + B300S solar generator kit is highlighted by 30 amp and 50 amp AC outlets. The AC500 has a surge power of 10,000 watts, which means you can comfortably power your entire home with this device during a power blackout. Its backup power is from 3072Wh to a whopping 18,432Wh, making it capable of powering many appliances.
The generator accepts solar input of 3KW and produces up to 15000Wh per day in ideal conditions. Perfect for blackouts, the BLUETTI AC500 will keep your house well-lit.
To be precise, knowing the Time Advantage Rates of Alabama Power can greatly affect your electricity savings. If you are able to regulate the amount of electricity you use during the off-peak and economy hours, then you will be able to cut down your total costs. To fully grasp these benefits, one has to know the particularity of the peak and off-peak periods that apply to the chosen tariffs. In case you do not feel the plan suits you, note that you can cancel the plan and go back to the normal rates. Use the information provided to make the right decisions when it comes to consuming energy in your home or business.
