Solar Electric Fence vs. Solar Generator Power Electric Fence
09/10/2023
The good news is you can protect your crops or commercial and residential properties by installing electric fences. However, this electric fence may cost you grands. Protecting your crops and stressing over power consumption or electric bills is out of trend now.
One thing you can do to install a cost-effective and eco-friendly electric fence is to use a sustainable energy source. Protect your crops and the environment simultaneously with sustainable energy sources like solar power stations or generators. Now, farmers can install solar electric fences or solar-powered electric fences to assure crop safety against animal or pest attacks.
In this article, we will shed light on what actually solar-powered electric fences are. Furthermore, we will dig deeper into the topic and explore the best BLUETTI solar power generators for the purpose.
What Is a Solar-Powered Electric Fence?
fence
The solar electric fence is an implication of renewable energy sources to protect the crops and contain the livestock within a fence. This ingenious system captures solar energy through solar panels and converts it into electrical energy.
The primary device of the solar power electric fence is a rechargeable battery. As is understood by the name, this device is an energy reservoir. The system stores surplus electricity in this device for later use. Why do we need to store the energy? To ensure uninterrupted power provision to electric fences during cloudy days or at night.
However, the core of the solar electric fence system is a charger, also termed an energizer. The charger is a distributor and regulates the electric flow into the fence. Thus, the system generates electric energy, and the energizer sends off controlled batches of non-lethal current throughout the fence.
If you touch the fence while the energizer is still working, you will get an uncomfortable shock, which won’t be lethal. The purpose is to deter livestock and prevent any unauthorized access to your properties.
Solar electric fences are widely used in agriculture as an effective tool to contain livestock and protect crops. Furthermore, using renewable energy contributes to the environment and addresses electricity issues in remote areas that lack grid electricity.
What Is a Solar Generator for an Electric Fence?
electric fence
Although solar electric fences and solar generator electric fences work alike, there is a minimal difference between them. While the solar electric fence system charges the fences directly, the solar generator electric fence system uses a battery and panel combo to store energy.
This system specifically includes solar panels, a charge controller, battery storage,  and an energizer.
  1. Solar Panel: What is a mango shake without a mango? Likewise, a solar generator system is nothing without solar panels. These panels capture and convert solar energy into electric energy.
  2. Battery: We need to preserve the energy for difficult times, like when sunlight is low or during the night. The battery does this job and stores the electricity for future use.
  3. Charge Controller: Charge controllers prevent overcharging and regulate the efficiency of the battery used in the system.
  4. Energizer or Fence Charger: Energizers pass the pulses of current to the fence to shock any object that comes in contact.
All in all, solar energy is converted into electric energy via the panels. This energy is not sent to the fence right away; rather, it is stored. Then comes the energizer into action, draws current, and sends it to the electric fence.
Again, solar generators are a great choice for remote areas where the concept of electricity is far-fetched. These generators produce sustainable energy, cut costs, and leave less carbon footprint.
BLUETTI AC500 + B300S
Home Battery Backup
Check Discount
Which One is Your Best Choice?
Both solar electric fences and solar generator electric fences utilize solar energy, but they often refer to slightly different configurations or emphases. Let's compare the two to determine which might be the better choice:
Scratching your head over, which should be the best option for your farmland?  Well, Keep reading to make the right decision.
Solar Electric Fence vs. Solar Generator Electric Fence:
Is Quite affordable with its minimal operating cost.
This system generates electricity that can be used for multiple purposes, which implies you can also charge your device!
It needs little attention and is easy to install.
The installation cost of a solar generator may hurt your pocket. However, the durability can compensate for the initial investment.
This system is weather-reliant. You may run out of electric energy when the sky turns cloudy.
The energy production is not weather-reliant, and you can use electricity even when it's pouring or at night.
When choosing between the two, keep in mind the following aspects when making a choice that suits your needs:
  • Usage Needs: If you need an independent energy source only for the electric fence, a solar electric fence is the best fit for you. However, if you need energy for multiple purposes, don’t hesitate to buy yourself a solar generator.
  • Budget: A solar generator has higher installation and maintenance costs than a solar electric fence.  You can choose accordingly.
What Size Solar Generator Do I Need for an Electric Fence?
When selecting the size of a solar generator, consider your daily consumption. You should keep in mind the length of the fence and the amount of energy it consumes. This information will help you choose the product that matches your needs and demands.
Furthermore, you should also take into consideration the usual weather conditions in your town, the availability of sunlight, and the frequency of cloudy weather. You should consult an expert and discuss your requirements before selecting the size of your solar generator.
BLUETTI Top Solar Generators For Electric Fences
bluetti ep500
Fence your crops and contain your animals with the portable BLUETTI EP500 Solar Generator.  This diva comes with a user-friendly smart screen to ensure easy usage.  The multiple charging pots are one of the best features of the BLUETII EP500 solar generator.
Here are the key features of the product
  • 5100Wh LiFePo4/6000+Charge Cycle: The energy storing capacity of this generator is unmatchable. You can store as much as  5100 watts of energy every hour while using this generator.
  • In-grid UPS Mode & Flexible UPS Mode(24/7): Enjoy the uninterrupted supply of home-made electrical energy with this prodigy of solar generator realm.
  • 2000W PSW Inverter: The 2000-watt inverter can convert the solar energy enough to produce watts that will blow your mind! You can use 2000 watts of energy at a time with this 2000W PSW
bluetti ac200p
Need a sustainable energy source that is portable, eco-friendly, cost-effective, and stores a huge sum of energy? Look no further because BLUETTI AC200P Solar Generator comes with multiple mind-blowing features, which are given below:
  • Pure Sine Wave Inverter 2000W AC with 4,800W Surge: Not only that, you can plug in multiple devices at a time; with BLUETTI AC200P, you can also consume and store 2000 watts of energy in a go.
  • LiFePO4 Battery: The battery has a long life. You can charge and uncharge the device 3500 times, and the efficiency will drop only to 80% of its original capacity.
FAQs about Solar Electric Fence
Q. How to Install a Solar Electric Fence?
First, create a boundary to protect your desired area. Run the electric fence through the border. Now, find a sunny place for your solar panels and connect the panels with the charger. Next, connect the electric fence with the charger and test the voltage efficacy.
Q. How Many Watts Does an Electric Fence Use?
The watt consumption per hour can vary with the type of solar generator you deploy and the length of the electric fence. However, on average, the electric fence can consume energy anywhere between 2 watts to 25 watts.
Q. Tips for Safe Use of Solar Generators Power Electric Fence?
The solar panels should be inclined to an angle where there is an increased chance of energy absorption. Furthermore, install solar generators in arid areas where the sun shines bright all the time. In addition to this, you should ground the solar generator properly.
Final Thoughts:
Solar electric fences not only protect your assets but also protect the environment. This source of energy generation directly supplies the electric fence while the solar generator stores electric energy and then passes it on to the fence wires. Thus, the generator makes it safer for you, while the solar electric fence makes it affordable for you to protect your crops.
One can choose between the two depending on your needs and emphasis. For the best solar generator options, BLUETTI products top the list among all the currently available solar generators. You can go visit their website and purchase a product that suits your needs.
If you are looking for a portable, eco-friendly, pocket-friendly, user-friendly generator that can supply multiple devices at a time and store massive energy, try the  BLUETTI Solar Generators
