Portable Solar Generators for Emergencies – All You Need to Know
25/04/2023
During an emergency blackout, you need a reliable power source to run your essential appliances, charge your devices, and stay in touch with the outside world. Portable solar generators are among the best options in that regard and can provide you with clean, reliable energy even in the harshest of conditions.
This blog will tell you everything you need to know about portable solar generators for emergencies.
What Are Portable Solar Generators?
Portable solar generators collect energy from the sun, transform it into usable electricity, and store it in a battery for later use.
Solar generators do not use fossil fuels like conventional generators do. They instead use solar panels to generate electricity, making them a clean and environmentally-friendly source of power.
These generators are available in a wide range of sizes and power outputs, allowing you to choose one that best meets your specific requirements.
How Do Portable Solar Generators Work?
Photovoltaic panels in portable solar generators use light from the sun to generate electricity. Solar panels consist of solar cells that produce power when exposed to sunlight. These panels produce electricity, which is then stored in a battery storage unit for later use.
The battery can be considered the heart of a portable solar generator unit. It stores the electricity generated by solar panels so that it can be used when needed, such as during periods of emergency. These batteries can store a substantial amount of energy and can be recharged numerous times before needing to be replaced.
A portable solar generator's capacity is measured in watt-hours (Wh). A watt-hour is the amount of energy consumed by a device that uses one watt of power for one hour. The more energy a portable solar generator can store in watt-hours, the longer it can keep your devices running.
Benefits of Portable Solar Generators for Emergencies
1)    Eco-Friendly
Portable solar generators are a sustainable alternative to conventional generators since they generate clean energy without releasing toxic greenhouse gases.
2)    Cost-Effective
Although the initial investment in a portable solar generator may be more than that in a conventional generator, its lower operating and maintenance costs over time make it the more economical choice.
Other than that, a portable solar generator can also help you save money on your utility bills, which further compensates for its higher initial investment.
3)    Portable and Lightweight
Portable solar generators are designed to be lightweight and easy to carry, making them perfect for emergency situations that often require swift movement.
4)    Silent
Solar generators make no noise, making them ideal for camping trips or power outages where you don't want to disturb anyone.
5)    Low Maintenance
Compared to conventional generators that need routine oil changes and other maintenance, portable solar generators require extremely minimal upkeep.
How to Choose the Right Portable Solar Generator for Emergencies?
There are several factors you need to consider when buying a portable solar generator for emergencies, with some of the most important ones being:
1)    Power Output
Watts is the standard measurement unit for a portable solar generator's output power (W). Choose a generator that is strong enough to power all your essential devices and appliances.
Make sure to check the wattage needs of the devices you want to power and choose a generator that can meet those needs.
2)    Battery Capacity
Watt-hours help measure a portable solar generator’s (Wh) battery power. As mentioned, the length of time a solar generator can supply electrical power largely depends upon its battery capacity. Therefore, make sure the generator you choose has enough battery power to meet your needs.
3)    Weight and Portability
A lightweight and portable solar generator is always convenient, but these traits become essential during times of emergency. Thus, it is important to look for a generator that is light and easy to move.
4)    Charging Time
A portable solar generator's charging time is the time it takes to fully charge the battery using solar panels or an AC power outlet. The charging time may vary, according to the generator's capacity and the strength of the sunlight. If you need to use a generator quickly in an emergency, choose one with a short charging time.
5)    Durability
If you are buying a portable solar generator for emergencies, it is important to choose one that can withstand harsh weather conditions and rough handling. Pick a generator with a strong build made of long-lasting components.
6)    Added Features
Some portable solar generators have extra features like LED lights, USB ports, and AC outlets. Consider these extra features when selecting a generator, and pick one that offers all the features you think you will require.
Applications of Portable Solar Generators in Emergencies
There are several emergency uses for portable solar generators, including the following:
1)    Powering Essential Appliances
During an emergency, you need to be able to access power for things like your refrigerator, electric stove, and medical equipment. Portable solar generators can keep these things running until the power is restored.
2)    Charging Devices
In times of crisis, maintaining contact with the outside world is essential. Portable solar generators can be used to charge electronics like phones, laptops, and tablets, thus allowing you to communicate with others and reach out for assistance.
3)    Lighting
Portable solar generators can power LED lights, giving much-needed light when the power goes out. This is especially critical during nighttime natural catastrophes and other situations.
4)    Camping and Other Outdoor Adventures
Solar generators are also beneficial for camping and outdoor excursions. They can power your phone, flashlights, and other equipment, enabling you to remain connected and secure in remote regions
5)    Medical Emergencies
During medical situations, portable solar generators can power medical equipment, such as oxygen concentrators, CPAP machines, and nebulizers.
Thus, portable solar generators can be lifesavers, especially if you encounter a medical emergency during a blackout or in a remote region without access to the power grid.
6)    Search and Rescue Operations
Search and rescue operations need power to run their gear during emergencies like natural disasters or accidents. Portable solar generators can equip them with the electrical power essential for their operations.
7)    Emergency Preparedness
A portable solar generator is a crucial piece of equipment for any emergency kit. It can be used to charge your communication devices, emergency radio, and have them all ready for use in the event of an emergency.
Factors Affecting the Performance of Portable Solar Generators in Emergencies
Many factors can affect the operation of portable solar generators during emergencies – and you must know and understand these factors to be able to get the best out of your generator in a crisis situation.
Here are the most essential of those factors:
1)    Weather Conditions
The performance of portable solar generators can be affected by elements like rain, snow, or overcast conditions. Solar panels need direct sunlight to produce energy, and anything that blocks the sun can make the solar panels less effective.
This is why cloud cover can considerably diminish the efficiency of portable solar panels.
2)    Solar Panel Angle and Orientation
It is also important to consider the angle and direction of the solar panels while using a portable solar generator. Where you live and what time of year it is will determine the best angle and direction for the solar panels.
If your solar panels are not properly aligned, they may not receive the maximum amount of sunlight, reducing the solar generator's efficiency.
3)    Battery Capacity
How much energy a portable solar generator can store and how long it can power your devices depends on its battery capacity.  If the battery capacity is insufficient for your power requirements, the generator may be unable to power your devices for an extended period of time.
4)    Device Power Consumption
The power consumption of your devices also has an impact on the portable solar generator's performance. If your devices have high power consumption rates, the generator may not be able to power them for a lengthy period of time.
Thus, make sure to evaluate your power consumption needs before choosing a portable solar generator.
5)    Charging Time
A portable solar generator's performance in an emergency may also be impacted by how long it takes to charge. You might not be able to use the generator when you most need it if it takes too long to charge.
6)    Temperature
A portable solar generator’s battery can operate differently depending on the temperature. The battery’s performance and lifespan may be affected when it is exposed to consistently high temperatures.  Ideally, you should store your portable solar generator in a cool and dry place.
7)    Load Balancing
Load balancing is the process of spreading the power demand across several outlets to keep them from overloading. When the generator is overworked, it loses efficiency and can even damage the battery.
To get the most out of your outlets, it's best to distribute the load evenly.
Common Mistakes to Avoid when Using Portable Solar Generators in Emergencies
Portable solar generators are great to have in emergency situations, but they can also prove to be risky if not used correctly. Here are a few common mistakes you need to avoid while using portable solar generators during emergencies:
1)    Overloading
By connecting too many devices to the generator, you risk damaging the battery and shortening its life. It is crucial to carefully read the manufacturer's instructions and adhere to the recommended load suggestions.
2)    Incorrect Storage
To protect the battery and prolong its useful life, it is important to store the generator in a cool and dry place.
3)    Using Incompatible Devices
Solar generators are sometimes incompatible with certain devices. Before using the generator, make sure to check your devices’ power requirements. Utilizing incompatible devices can damage the generator's battery and shorten its lifespan.
4)    Not Cleaning the Solar Panels
Debris and dirt on the solar panels can diminish their efficiency and impact the operation of the generator. Regular cleaning of the solar panels is essential for maximum performance.
5)    Not Using a Surge Protector
Electricity surges can harm the battery and shorten the generator's lifespan. It is, therefore, essential to use a surge protector to safeguard the generator against power surges.
Portable Solar Generators – a Vital Weapon in Your Emergency Preparedness Armory
A portable solar generator is perhaps the best option for when you need clean and reliable power during times of emergency. These generators can power a wide range of electronics and appliances, and their lightweight and portable design makes them convenient to move about.
By choosing the right generator and using it the right way, you can make sure you have a reliable source of power when you need it most.
If you are looking for a portable solar generator to arm yourself for an emergency, we invite you to check out our wide range of options. We offer different types of portable solar generators, panels, and kits, and can help you choose one based on your budget, location, and emergency power requirements.
Shop Bluetti
