Shop our products
Are you aiming to dive into the intricate world of electrical units? If yes, you are on the right page. Delve right into developing a deep understanding of the basics of electrical units and the conversion of milliamps to amps.
After all, this knowledge is crucial when choosing electrical appliances for your home and dealing with the requisite power required by said appliances.
Understanding Current
Before proceeding, it is imperative to comprehend the basics of an electrical current and its units. All electrical devices function through the mechanism of an electrical circuit in them.
It is in this electrical circuit where an electrical current is typically observed. In it, tiny charged particles - called electrons - flow. Thus, an electrical current is the flow of electrons in an electrical circuit.
These streams of electrons move through a conductor - such as a wire - when attached to a power source or battery. They also move in a specific direction based on whether it is AC (Alternating Current) or DC (Direct Current).
In DC, electrons flow from the positive end to the negative end of the battery. On the other hand, in AC, electrons flow in both directions, from the positive to the negative end and from the negative to the positive end.
Now the question arises: what is the unit attributed to this flow of electrons called current? The answer is Ampere (amp, in short).
Basics of Milliamps and Amps
Now that we know what an electrical current is, it is time to figure out its units.
Ampere/Amps
Unit: An ampere (A) is the standard current unit in the International System of Units (SI).
Strength of electrical current: Ampere is a measure of the strength of the electrical current. A higher amperage denotes a greater strength of the current, while a lower amperage represents a relatively weaker current strength.
Where you find it: This unit is used where there is a lot of electron flow, i.e., for devices where high current is required. Examples include big household appliances, such as refrigerators and washing machines, and larger electronic equipment.
Milliamps
Unit: Milliamps (mA) are a thousandth (1/1,000) of an amp, a much smaller figure than amps. It is akin to a miniature version of Ampere.
Where you find it: Since milliamps are such a minute figure compared to amps, they are used in electrical devices where the electron flow is much lower than in bigger household appliances.
For instance, a calculator, a digital watch, or the tiny LEDs in a gaming mouse are all appliances where you would use the term “milliamps.”
Conversion Methods
Milliamps to amps conversion and vice versa are another crucial piece of information to have in your arsenal when dealing with electrical appliances. There are several methods for this conversion:
1. The Conversion Formula
There is nothing more reliable than knowing the good old formula for milliamps to amps conversion and vice versa. The formula is
- For milliamps to amps: Divide the milliamps value by 1,000 to get the value of amps.
- For example, assume that milliamps = 2,000 mA
Amps = milliamps / 1,000
= 2,000 / 1,000
= 2 A
- For example, assume that milliamps = 6,500 mA
= 6,500 / 1,000
= 6.5 A
- For amps to milliamps: Multiply the amps value by 1,000 to get the value of milliamps.
- For example, assume that amps = 7 A
Milliamps = amps * 1,000
= 7 * 1,000
= 7,000 mA
- For example, assume that amps = 0.5 A
= 0.5 * 1,000
= 500 mA
2. Mental Math Trick
If you don’t have time to do written milliamps to amps conversion, there is a mental trick available to make your calculations easy.
From milliamps to amps: You are essentially shifting the decimal point three places to the left
For example, 1) 900 mA = 0.9 A
2) 80 mA = 0.08 A
3) 7 mA = 0.007 A
To confirm, if you divide the milliamp value by 1,000, you will see that these answers are correct.
3. Calculators
If the figures are too big for manual or mental calculation, there are always calculators available to make your life easy. You can use a basic calculator in physical form or on your desktop.
For milliamps to amps conversion, simply write down the milliamps value and divide by 1,000. Conversely, for amps to milliamps conversion, write the amps value and multiply by 1,000.
4. Online Converters
Why make things difficult for yourself with manual labor when digital devices are there to help? On your desktop, laptop, or smartphone, simply type “milliamps to amps converter” on Google, and voila!
You will find an online milliamps-to-amps converter, where you can type in your mathematical figures and let the device give you the answer. How convenient it is!
Things to Keep in Mind When Doing Calculations
No matter how cautiously you handle milliamps to amps conversion, there are still several things you must never forget. After all, you are dealing with mathematical numbers - one wrong step and all calculations go wrong.
1. Decimal Points
As easy as the milliamps to amps conversion sounds, decimal points, nevertheless, end up causing confusion. Therefore, it is imperative that you remember that milliamps have three decimal places, while amps have only one. You must always pay attention to their positions when converting.
2. Rounding
Normally, small and easy figures do not require rounding off the converted values. However, it may become necessary depending on the context of milliamps to amps conversion.
The context might necessitate the rounding of converted values to a suitable level of precision. So, keep it in mind.
3. Units
It is very easy to get confused between milliamps and amps, especially if the unit is not written with the mathematical values. Therefore, always double-check and clearly indicate whether you are dealing with milliamps or amps.
It will avoid confusion and errors that you could potentially make during your calculations.
Safety Considerations
Dealing with electrical appliances is no child’s play. There are several safety considerations you must keep in mind when handling milliamps to amps conversions and electrical devices.
1. Understand the Context
Knowing the context of the milliamps to amps conversion is extremely crucial when applying the correct conversion and interpreting the result accurately. You should be very clear about what you are dealing with.
Is it power supply ratings, component specifications, or measured current values? Depending on the context, the conversion you have to apply can vary.
2. Avoid Exceeding Component Ratings
You should never forgo the manufacturer’s guidelines on electrical devices' rated current capacity. They always tell you about the safe current limits, and you must make sure to follow them.
Whether you are doing milliamps to amps conversion or choosing a power supply to attach to them, never exceed the component rating. This is because overloading leads them to become overheated, can cause a fire hazard, or can potentially damage the circuit or device.
3. Use Appropriate Tools and Methods
When dealing with easy calculations and quick estimations, you will find mental shortcuts easier. However, for complex figures and critical situations, never rely solely on your own manual work.
Instead, seek out the assistance of online calculators, conversion tables, or scientific calculators. These tools will offer reliable and accurate results while minimizing the chances of errors.
Application
So now that we have understood everything about milliamps to amps conversion, the question is, why was it necessary to learn them in the first place? What is the application of this knowledge?
Well, you might be surprised with how valuable this information is in dealing with your everyday electrical appliances.
For instance, if you purchase the BLUETTI EB3A Portable Power Station for your home, your milliamps to amps conversion information will aid you in several ways.
BLUETTI EB3A Portable Power Station ia a 600W 268Wh has a 600W AC Pure Sine Wave Inverter, i.e., it can provide you 600W of power. Moreover, it has a storage capacity of 268Wh (Watt-hour), and its LiFePO4 battery ensures longevity through its 2,500-plus life cycles until it reaches 80% of its original capacity.
Now, here is how your milliamps to amps conversion knowledge will help you with this power station. Through conversion, you can estimate how long a particular device will run with this power station.
For instance, this BLUETTI EB3A Portable Power Station has a capacity of 268Wh, and assuming an appliance runs at 500 milliamps, the amperage draw will help you estimate its running time.
Similarly, if you purchase the BLUETTI PV200 Solar Panel for your home, your knowledge of milliamps to amps conversion will aid you in utilizing it to its full potential.
The BLUETTI PV200 Solar Panel boasts the utilization of Monocrystalline solar cells, which are famous for their durability and efficiency. Secondly, it has a high efficiency of 23.4%. How tempting it is!
Your milliamps-to-amps conversion knowledge will come in handy when figuring out how much power (in amps) the solar panel will provide under various conditions based on its 200W output and 23.4% efficiency.
Find out how many solar panels you need to go off-grid.
Purchasing the BLUETTI B300 Expansion Battery will test your knowledge of milliamps to amps conversion in another way.
The BLUETTI B300 Expansion Battery boasts a 3,072Wh capacity. With its 100W USB-C, 12V/10A car output and USB-A ports, you can charge several devices with this battery. Isn’t it convenient?
Your knowledge of milliamps to amps conversion will aid you in determining which devices can be safely and effectively charged with this battery. For instance, assuming that a device requires 2,000mA for charging and you can determine that B300’s ports can deliver this, you are assured that they are compatible.
Final Words
So, there you have it. With this knowledge of milliamps to amps conversion in your arsenal, you can now make informed decisions about the electrical appliances present in your home or when you are out buying some remarkable BLUETTI products for your house.
