Make Your Medical Equipment Power Outage Proof: Portable Solar Generators to the Rescue
26/10/2022
Lives hang in the balance when it comes to electricity. Disrupt the power supply and vital medical equipment stops. But did you know that you can harness the power of the sun to generate free electricity that keeps medical running?
While large institutions rely on commercial solar panel installations and equipment, there are a lot of individuals that use medical equipment – as well as mobile clinics and small offices.
In this article, we’ll explore how portable solar generators and equipment can keep life saving treatments running when it matters most.
Uses for Portable Solar Generators in Homes and Healthcare Facilities
A healthcare center is typically bustling, with people coming in and going out. It can also be very stressful for anyone admitted overnight at the clinic. However, there are many things at healthcare centers and homes with patients that portable solar generators can power.
Here are some common medical equipment that portable solar generators can power:
Medical Devices and Equipment
Electric Wheelchairs
Some patients may need electric wheelchairs to get around their room or outside during the day. If their battery dies on them, they would not be able to go anywhere until it is charged again — which could take hours — depending on how much charge was left when the battery died. A portable solar generator would allow them to charge their batteries while out in the sun so they can get around again in no time flat.
Mobile Dialysis Units
Dialysis is a treatment that removes waste products from your blood when your kidneys are not working correctly. It usually involves being hooked up to an artificial kidney machine that does this work for you while you are connected to it by tubes and wires.
Mobile dialysis units are small enough to move around quickly and have wheels that can be rolled from room to room when necessary. They are typically powered by batteries or generators but can also be powered by portable solar generators if necessary.
Portable Ultrasound Machine
Portable ultrasound machines are vital tools for doctors and nurses. They diagnose various conditions, from heart disease to kidney stones.
However, some healthcare units do not have enough power outlets to support their portable ultrasound machines. This can lead emergency room doctors to wait for an available outlet before diagnosing their patient's condition.
Fortunately, there is an alternative solution: portable solar generators. Portable solar generators provide enough power for all devices, including portable ultrasound machines. This means you will never have to wait for an available outlet again.
Patient Monitors
Portable solar generators can also be used to power the portable patient monitors. These monitors are generally small devices used to display a patient's vital signs, such as temperature, heart rate, and blood pressure. They are usually powered by batteries, but portable solar generators can also power them.
The portable solar generators will provide a constant power source so that the patient monitor does not have to rely on battery life. Patients who need constant monitoring will benefit significantly from this technology because it will ensure that they get uninterrupted monitoring.
Defibrillators
Defibrillators are critical machines used to treat heart attacks and other cardiac issues. They provide an electric shock that can restart a stopped heart by sending an electric current through the chest wall (myocardial) muscles.
Defibrillators are often found in healthcare centers, but they do not always have access to electricity or battery power. With a portable solar generator, however, you can provide the power needed to save someone's life if they need immediate attention.
IV Pumps and Infusion Devices
When you think about devices powered by portable solar generators, IV pumps and infusion devices may not come to mind. However, these devices use electricity just like any other piece of equipment. If you have an IV pump or infusion device in your home and you are looking for a way to reduce your electric bill and be more environmentally friendly at the same time, consider using a portable solar generator instead.
Dental Chairs
portable solar generators for medical equipment
Portable solar generators can be used as an alternative power source for dental chairs so that patients can continue receiving treatment even in the event of a power outage or other emergency. Dental chairs are used for procedures such as teeth whitening and dental implants. They are typically used with other medical devices, including drills, ultrasonic scalers, and suction equipment.
Dental chairs are typically powered by electricity from the grid so that they can work properly when they are needed most. However, if the power goes out or there is no power source available, then these devices cannot be used effectively until the problem has been resolved. This can leave any patient who requires dental care out of luck until the problem has been fixed.
Nebulizers
Nebulizers are devices that create fine mist jets of liquid medication and deliver it to the lungs. They treat asthma, COPD, cystic fibrosis, emphysema, and other respiratory conditions. Nebulizers can be powered by electricity or batteries. When powered by electricity, they require frequent recharging, which is impossible in emergency situations where there is no power supply. A portable solar generator can easily be moved around and provide the necessary power to run nebulizers during an emergency so that patients can receive their medication on time.
Other Medical Facilities
Computers
Healthcare centers use computers for patient records to billing services, making them an essential part of daily operations. These computers need constant power to run smoothly without any interruptions or crashes due to a lack of electricity or inefficient energy sources like diesel generators which require regular refueling and maintenance costs over time.
Portable solar generators ensure that the computers have continuous power without interruptions. Moreover, these generators have no maintenance costs since they work without any need for fuel or maintenance other than cleaning off dust buildup occasionally if needed.
Patient Room Lighting
Room lighting systems in healthcare centers are mainly run from grid power sources. However, the lights may not always function correctly or fail during blackouts or other emergencies. A portable solar generator can provide enough light for patients who need it most during these times. The generator will also provide enough light for doctors and nurses who need to treat patients during emergencies or at night when there is no electricity available for their workstations.
Pharmacy Refrigerators
Pharmacy refrigerators are essential for any healthcare center because they store the medicine and other drugs needed for the patients. These refrigerators need to be kept cool, so they do not get spoiled. A portable solar generator can help maintain the temperature inside these refrigerators by charging them with electricity when there is no power available from the grid or another source of electricity supply, such as a battery bank or fuel cell system.
Benefits of Portable Solar Generators for Healthcare Centers
The following benefits make solar generators the perfect solution for healthcare centers and medical facilities.
Reduces Reliance on the Grid
One of the biggest upsides to portable solar generators is they reduce your facility's reliance on the electrical grid. In fact, a study by the National Renewable Energy Laboratory (NREL) found that rural healthcare clinics are particularly well-suited for solar because they are significant electricity users and can be located near suitable land for installing solar panels. This study shows how important the healthcare sector is and thus how solar power can be used to power the facilities in this sector.
Minimizes Downtime Due to Power Outages
Another benefit of using portable solar generators is that they can minimize downtime during power outages caused by weather events, such as hurricanes or other disasters like earthquakes. This has always been one of the main selling points for portable solar generators over traditional models: They do not rely on underground lines and utility poles. So if there is no power from outside sources, you are still good to go with your power production capabilities.
Offers Increased Safety for Patients and Staff Members
Portable solar generators also offer increased safety for patients and staff members compared to traditional backup systems like diesel generators or fuel cells because they do not emit fumes like those sources do — which can contribute to air pollution inside a healthcare center or home. In addition, diesel generators can be loud and disruptive, making it difficult for patients to sleep comfortably or concentrate on their treatment plans during recovery time.
Saves Time
Another benefit of using solar generators at healthcare centers is that they can save time for administrators and staff members dealing with the aftermath of a disaster or emergency. In many cases, the first thing people will want after an emergency is power — especially if they have patients who need medical attention immediately. That is why it is crucial to have backup power in place before something happens so that you do not waste any time trying to get back up and running once everything settles down again.
Reduces Costs
One of the main reasons healthcare centers are looking into portable solar generators is because they want to reduce their overall costs and improve their bottom line — which every business strives for. By reducing their dependence on traditional forms of backup electricity, healthcare centers will save money in the long run by cutting down on fuel consumption from diesel generators and maintenance fees associated with keeping these systems running smoothly over time.
Increases Mobility
When you are in a healthcare center, mobility can be very valuable. You may want to move from one room to another quickly, or you may need to be able to leave the building and go somewhere else entirely. With a portable solar generator, you do not need to run an extension cord across the room or worry about getting tangled up in wires. The unit will always be lightweight and easy to transport with minimal effort.
Supports Green Initiatives
Finally, one of the most important benefits of using solar generators is that they help promote sustainability. As a healthcare provider, you must do everything possible to protect the environment — so why not start with powering your medical facilities with renewable energy sources like portable solar generators?
Thanks to the innovation of solar panels and portable generators – you can keep vital medical equipment running. In spite of power outages and if you’re off-grid. It’s an exciting new development that makes life easier, safer and more sustainable for the planet.
Our company Bluetti produces outstanding, durable and affordable portable solar panels and generators. If you have any questions about the right products or set up, feel free to contact our customer care team. We’ll be happy to answer any questions.
