Is It Safe to Use a Generator in an Apartment?
Having a generator in your apartment can be a boon as it can provide backup power during a blackout. Apartments allow the use of different generators ranging from solar to gas generators. But is it safe to use them? Do they pose any health risk? Let’s find out.
Do Apartments Install Backup Generators and Should I Buy One?
Yes, most apartments have a backup generator installed that provides backup power incase of a power outage. As you’d know, they are stationary, large, and often run on fossil fuels. In most cases, they provide power to essential services such as elevators, AC systems, and lighting systems. These automatic units do not provide backup electricity to individual houses.
As such, you cannot power your appliances or light your house with the apartment’s backup electricity. Unpredictable power outages can cause unnecessary disruptions. It is for this reason you need to invest in a generator.
A generator can help keep your food fresh, allow you to continue, and even power critical devices. That said, you need to liaise with the apartment to determine which type of generators are allowed. Most apartments will allow the use of rechargeable solar generators since they do not produce toxic gasses and are quiet during operation.
Furthermore, solar generators are portable allowing you to carry them wherever you need them. So, if you need a generator for your apartment, consider buying premium options like those from BLUETTI. They are quiet, eco-friendly, and efficient.
Large units can even power your entire house for days on a single charge. And the best part is that they have many charging options. You don’t have to rely on solar or AC. Instead, you can use either, plus a generator and your car.
What Type Of Generator Can You Use In An Apartment?
There are two types of generators you can use in an apartment: gas and battery generators.
While gas generators provide more power output, they have some downsides. They can be quite loud, annoying your neighbors and even people in your apartment. Secondly, they produce harmful toxic gasses that are detrimental to your health. Not to mention their bulkiness and need for specialized installation.
But that’s not all, most apartments will require you to seek permission before using them. And as you’d guess, not many landlords are receptive to gas generators. And if you can use them, you’ll have to place your generator 20 feet away from the building.
This is why battery generators are the most ideal option.
Battery generators are not only quieter but also safe and easy to use. They do not emit harmful gasses and are not a nuisance to your neighbors. Besides, you can recharge them using different methods like solar and AC. Besides, you don’t need permission to use them.
These compact and lightweight units do not require maintenance and can be placed anywhere. Whether you want to use them on the balcony or in your bedroom, they got you sorted. And if you want to charge them using solar, you can use a portable solar panel and place it on your balcony.
Bigger options might require you to use larger solar panels or recharge using AC. You can recharge them during the day and use them at night when the electricity rates are high. This allows you to reduce your energy costs.
Generators for Indoor Use
Having a backup generator in your house can help you power appliances and devices during a power outage. Moreover, it can help you reduce electricity bills, especially if you have a high-capacity unit installed in your house.
Here are some of the best BLUETTI generators ideal for use in your apartment.
Power On, Rain or Shine
①1,536Wh Capacity; ②4,800W Surge Power; ③1,200W Max. Solar Input; ④IP65 Water & Dust-resistant; ⑤3,500+ Life Cycles to 80%; ⑥MPPT Controller, BMS, etc
Get Discount | Buy Now!
If you are looking for a portable generator with an elegant design, this model got you sorted. Coming in an elegant black finish, the AC240 bolsters the aesthetic of the space it is in. Furthermore, it comes in a lightweight and compact design. This means you can carry and place it where you need it.whether it is in the kitchen or bedroom, this model makes the cut.
It has impressive performance, ideal for home use. It has a 2400W rated power, ensuring seamless output of power. And thanks to the 3600W power lifting mode, it can support appliances such as refrigerators and AC systems. Its capacity can be expanded to 10136Wh allowing you to connect as many devices as you want.
Speaking of devices, it has over five ports so you can charge multiple devices simultaneously. For example, there are two USB-A and USB-C ports. Recharging it is easy since it provides you with five charging options including solar panels, car charger, and AC wall outlet.
You’ll love how efficient the LiFePO4 battery is. Besides its high capacity, it has over 3500 life cycles, meaning you can use the generator for over 10 years while providing high performance. If you want a compact generator for your apartment, consider buying this model.
BLUETTI AC200P + 3*PV200D Solar Generator Kit
Stay Charged, Anywhere, Anytime
①2,000Wh Capacity; ②4,800W Surge Power; ③700W Max. Solar Input; ④7 Ways to Recharge; ⑤3,500+ Cycles to 80% Original Capacity; ⑥MPPT Controller, BMS, etc
Another ideal option is the BLUETTI AC200P that comes with three solar panels. If you live on upper floors, this might be a perfect fit for you. Simply position the solar panels on the balcony and the generator will charge seamlessly. The best part is that these solar panels have a high power output meaning your generator will recharge within a few hours.
As you’d expect, it comes in an elegant black and silver finish, which improves the aesthetics of the space it is in. The tactile buttons and LCD display provide an intuitive user experience, making it an easy-to-use unit. Of course, its lightweight design allows you to carry it wherever you need it while its compactness makes it fit in tight space.
While a small unit, it has an impressive capacity of 2000Wh providing ample power to run your air conditioner for four hours or your electric grill for 1.5 hours. You get a 4800W surge wattage ideal for starting small to medium appliances such as a car fridge. And the 2000W rated power ensures appliances run seamlessly.
The battery is another impressive feature. As a LiFePO4 battery, it provides much-needed efficiency and performance to provide power for your whole house. Thanks to the lithium iron phosphate chemistry, it has over 3500 life cycles. Get this quiet and eco-friendly power station and keep your devices powered during a power outage.
How Long Can An Apartment Generator Last?
How long a generator can last depends on factors like its size and the number of appliances connected to it. If you have a large generator with few devices connected to it, it can last for days or weeks. On the other hand, if you have a low-capacity generator connected to many devices, it can last for a few hours.
If you’ll be recharging your generator using solar panels, the peak sun hours will be a crucial factor. The higher the number, the easier it will be to recharge it and the more energy it will store, meaning it will last longer. If the peak sun hours are few, the generator might not have enough juice to power your devices for extended periods.
To determine how long a generator will last, divide the generator’s capacity by the appliances’ total wattage. Assuming the generators efficiency is 80%, we can calculate its working hours using the following formula:
Run time = generator capacity * 0.80 / total wattage of appliances
How to Use A Generator in Your Apartment
Here is a practical guide on how to use a generator in your apartment.
Choose the right solar generator for your power needs. You should calculate the total critical load to determine the appropriate size of the generator.
Place your solar panels in an appropriate position that receives direct sunlight. The balcony is the most appropriate area. Ensure the panels are well-grounded to withstand strong winds.
Connect the solar panels to the generator. If you are using portable solar panels, you can connect them directly to the generator. For stationary panels, you will need a transfer switch to connect to your apartment’s electrical system.
Charge the generator fully before using it and then connect your appliances and devices.
Most modern apartments will have a backup generator installed which automatically turns on when there's a power outage. However, it provides power to critical infrastructure in the apartment block and not individual houses.
As such, we recommend getting a backup generator for your house. While a gas generator is an ideal option, using a solar generator has more benefits. For example, it is quiet, eco-friendly, and you don’t need permission to use it. And for the most reliable models, consider buying from BLUETTI.
