Shop our products
Did you recently experience a worrisome power outage? Did that go for hours, ruining your day's schedule and affecting your work?
Unfortunately, blackouts aren't only a thing in the rural or developing world today. The rapidly growing cities and fluctuations in the weather are putting pressure on already weak national grid stations.
Therefore, if you don't want to be a victim of unnecessary halts in the supply of electricity, equip yourself with a generator for your apartment. But which one should you go for?
Dig in to find your answer!
Do You Need a Generator for Your Apartment?
Do you own an apartment but are not sure if you can get a generator, too? Well, many apartment buildings come with their backup generators. These powerful machines are built for commercial purposes to run lights and other building services when required.
However, these backup apartment generators don't supply power to individual apartments. This means you have no other choice than to get a separate generator for your home and experience an uninterrupted supply of power.
Which Generator Should You Select?
With so many powerful brands selling their generators on the market, you may get confused while picking one that meets your requirements. Attractive and engaging advertising and promotional strategies can fool even the most experienced buyers.
So, if you don't want to get trapped and witness your money getting wasted, consider a few important factors before making a buying decision. Ask yourself a few questions before you take the plunge and bring your first generator for your apartment home.
Type of Generator- Solar Powered or Gas?
Gas-powered generators are not safe for an apartment. Regardless of how inexpensive they may be, they can be deadly because of their exhaust production.
What are you left with? Portable solar-powered generators are perfect to keep in small or big apartments. These are usually compact and can charge your appliances for many hours. What's more, if you own sensitive electronics, solar generators are a perfect option for them because of their zero THD and an ideal sine wave.
Battery-powered generators aren't noisy. Suppose you live in an apartment building with thin separations between each accommodation. In that case, a quiet yet powerful generator will prove quite handy.
Another great thing about such machines is that they majorly require solar power to work their magic. All you have to do is place these generators on a balcony, facing the sun, and let them charge for hours to perform well in times of misery.
Generator's Capacity - How Big Should Your Solar Machine Be?
How big is your apartment, and how many electronics do you want the generator to run for you? Once you have the answer to this question, you can pick the right number of watts that you wish to draw from your solar machine.
Some electronics in your space may have a higher amp draw than the rest. Your chosen generator should be able to run them first. If they do, running smaller machines won't be an issue.
Consider All the Charging Options Available
Most solar-powered generators can be charged through solar panels, car adapters or wall outlets. When searching for the best unit for your apartment, always read the product description to know what accessories come with it. You may have to buy certain items separately which may ultimately increase your cost.
For example, most generators don't come with car adapters or solar panels until you get a good deal. These are usually some added expenses to use a generator in your space.
Are There Any Upgradable Options?
Suppose you plan to move from a small apartment to a bigger one with more electronics. In that case, will it be possible to upgrade your existing generator easily?
This is a concern most buyers don't think about. However, you should reap maximum benefits from your purchase.
Some units come with space for extra batteries. You can use them to run appliances with higher wattage.
Similarly, a few generators have the helpful feature of hooking an extra solar panel to it, if required. This is a perfect upgrade option when you need to charge your electronics at a faster rate.
Is My Generator Safe?
Most generators for apartment are usually safe. They come with great safety features so that you can run with complete peace of mind.
However, it is always wise to check your units for these features before purchasing them. For instance, generators that come with an internal gauge to maintain high/low temperatures are a great and secure purchase. The gauge shuts down the unit if the generator's battery fails to perform as per the manufacturer's specifications.
Similarly, solar machines that come with overload protection are also deemed safe. They prevent the generator from overcharging. The feature also keeps the unit safe from charging more electronics than its capacity allows.
Weight and Durability- Is it Long-lasting?
When buying a generator for apartment, always consider its weight. Will you be keeping the unit in one place all the time, or do you plan to take it on your road trips as well? Make sure you know the answer so you can pick one that adjusts your lifestyle.
In addition, don't compromise on the unit's durability. Your chosen generator must be made to stand all the bumps on the road if you plan to move it often. It should also be able to stay protected from rain and storm so it serves you for as long as you want.
Price
Your budget plays a key role in choosing the best unit for your little home. If you have a limited budget, work accordingly and look for a solar powerhouse that meets your requirements.
But make sure to take all the above factors into account. After all, you may not want a cheap generator that is unsafe, non-durable, and fails to perform well when required.
Here is a tip. Keep looking for deals and then make a purchase when you see an attractive offer.
Indoor-Friendly Solar Generators for Apartments
Do you want us to ease your search for the best apartment generators? Take a look at our top three recommendations.
1. BLUETTI AC180 Solar Portable Power Station
Now, this is a portable unit with a strong performance. The AC180 portable generator has a whooping capacity of 1152Wh. This means you can easily use it for a good number of appliances.
Additionally, the unit can be charged in four different ways, leaving you lots of options to try. The eco-friendly and quiet generator can be easily monitored and controlled through the BLUETTI app, allowing you to handle it even if you aren't home.
Priced well, the generator comes in four models and also has an impressive five-year warranty.
2. BLUETTI AC300 + 1*B300 | Home Battery Backup
With an impressive capacity of 3072Wh, this generator does the work pretty well. You can recharge the unit in seven different ways, by using a lead battery, AC, or solar car.
Another great thing about this unit is that it is expandable. Now, what does that mean? You can increase the capacity of this unit easily up to 12,288Wh, as per your required use.
Again, this generator is well-priced, with an attractive warranty, and allows you to spend less in exchange for more. You can also use it to back up your UPS for a whole day.
3. BLUETTI EP500 Solar Power Station
Your apartment deserves to stay lit and running all the time. Therefore, it is wise to consider the EP500 as your preferred solar power generator. Why?
For starters, the unit has 2000W of output and can load multiple devices at one time. Moreover, this is a flexible generator that is easily moveable, making it portable for your trips.
You can change this solar power solution in more than one way. The machine comes with a smart touchscreen that helps you know the right time to charge the generator and keep it running.
There are three available models of this generator. Pick one whose features and price tick all the right boxes for you.
Get a Generator, But Use It with Precautions
A generator is necessary for your apartment right now, and if you experience regular blackouts in your area, consider this as an immediate asset. The unit can benefit you in more ways than you can imagine, but use it with safety.
Even if your chosen generator comes with loads of safety features, ensure to be vigilant when consuming its power.
Avoid overloading the machine so it doesn't heat up. If it does, it can damage the batteries and your electronics, increasing the chances of a fire disaster.
If possible, keep the unit in an open space rather than indoors. This isn't necessary, but a wise idea to keep all risks at bay.
Wrapping Up
Purchasing a generator for apartment is a serious business, so make sure that you don't take this lightly. This is an investment that can be a blessing in your worst days, so consider every factor smartly, and don't just get fooled by online deals that give you nothing for the price you spend.
