Are you looking for the best apartment generators for your home? Chances are that you will find a huge variety of these machines from various suppliers, but picking the right one can definitely be challenging.
It isn’t fun losing power every now and then, especially when your entire home runs on electricity. Besides, a generator is an asset that can be your best companion during emergency outages.
Therefore, owning a generator that meets your apartment needs and fits well in your space is crucial. Dive in to know how much a generator costs and which one may be a great fit for you.
Can a Generator Be Used in an Apartment?
Have you often thought of buying a generator but stopped after listening to several horror stories? Generators can be harmful, but only those that use gas to work. Most landlords don’t allow keeping such units if there isn’t enough outdoor space to place them.
However, if you have a solar-powered generator, you can easily use it in your apartment without any worries. They are emission-free and also silent, meaning that they pose a minimum risk and won’t disturb the neighbors.
That said, it is always safe to keep your generator away from your indoor space. Ensure that there is proper ventilation available and enough light to keep your solar-powered unit working.
Generator Cost by Fuel Type
Once you have established the need for a generator for an apartment, look for units that meet your budget. Each generator comes with its own cost, depending on its fuel type.
Generators run using different types of fuels, including gas, diesel, and solar power. The fuel rates are prone to fluctuations every month. However, on average, gas-powered generators are comparatively cheap.
For instance, the fuel cost of gasoline generators may range from $500 to $3200. Similarly, natural gas generators’ price may vary from $2,200 to $25,000, as per their capacity.
Since diesel fuel prices are high, the fuel generators may cost anywhere between $3,200 to $24,000.
Finally, solar-powered generators are far more efficient than other fuel models. Their price range can vary between $2,000 to $25,000. However, they need enough sunlight to work and are only suited for places that offer them sufficient sun.
Generator Cost by Size
The cost of the generator can also vary due to its size and the area it covers. For instance, a 2 to 5KW generator may cost around $300 to $1500. Similarly, a 13 to 16kW unit can cover up to 1,500 sq ft home and is usually worth $3500 to $4800.
If you have a big apartment around 3,000 - 5,000 sq ft, you may have to go for a 22 to 25 kW generator. Such a unit may be available for $4,500 - $12,500.
Again, it is imperative to note that the prices may change and fluctuate according to the demand and overall inflation rates. You should always take the most updated costs of the unit before making a purchase.
Factors That Affect Generator Costs
Apartment generators don’t have the same price all year long. In fact, you will often see the costs increasing until there are great offers and deals to avail of.
There are many important factors that impact a generator’s cost. For instance, if the price of raw material used to manufacture the unit increases, its cost will automatically rise.
A frequent fluctuation in expenses along the supply chain, changes in fuel costs, generator output and overall installation costs can also have an impact on the final price of your generator.
Therefore, it isn’t right to blame the brand only. If you live in an unstable economy, the cost of generators and other commodities may seem to change more than you can imagine.
Choosing the Right Generator for an Apartment
The cost of a unit shouldn’t be the only factor that should determine your purchase. When looking for the best apartment generators, you must also consider some other factors and then pick the right one.
Determine Your Apartment's Required Power
What is your apartment’s size, and how many items do you wish to run with your newly purchased generator? You can’t just buy a generator as per your budget and expect it to power your entire house. Make sure that you do some homework and calculate the number of watts you aim to draw from your unit.
Certain appliances have a much higher amp draw than the rest. If you wish to run them using a generator, ensure that the selected unit runs them first. If it is successful, it won’t have issues running the small appliances.
Consider Generator Type
As stated previously, the best generators for an apartment are usually solar-powered. However, if your building allows, you can also keep a diesel or gas unit. But make sure you practice all the precautionary measures before using the machine.
Gas units are cheaper than most other generators. But solar-powered units are energy efficient and much safer. They don’t require high maintenance and can be used to light up your entire space.
Budget and Costs
Are you thinking of buying a generator but don’t have enough money in your bank balance? You must consider and evaluate your budget and then match it with all the costs related to buying a unit.
Please also consider the delivery expenses, installation costs and yearly maintenance expenditures before spending your money. If there is any labor cost incurred in this process, don’t forget to take that into account too.
Noise and Environmental
You may buy a generator for your ease but don’t make this purchase at the cost of the peace and safety of people and animals living around you. Some generators are way too noisy and can cause a nuisance in your neighborhood. Such units are a no-no, especially if you live in an apartment.
Similarly, be sure to consider your environment when purchasing a generator. Generators that emit carbon monoxide are dangerous for you and can also pollute the environment, increasing the risk of health hazards as it is a poisonous gas. It blocks oxygen from getting into your body.
Therefore, you need to be a responsible individual and less selfish when investing in a generator for an apartment.
The 3 Best Indoor Generators For a Small Apartment Use
Here’s hoping that this buying guide has helped you find the generator for your little space. If you are still on the lookout, here are reviews of the top three best units that you may want to consider. Take a look!
Do you need a portable power station for your apartment? In that case, you may want to get your hands on the BLUETTI EP500Pro. Entirely sourced through solar power, this unit can produce an output of 3000W and comes with both flexible and in-grid UPS Modes.
What’s more, the power station is incredibly safe. It features the LiFePO4 technology that enhances the durability and performance of the unit. You can also upgrade the generator’s firmware through your internet connection.
It is a well-built generator that will never let you run out of power.
Are you tired of continuous power outages? If yes, you and your family may need the BLUETI AC300 + 1*B300. What’s great about this machine?
For starters, it has an excellent capacity of 3,072Wh. This can be expanded to a maximum capacity of 12,288Wh with four B300 power kits. Your small apartment will stay lit for days. Like most other units from the same brand, this one also uses the LiFePO4 Battery, which is highly durable.
You can easily charge this machine in seven different ways, including AC, solar, car, and lead-acid battery. You can buy this generator in six different models and get your home a much-needed power backup for bad days.
With a capacity of 4,096Wh, this unit can be your number-one savior on the most disturbing days with consistent power outages. With two power kits of B230, the generator's capacity can increase to 6,144 Wh, and that truly is incredible.
The machine features an incredibly durable battery with 3,500+ Life Cycles to 80%.
If you often face charging problems with your generators, know that this one won’t disappoint. It can be charged in seven different ways, including car, solar, lead battery, and solar.
The unit features 16 outlets, allowing you to use it for all your needs at a time. What’s more, if you have an RV, this battery backup comes with special outlets to accommodate all your requirements.
You can conveniently monitor and control your machine’s performance using the BLUETTI app. This is an affordable generator but gives you excellent relief through its top-notch output.
The AC200Max +1*B230 comes with a four-year hassle-free warranty. The brand is always available to offer you excellent customer support as required.
If you are picking a generator for an apartment for the first time, know that the process can be daunting at times. However, your excellent homework and search can help you pick the unit worth every buck.
Therefore, evaluate all the factors before you make a choice. Moreover, take expert advice or go through customer experiences so you can know whether the recommended units can save you from the hassle caused by power outages for good.
Also, consider the BLUETTI generator options above, as they may tick all the right boxes. Happy Shopping!
