Shop our products
Mini-fridges, those small but mighty appliances of today's modern life, without a doubt have found their way into almost every corner of our lives. They are everywhere such as outdoors, dorms, offices, and homes and at arms reach. They are always there to preserve the freshness of food and keep the drinks cold. But the question that comes in is their energy consumption. The wattage of the mini fridge and the factors determining it should be considered carefully. Because it has a smaller dimension than a regular fridge, it wastes drastically less energy, right? Today, we are going to provide you with all the answers you have been looking for.
How Many Watts Does A Mini Fridge Consume?
A mini fridge's power consumption fluctuates significantly depending on the size, design, and energy efficiency of the appliance. Most of the time, mini fridges burn 50 to 100 watts of power. To estimate the energy usage more precisely, you can use the formula: The power (in watts) = voltage (in volts) × amperage (in amps).
For instance, if the mini fridge works at a normal household voltage of 120 volts, then we would be able to determine the power ratings. If the fridge draws a current of 0.5 amps, we can calculate its power consumption as follows:If the fridge draws a current of 0.5 amps, we can calculate its power consumption as follows:
Power (watts) = 120 volts × 0.5 amps = 60 watts.
Importantly, this case assumes that the mini fridge consumes 60 watts of the electricity when being run.
What is the Expense of Operating a Mini Fridge?
When you have found out the wattage of your mini fridge, you can approximate its daily operating cost by considering its intermittent mode of operating. Mini fridges work in a cyclic manner turning on and off alternately to maintain the internal temperature of the fridge with the least energy consumption. To be precise, the usual mini fridge operates for about 8 hours in a day that is one third of the day.
To calculate the daily energy consumption, use the following formula:
Daily Energy Consumption in watt-hours = Mini Fridge Wattage x 8 hours
Next, find out the electricity rate in your area, usually measured in kilowatt-hour (kWh), which is the cost of energy per unit consumed. Take your daily energy consumption multiplied by your local kWh cost to get the daily price of running your mini fridge.
For example, if your mini fridge has a wattage of 80 watts and your local electricity rate is $0.12 per kWh:For example, if your mini fridge has a wattage of 80 watts and your local electricity rate is $0.12 per kWh:
Hourly Energy Consumption = 80 watts × 8 hours = 640 watt-hour.
Daily Cost = 640 watt-hours x 0.12$/kWh = 0.0768 $.
Hence, the expected daily cost of your mini fridge to run will be around $0.08. This calculation enables you to predict and manage your electricity bills that you will need to pay for operating the mini fridge efficiently.
Contributors to Mini Fridge Power Consumption
Design and Insulation
The design, and quality of construction of the mini fridge determines the efficiency of the energy. Fridges with better insulation and tightly sealed doors are a good way to keep the temperature in the fridge consistent while at the same time saving energy.
Temperature Control
The temperature levels of your mini fridge fundamentally influence its power consumption. Maintaining the temperature inside the fridge below the room temperature level results in a higher energy consumption, which directly affects the power consumption.
Size Matters
The size of the mini fridge is the most important factor in the power consumption of the appliance. In most cases, larger mini refrigerators tend to consume more energy in cooling their augmented internal volume than the smaller ones.
Usage Frequency
The number of times you open and close the fridge door may impact how much energy the fridge uses. The more often the door is opened, the more the fridge uses additional energy to adjust the temperature, which is another factor that consumes more power.
Climate Conditions
The temperature and climate of your region also affects the energy consumption of your mini fridge In warmer regions, the fridge may have to work against the higher ambient temperatures more often and therefore consumes more power.
Energy-Saving Mini Fridges As The Best Choice
Tap into energy-saving choices that optimise energy efficiency without forgoing the cooling effectiveness. Here's what to consider when searching for an energy-saving mini fridge:
Energy Star Certification
Select the mini fridges that have earned the Energy Star certification. Energy Star certification is an indication that the product conforms to the high energy-efficiency standards set by the Environmental Protection Agency (EPA). They offer the potential for nearly 50% or more electricity saving, leading to lower utility bills.
Inverter Compressor Technology
Select compact refrigerators that have inverter compressors with the best energy efficiency. Traditional compressors are not as efficient. Inverter compressors, thanks to their variable speed, which is adjusted to the cooling demand, are able to minimise energy waste and, consequently, achieve maximum cooling efficiency.
LED Lighting
Choose a mini fridge which is equipped with an LED lighting system on the inside. LED lights, in addition to using less power, generate little heat and thus, cut the workload of the refrigerator's cooling system and increase the efficiency of the entire system.
Adjustable Shelving
Give preference to mini fridges with adjustable shelving options, which will allow you to tweak shelf layouts and optimise storage space utilisation. An adjustable shelving layout cuts down on the amount of empty space in the fridge, thus requiring the compressor to work less, which in turn also helps to save energy.
How To Run Your Mini Fridge During Power Outage?
BLUETTI EB55
The BLUETTI EB55 is the best choice for Portable Power Station for power outages, camping trips or campervan adventures due to its compact and lightweight structure. Integrating a 537Wh capacity and a 700W inverter with a surge capacity of 1400W, the EB55 is capable of powering different outdoor appliances and electronics such as mobile phones, mini fridges, radios, projectors, and so on. Additionally, it can power up to 13 devices at once, including smartphones and mini-fridges, while its wireless charging pad makes it easy to charge your devices.
With a weight of only 16.5 pounds and a handle to carry it, the EB55 is a portable device that you can bring wherever you go for power. It is superior in performance, promptly recharging and being errorless as a source of power for drones, phones, laptops and even astronomical telescopes. Besides, it can be recharged using solar power, consequently offering a self-sufficient energy solution for off-grid trips.
BLUETTI AC2A
The BLUETTI AC2A is a pocket-sized powerhouse that comes with a stylish design and a hand grip for easy mobility. When it comes to power, this model has a 204.8Wh capacity, a 300W continuous output, and a peak of 600W. It is ideal for power outages, camping, RV trips, and other outdoor adventures.
Its 270W Turbo Charging helps for quick recharging, with 80% capacity reached in 45 minutes. On the other hand, it uses the pass-through charging method, which enables the charging and discharging processes to take place at the same time. The AC2A is a superb energy source for different scenarios such as outdoor activities, mobile offices, home backup, and emergency events. It can be used in power outage situations and it is very easy to operate as it can be used to run appliances like mini-fridge.
Furthermore, it is capable of charging up to 200W solar input and is quick to recharge in just 1.2 hours, hence providing unending power supply in remote locations.
BLUETTI AC70
BLUETTI AC70 power station is a dependable backup power, which combines a strong capacity and output. This power bank of 768Wh can conveniently run devices such as mini-refrigerators in the event of power failure, ensuring that your important items stay cool and fresh. The model comes with a wide range of ports, such as AC outlets, DC ports, and USB ports, therefore, it provides versatility in charging multiple devices at the same time. Also in this context, AC70 can be recharged using solar power, which is an alternative and ecological energy source for situations where there is no grid.
Its reliable operation will always be there to provide an uninterrupted power supply, which is very necessary for household use. If you are in a situation with no power supply or you need to go camping, the BLUETTI AC70 power station will provide you with the reliable energy at the time when you need it the most.
Final Words
I believe that when choosing a mini fridge, you should strive to achieve a good balance between convenience and energy efficiency. By knowing how it operates and the factors that affect its power consumption, you can make the right call. This way, you are guaranteed that your perishables preserve their freshness and contribute to a lesser impact on the environment. Whether you want to cool your beverages, store snacks or even preserve medicines, a mini fridge does this and more for you. In spite of that, you should keep your eyes on how much energy it consumes. You do so depending on the benefits of the mini-fridge while being energy efficient.
