It is difficult to imagine our lives without some of the major appliances we tend to take for granted, like HVAC systems and refrigerators. However, in the case of clothes dryers, the alternative is not a far-fetched idea. Have you ever seen laundry strung up on a clothesline? Maybe you have hung your clothing over a clothesline for air-drying!
Clothes dryers are definitely time savers. When you don't have time to dry clothes all day on the line, you throw them in the dryer and they are ready to be folded within an hour. You may have the luxury of a clothes dryer, but what about its electricity consumption? Does it cost a lot or is it pocket-friendly? Let’s find out.
Are Dryers Energy Guzzlers?
The dryers are known to be high-energy consumers because they use the heating elements to dry clothes efficiently. Their energy usage can cause very high spikes in energy usage during operation. In the usual course of things, the dryers run less than 5 hours per week. However, don't take the impression that the dryers are the only power-hungry items since they function for a short amount of time.
How Much Electricity Does A Dryer Use?
An electric dryer has a high electricity consumption when operating. A typical electric dryer, on average, uses about 2.3-5.7 kWh of electricity per load, considering factors like drying level, cycle duration, and efficiency. The more clothes are washed together and the longer the drying cycle, the more energy is consumed. To calculate the electricity cost, find the dryer's wattage, then multiply it by the number of hours it is in operation, divide by 1000 to convert it to kilowatt-hours. Next, you should multiply the number by the electricity rate per kWh that is charged by your utility company. For instance, if a dryer completes an hour of operation at the rate of $0.12 per kWh and consumes 3.5 kWh, the cost would be $0.42.
How Many Amps Does a Dryer Use?
On average, a cloth dryer uses up to 20-25 amps of electric current when it is being operated. To discover the exact amperage used by a dryer, it is recommended to refer to the specifications provided by the manufacturer. These specifications are mostly expressed in watts or kilowatts, which are shown as dryer power ratings. Watt is the total power consumption measure for the device.
To calculate the amps, you can use Ohm's law: Amps = Watt / Volt. The dryer usually has a voltage of 240 volts. For example, if a dryer has a power rating of 4800 watts, you will divide 4800 by 240 to get 20 amps. Hence, for every 240 volts of the electric potential, the dryer consumes 20 amps to churn out 4,800 watts of power. The relationship, in other words, is the pre-understanding that is necessary for being able to use electrical appliances safely and to select suitable wiring and circuitry for the clothes dryer. In any case, before you start the installation process, check the specification sheet and, if needed, contact an electrician.
Dryer Running Cost
To calculate the values:
Let us assume that the average electricity demand per load is 3.5kWh.
- Monthly consumption = 3.5 kWh per load× 30 days per month = 105 kWh per month.
- Consumption per year = 105 kWh/month * 12 months/year = 1,260 kWh/year.
To calculate the bill, use the multiplying method by the kWh price.
- The monthly cost is $105 kWh/month * $0.12/kWh = $12.60/month.
- Monthly charge = $12.60/month * 12 months/year = $151.20/year.
Factor |
Monthly |
Yearly |
Electricity Usage (kWh) |
105 kWh |
1,260 kWh |
Estimated Cost (at $0.12/kWh) |
$12.60 |
$151.20 |
How Much Energy Do Different Types of Dryers Use?
Vented Clothes Dryers
Vented clothes dryers are a traditional option that employs an external vent to exhaust the hot and humid air produced during the drying process. However, their electricity use varies depending on the load, and it usually falls in the range of 2.4 to 4.8 kWh per load. Nevertheless, these can be affected by the load size, type of fabric, and set drying time.
Condenser Clothes Dryers
The condenser dryers are the ideal alternative to the vented dryer because they let moisture get collected from clothes in a water container or drain. For convenience, a ventless dryer is slightly more energy-intensive than a normal dryer, which takes anywhere from 2.8 to 5.5 kWh per load to operate.
Heat Pump Clothes Dryers
Heat pump dryers are the most energy-efficient among other types of dryers as they use a heat exchange process to dry clothes. Consumption of electricity in the range of 1.3 kWh for wash to 2.4 kWh for dry, they are really economical and environment friendly when compared to vented and condenser dryers.
Ways To Minimise Energy Consumption When Using The Dryer
Regarding the drying of clothes, there are many practices that you can apply in order to lower power consumption and hence save energy expenditures. Here are some tips to help you make your laundry routine more energy-efficient.
Here are some tips to help you make your laundry routine more energy-efficient:
Choose The Right Dryer
Go for a purchase of an energy-saving clothes dryer with high energy star ratings that is built with features that consume less power. Search for those machines that have energy-saving features installed in them like cycle delay switches, which you can use to schedule washing cycles at the off-peak hours when electricity rates are low.
Air-Dry Clothes Partially
Remember to use air-drying to some extent by allowing your clothes to air-dry partially on a clothesline or drying rack before transferring them to the dryer. This process can considerably decrease the total time spent drying and energy use.
Optimise Load Capacity
The best way to ensure that the drying process is as efficient as possible is to optimize the load size. Try to prevent overloading or underloading the machine since they will eventually consume more energy and result in inefficiency in drying. Go for even distribution and the right amount of loads to get maximum calorie burn.
Sort and Dry Similar Fabrics Together
Sort your laundry on the basis of fabric type and weight, and dry the similar fabrics at the same time. This results in a more uniform drying and the reduction in usage of the dryer cycles that may take longer or consume more energy.
Utilise Spin-Dry Feature
Utilise the spin-dry function in your washing machine first before placing the garments in the dryer for better drying. Through this stage, the water evaporates faster, which leads to saving energy.
Regularly Clean the Lint Filter
Make sure that the lint filter is clean for better airflow and to avoid a possible clog. A dirty filter clogs the air circulation and thus forces the dryer to use more energy and work harder. After each use, clean the filter or as per the directions on the product label.
Utilise Sensor Drying Technology
Utilise the sensor drying feature in the modern dryers which has been made accessible. The moisture sensor component of this appliance detects the moisture level in your clothes and sets the drying time according to that, which helps to prevent over-drying and hence reduces energy waste.
Dry Clothes During Off-Peak Hours
If you have the opportunity, run your dryer at times when electricity rates are low. This can lead to a reduction of 30-50% of your energy bill.
Ensure Proper Dryer Ventilation
Ventilation is important to keep the dryer vent and exhaust ducts clean so that they can have proper venting. Adequate ventilation will enable the dryer to function economically, which will cut down on energy consumption and extend the longevity of the appliance.
Can I Use a Home Battery Backup to Power the Dryer?
Among homeowners, there are many who ask if a home energy storage system can provide the same power that the dryer needs. Let's check if such systems are capable of the task.
BLUETTI AC300 + B300
BLUETTI AC300 is a modular home battery backup system featuring four B300 battery modules of 12,288Wh in total. It is ideal for meeting the power needs of families for days during emergency cases or power outages. It features an advanced MPPT solar charging feature that can recharge a B300 module in just 1.5 hours using only solar energy.
This solar power system is fitted with a 3000-watt pure sine wave inverter that can run appliances like refrigerators, TVs, and lights among others. The device provides adjustable AC charging rates as well as up to 5400W total input power, allowing for fast charging whether from solar panels or wall outlets, making it the perfect choice for camping or home use.
BLUETTI AC500 + B300S
The AC500 and B300S, a power system that uses solar energy, is a game changer in the power industry, allowing for expandable capacity to deal with power outages and off-the-grid living. The unit comes with the space for 6×B300S expansion batteries, and it accumulates a total capacity of 12,288Wh, which guarantees that the power supply is uninterrupted for several days. Having a pure sine wave 5,000W inverter, it runs appliances like clothes dryers and refrigerators, even during outdoor activities such as camping and barbecues.
An MPPT controller-supported system, allows the unit to recharge rapidly with up to 3,000W solar input. It is fully recharged in about 1.5 hours. The system is now your home energy source, it does not allow loss of power during grid outages and supplies uninterrupted power to essential loads.
BLUETTI EP500Pro
The BLUETTI EP500PRO has the 5120Wh LiFePO4 battery pack and the 3000W pure sine wave AC inverter, which are next-level breakthroughs. This powerful unit has the capacity to keep the entire house running during blackouts, including the clothes dryer. It supplies up to 15 outlets, making it possible to charge everything from laptops to electric cars. Its highly developed Battery Management System guarantees safe operation and high performance.
The EP500PRO will immediately become your home energy source during grid failures, which is unlike noisy gasoline generators. Add up to 1200W solar input to fast charge the battery, or use it to power appliances without depleting the battery. Farewell all concerns about power failures with the BLUETTI EP500PRO.
Considering the energy-intensive nature of dryers, reviewing your usage habits, and the model you have bought is a wise thing to do. Identifying the kWh per load consumed, understanding the technology behind your dryer, and the significance of maintaining enough air circulation is vital. These can save the maximum expenditure for each use. Even though those savings seem to be small, they contribute a lot to your budget, and the environment at the end of the day.
