Shop our products
Are you wondering how many watts does PS4 use? Well, based on the type, a PS4 can use 5 watts f or PS4 Silm on Standby Mode, and it can go up to 155 wattages in intensive gaming, especially with PS4 Pro. It all depends on the type of PS4, your usage, and the different modes.
How Many Watts Does A PS4 Use?
To understand how many watts does PS4 use, we need to understand what a PS4 is and how it works first. PS4 stands for Play Station 4, which is a gaming playstation developed by Sony Interactive Entertainment. A part of the PlayStation video games console series, PS4 comes after PS3 and before PS5.
Despite PS5 gaining popularity, PS4 is still much loved. Let's break down the maximum wattage that PS4 uses. The classic or original PS4 has a maximum rating of 250 watts, while the slimmer version is rated at 165 watts, and the Pro version has a maximum of 310 watts.
Wattage for 3 Versions of PS4
Let's break down each type of PS4, how they differ, and how many watts the 3 different types of PS4 consume.
Original PS4
Released in November 2013, the original PS4 is a dynamic gaming console with distinct sharp corners and edges and a matte-glossy finish. It features an 8-core AMD "Jaguar" processor and 1.84 TFLOPS AMD Radeon Graphics, which means the best pixels ever!
PS4 usually allows peak usage wattage of 150-165W and total memory storage space of 500GB or even up to 1TB in special editions. Plus, it has a distinct power and eject button configuration. However, its biggest drawback was the noise.
PS4 Slim
With a 40% smaller body, the PS4 Slim has most of the Original PS4 hardware components, but it features a quieter fan and 5GHz Wi-Fi support. Moreover, it offers a much easier hard drive replacement option and a total storage space of 1 TB. Coming with the tactile project and eject buttons, the PS4 Slim allows a peak wattage of around 100 watts while in use.
PS4 Pro
Sony goes one step ahead with their PS4 Pro to create stunning visuals and give you an unrivaled gaming experience. It offers beautiful 4K resolution in games and even upgrades lower resolution games to 4K clarity. Furthermore, it gives you faster load times and allows up to 160 peak wattage when in use, especially when working with 4K games.
How Many Watts Does the PS4 Use in Different Modes?
The table below illustrates the 4 different modes of a PS4 and how many watts does PS4 use in different modes.
PS4 Mode |
Wattage |
Standby/Rest Mode |
0.47W |
Idle on the Main Menu/Login Screen |
85.6W |
Streaming Mode |
99W |
Gaming Mode |
120W |
Gaming in PS4 with PS VR |
144W |
These values can vary based on your use, and the duration you use PS4 for. Plus, if you let it stay idle when not using, or turn the power off, it also determines how many watts does PS4 use.
How Many Watts Does A TV and PS4 Use?
On average, most TVs use between 27 to 147 watts, and similarly, a PS4 uses between 45 to 145 when in use. So, it puts us at around 250 watts when both are used together. Here, we assume a typical TV use around 57 watts.
In reality, the number of watts that a TV and PS4 use together depends on the type of TV and its wattage level. For example, if you're using a simple 75-inch OLED TV with your PS4 for intensive gaming, the total wattage could be around 270 watts.
In contrast, if you're pairing a 50-inch LED TV with PS4 Pro, the total wattage can easily land at 235 watts.
Wondering why?
A 50-inch LED TV uses 75 watts to run, while a PS4 Pro uses around 160 watts during play, and we average it to 120 watts. We add the two: 75 watts + 160 watts = 235.
Let's be honest: you won't be using it in full force, so you can average the PS4 wattage at 120 watts, and that gives us 195 watts to run both TV and PS4 together.
How Much Electricity Does A PS4 Use Per Month?
How many watts PS4 use per month depends on the duration of use. If you're actively using it, a PS4 may consume around 145 watts per hour, but if it's idle, it can use around 185 watts per hour.
Let's say you use your PS4 3-4 hours daily. Simply multiply your duration by hourly wattage, and then multiply by 30 (total days in a month).
For gaming, you use around 145 watts per hour, so if we take this value, it will be 145 x 4 x 30 = 17.4kWh. For streaming at 90 watts per hour, it will be 10.8kWh.
Simply multiply this value by the cost of electricity in your region. Let's assume it is 2 cents for gaming and 1 cent for streaming.
So, for gaming, the monthly cost will be 17.4kWh x 2 cents = $2.40, and for streaming, it will be $1.08.
If you use PS4 for both gaming and streaming daily, take that into account when calculating the total and for idle time, too.
Can you Use a Solar Generator to Power PS4?
Do you love gaming, but the bills are racking up? Not to worry! You should consider switching to another source of energy to power your PS4. Solar generators are a great alternative, and a typical solar generator kit comes with solar panels, a battery, and an inverter.
Before selecting a solar generator, you need to understand how many watts does PS4 use. If you're playing a demanding game, the PS4 will use 160 watts. But adding a 50-inch LED TV (75 watts) and headphones (5 watts) may take the wattage to around 940 watts, especially if you typically play for 4 hours.
This estimated wattage can be lower or higher based on your use, and you should make sure your battery and inverter can cater to your PS4 before selecting a Solar Generator.
Best Alternatives of Electricity to Power a PS4
Wondering what Solar Generator to pair with your PS4? We've got you covered. Below are 3 BLUETTI Solar Generators that work seamlessly with all types of PS4 with energy to spare.
The BLUETTI AC180 Solar Portable Power Station is durable with LiFePO₄ batteries that make them long-lasting with 3500+ charge cycles. Moreover, it's a quiet generator and eco-friendly since it generates electricity via solar power. It allows you the option to plug in 11 different devices at the same time through USB ports and flexible rechargeable options.
Key Features:
1,800 W High Power Uplift Capacity: Long story short, it can provide 1,800 watts continuously for running your devices. Plus, it offers 2,700 watts in short bursts in Power Uplifting Mode for devices that require higher initial wattage.
1,152 Larger Battery Capacity: Its battery allows you to store up to 1,152 watts, which means it can run your appliances when there's rain or a cloudy day.
Rapid Recharging: This Solar Generator recharged from 0 to 80% in just 45 minutes. With this quick recharging, you can get it ready for use pretty quickly for your PS4.
BLUETTI ELITE 200 V2 Power Station
TThe BLUETTI Elite 200 V2 Portable Power Station offers a 2,073.6Wh battery capacity, functioning like a large energy bank that stores electricity to power your essential devices at home or outdoors. It can be conveniently recharged in multiple ways, including AC wall outlets, solar panels, a generator, or a car outlet, giving you flexible charging options wherever you are. With fast charging support, the Elite 200 V2 can recharge quickly when paired with high-input AC power, helping you get back to full power in a short time.
Key Features:
High Capacity & Expandable: With a 2,073.6Wh battery, the Elite 200 V2 delivers 2,600W of continuous power and up to 5,200W surge, allowing it to run a wide range of household appliances and electronics with ease.
Long-Lasting Battery: Built with durable LiFePO₄ battery technology, the unit supports 3,500+ charge cycles before dropping to 80% capacity, ensuring years of reliable performance.
Reliable Warranty & Portable Design: If The Elite 200 V2 is backed by BLUETTI’s warranty support for added peace of mind. Despite its large capacity, the unit remains relatively portable, making it suitable for home backup, camping, and emergency power needs.
BLUETTI Elite 400 Solar Power Station
The BLUETTI Elite 400 Portable Power Station is a compact yet capable energy solution designed to power your essential devices both at home and outdoors. With a high-capacity battery and stable power output, it works like a portable energy hub that can keep your electronics running during camping trips, outdoor events, or unexpected power outages. It also features smart control through the BLUETTI App, allowing you to monitor and manage power usage conveniently.
Reliable Capacity for Everyday Devices: With its efficient battery capacity and stable output, the Elite 400 can power a variety of small appliances and electronics such as laptops, mini fridges, lights, and kitchen devices. This makes it ideal for camping, RV trips, outdoor gatherings, and emergency backup when you need to run multiple devices at the same time.
Flexible Recharging Options: The Elite 400 supports multiple charging methods, including AC wall outlet, solar panels, car charging, and generator charging. Solar charging allows you to generate clean energy off-grid, while wall charging ensures the unit is always ready when you need reliable backup power.
Durable and Portable Design: Built with LiFePO₄ battery technology, the Elite 400 is designed for durability and long-term use. Its compact and portable design makes it easy to carry for camping trips, outdoor adventures, and emergency preparedness, while maintaining reliable safety and performance.
Do you love gaming on PS4 but want to cut down on energy costs? No worries, you can simply connect your PS4 with a Solar Generator. Solar Generators can allow you to game freely without worrying about electricity costs for hours on your Play Station 4.
It's sustainable, but make sure to choose a product that can handle your PS4 wattage for multiple hours for a seamless experience.
