How Many Watts Does a Space Heater Use?
20/03/2026
How much will I pay this winter? Which heater is the best and what energy resource can help me out. In summers as we worry about the costs of electricity for air conditioners similarly in winter we often are curious about the usage of space heaters and their costs.
Read the article below to find out what factors to consider when looking for a space heater and the best energy saviors, aka solar panels, available in the market to save on your costs.
A space heater's wattage varies depending on a few factors, including its size, kind, and model. On the other hand, 1500 watt portable electric space heaters are usually available on the market. Naturally, smaller space heaters will consume less electricity, while bigger, more powerful units might reach above 1500 watts.
We recommend that before you buy the space heater you've got your eye on, you verify the manufacturer's specs because wattage might range between models and manufacturers.
Knowing the wattage of your space heater is crucial, just like with any device you use for extended periods of time. This will help you determine how much energy it uses and how much it will cost to run.
When using a space heater with a solar generator, make sure the generator has the capacity to deliver the necessary watts to the heater.
How Much Electricity Does a Space Heater Use?
At 120 volts, a 1,500-watt electric space heater uses 12.5 amps of power. (Amps x voltage equals Watts.) However, how would that affect your electricity bill?
You are not charged by the utility for power in amps. You are charged according to the amount of electricity used, which is expressed in kilowatt-hours (kWh).
Take the wattage of the space heater and multiply it by the number of hours you use it each day to determine how many kilowatt-hours it needs and, consequently, how much it costs to run. To convert that figure to kWh, divide it by 1,000.
Let's explain this further in the following table, assuming 6 hours of operations per day and six months of operations:
Appliance Wattage
Length Of Time Powered
kWh Of Electricity Used
1,500 W
1 hour
1.5 kWh
1,500 W
1 day (6 hours)
9 kWh
1,500 W
1 week (6 hours/day)
63 kWh
1,500 W
1 month (6 hours/day)
270 kWh
1,500 W
6 months (6 hours/day)
1,620 kWh
How Much Does It Cost to Run a Space Heater?
A 1,500-watt space heater will cost about $0.20 to operate for an hour. Although it might not seem like a lot of money, you need to think about how frequently and for how long you use the space heater. How many hours does your space heater operate on a daily basis? Do you make daily use of your space heater?
For instance, you should budget $1.20 each day if the space heater at your home office in the basement is used for six hours each day. You should budget an additional $25.20 per month for your power bill to run your space heater if there are 21 workdays in a month. There are an endless amount of scenarios like this one.
To be honest, all this cost depends on the usage of the heater. Multiplying the total hours of use by $0.20 can immediately tell you how much your monthly energy bill will increase if the average 1500-watt space heater costs roughly $0.20 per hour to run.
Installing solar panels may be a wise investment for your house, as it is a widely recognized truth about solar energy. With solar panels, the typical home could reduce its annual power costs by over $1,500! The biggest solar savings in decades are available to households that install solar today since power costs are higher than ever!
The amount you really save will vary depending on a number of variables, including how much power you use, local energy prices, system size, and how your utility bills solar users.
The mean yearly power usage of a residential utility client in the United States is 10,715 kWh or around 892 kWh per month.
The average household pays about $125 in electricity bills each month when you compound that amount with the national average electricity cost of $0.14 per kWh. This implies that the average family could save about $1,500 a year on power expenses if enough solar panels were installed to meet this electricity use!
We really hope you choose to invest in solar energy for your house and the environment since we are enthusiastic about solar and clean energy. But we also promise to provide you with all the information necessary to make an educated choice.
BLUETTI PV350 Solar Panel
Considered an effective and versatile option for a reliable power supply, BLUETTI PV350 Solar Panel ensures to provide best features especially in offgrid and emergency scenarios.
Key Features
High Conversion Rate: Even when the sunlight is low, the solar panels ensure that they generate enough power to keep your space heater working.
Easy Setup: When buying new equipment, setting it up is the first question that comes to mind . Our BLUETTI PV350 Solar panels come along with kickstand which simplifies positioning for maximum sun exposures.
Durability: These solar panels can withstand any type of weather condition including rain and water exposure. This robustness is essential for outdoor purposes,making them reliable for long term use.
Portability: The easy transportation makes it advantageous for those who need mobile power solutions. Moreover the ability to fold them means you can carry them around with you anywhere.
If you are looking for more specifications, check out below:
BLUETTI PV 200 Solar Panel
The BLUETTI PV 200 Solar Panel is the further best solution to save energy and handle up to 200 watts of energy.
Let’s now see its key specifications which make it different from others.
Up to 23.4% conversion rate: This impressive conversion efficiency ensures a significant amount of sunlight is captured and utilized as the best possible energy resource. This matters a lot when we are connecting high-powered appliances such as space heaters to them.
Easy setup with a kickstand: The attached kickstand with the solar panel enables the setup to be easy, quick and convenient. The panel can be positioned at an optimal angle where it has maximum solar exposure.
Durable & splash-proof: DDurability with the weather is a very important point to be noted. Our solar panels are designed in such a way that they withstand extreme weather conditions. They provide reliable performances even in non-idealistic weather conditions.
Visit the link to learn more about the water-resistant properties of these solar panels.
Foldable & portable: If transportation and storage is taken into account, our solar panels are ideally created. Their foldability makes them portable and convenient to be moved easily anywhere.
200W solar power for fast charging: In this fast-paced world everybody wants things to be done quicker. The 200W solar power is perfect for reliable and steady charging of your devices and power stations, providing a robust power solution for your energy needs.
Do Space Heaters Use a Lot of Electricity?
The answer to this question depends on various factors such as wattage, operating time, cost, type, and efficiency.
The majority of space heaters are rated for 1,000–1,500 watts of electricity. For example, a 1,500-watt space heater consumes 1.5 kWh (kilowatt-hours) of power each hour of operation.
A space heater's power consumption is mostly determined by how long it is left on. For instance, a 1,500-watt heater used 6 hours a day consumes 9 kWh of power per day.
The cost of operating a space heater is determined by the cost of power in the area. Operating a 1,500-watt heater for 6 hours would cost $0.90 per day if the tariff is $0.20 per kWh. The total for a month (30 days) would be $30.00.
Are All Space Heaters 1500 Watts?
No, not every space heater has 1500 watts of power. A space heater's wattage is determined by its model, size, and kind. The majority of portable electric space heaters have a power output of around 1500 watts; however, more powerful and bigger versions might have a power output beyond 1500 watts.
Most individuals can get by with a basic space heater that can heat an average-sized room. These are typically 1,500 watts and cover an area of around 200 square feet. A personal space heater with 400–500 Watts can work well for heating a limited area or beneath a desk.
One proven strategy to reduce your monthly energy costs is to utilize a space heater to heat the areas you use rather than the entire house. For a home of nearly any size, space heaters are far less expensive to run than central heating, averaging about 20 cents per hour.
Larger and colder regions require more energy to heat; thus, the overall savings from employing a space heater are much higher. The typical space heater requires 1,500 W of electricity to operate. A space heater may be powered by four to five solar panels, as solar panels typically have a rating of 350 W.
The amount you can save from solar energy varies greatly, and it also depends on your location, how much power you use, what plans and rates you have, and more. Generally speaking, most homes may anticipate saving between $10,000 and $30,000 for the course of a solar panel system's lifespan.
One of the best methods to lower or completely eliminate your power cost is to go solar, but before you make the decision, be sure to receive estimates from many reliable installers.
