How Many Watts Does a Coffee Maker Use?
Do you love coffee? I know I do. And for coffee lovers, a coffee maker can feel like a daily essential. But have you ever wondered how many watts does a coffee maker use?
Most household coffee makers use around 600W to 1,500W, depending on the type, size, heating system, and features. Drip coffee makers use less power, while single-serve and espresso machines may draw more during heating and brewing.
In this guide, you’ll find out how coffee maker wattage varies by type and model, what affects its power draw and electricity consumption, how much it may add to your energy bill, and how a solar generator can keep your coffee maker running when grid power isn’t available.
Most household coffee makers use about 600W to 1,500W, depending on the machine type, heating system, capacity, and added functions. Drip coffee makers use less power, while single-serve and espresso machines draw more during heating, brewing, or steaming.
Coffee Maker Wattage by Type
Wattage varies by brewing method and machine design. The table below compares typical power requirements across common coffee maker types.
| Coffee Maker Type | Typical Wattage |
| Drip Coffee Maker | 800–1,200W |
| Single-Serve / Pod Coffee Maker | 900–1,500W |
| Espresso Machine | 1,000–1,800W |
| Coffee Percolator | 800–1,400W |
| Fully Automatic Coffee Machine | 1,000–1,500W |
| Commercial Coffee Machine | 1,500–5,000W+ |
Overall, simpler drip and percolator machines tend to use less power, while espresso and commercial models require more wattage for faster heating and more demanding brewing functions.
Coffee Maker Wattage by Brewing Stage
A coffee maker does not use the same amount of power throughout the brewing process. Power draw changes as the machine heats water, brews coffee, produces steam, or keeps coffee warm.
Preheating: Many household coffee makers may draw around 800 watts to 1,500 watts while heating water and bringing the machine up to brewing temperature. Water is heated to 195°F to 205°F (90°C to 96°C) before extraction begins for most hot coffee brewing.
Brewing / Extraction: Power draw commonly remains in the 800W to 1,500W range while the machine maintains water temperature and brews the coffee. Espresso machines may run a pump during extraction, while drip coffee makers rely mainly on the heating element.
Steaming: Espresso machines can again approach their rated wattage when producing steam for milk. Household espresso machines fall around 1,000 watts to 1,500 watts, although actual draw varies by heater and steam system design.
Keep-Warm Mode: Drip coffee makers use much less power, around 40W to 200W, to keep the carafe warm.
Standby: When the coffee maker remains powered on but is not actively heating or brewing, standby consumption may fall to only a few watts, often around 1W to 5W.
Coffee Maker Wattage by Brand and Model
While most household coffee makers fall within a similar wattage range, the exact power requirement can still vary by brand and model.
| Coffee Maker | Rated Wattage | Estimated Brewing Time |
| Bella Pro Series 5-Cup | 650W | ~5–8 min |
| Mr. Coffee 12-Cup | 900–1,050W | ~8–12 min |
| Keurig K-Classic | 1,500W | ~1–2 min |
| Keurig K-Mini | 1,400W | ~1–3 min |
| Nespresso VertuoLine | 1,260–1,350W | ~1–2 min |
| Nespresso Original Essenza | 1,150–1,260W | ~1–2 min |
| De'Longhi Dedica | 1,300W | ~1–3 min |
| Breville Barista Touch | 1,680W | ~1–3 min |
Brewing times are general estimates based on machine type. Actual time varies with serving size, preheating, drink settings, and whether milk steaming is used.
These examples show that coffee makers in the same category can still have different wattage requirements. Rated wattage affects how much power the machine may draw while heating and brewing, while actual energy consumption depends on how long it operates at each stage.
Basic Electrical Terminologies
Before we begin, let us gain an understanding of the basic terminologies about electrical consumption that you will encounter in this article.
Watt (W): Watt is the basic unit of power, equal to one joule per second.
Power: Power is the amount of electricity an appliance consumes at a given time. Hence, how many watts does a coffee maker use refers to the electricity consumed by a coffee maker at one time.
Kilowatt (kW): Normally, the digits of power are relatively high; thus, it is preferred to use kilowatts instead of watts. This is because 1 kilowatt is equal to 1,000 watts.
Kilowatt-hours (kWh): Your utility bill at the end of the month has the electrical consumption in kilowatt-hours. It refers to one kilowatt of power per hour.
The electrical consumption of an appliance is the power usage that makes up your monthly electricity bill.
How Much Does It Cost to Run a Coffee Maker?
Coffee maker electricity consumption depends on wattage, brewing time, keep-warm use, and how often the machine runs. A higher-wattage coffee maker may draw more power while heating, but total daily electricity use can still be relatively low because brewing lasts only a few minutes.
Energy Use (kWh) = Wattage (W) × Operating Time (hours) ÷ 1,000
Electricity Cost = Energy Use (kWh) × Electricity Rate ($/kWh)
The Data:
Coffee maker wattage
Time duration required to make coffee
The average cost per kWh in your area/state
Example:
Let the wattage of your coffee maker be: 2,000W
Let the time duration: 2 minutes
Let the cost per kWh in your area: 13.19 cents
Conversions:
Converting watts to kilowatts: 2000/1000 = 2kW (1kW = 1,000W)
Converting minutes to hours: 2/60 = 0.03 hours (1 hour = 60 minutes)
Converting cents to dollars: 13.19/100 = $0.13 ($1 = 100 cents)
The procedure:
Power = time * wattage
= 0.03 * 2
= 0.06 kWh
The utility bill per one usage = power * cost
= 0.06 * 0.13
= $0.0078
Monthly bill = 0.0078 * 30
= $0.234 / 23.4 cents
Therefore, the cost of making your coffee for 2 minutes with a 2,000W coffee maker is $0.0078 in one usage, while the monthly cost is $0.234. Of course, your monthly bill will vary depending on your frequency of coffee maker usage in one day and in one month, the wattage of your coffee maker, its running time, and the cost of kWh in your area.
The above is merely an example for you to understand the contribution of your coffee maker to your utility bill.
Energy Consumption Factors For Coffee Makers
Generally, a typical coffee maker uses about 700W to 1,500W, depending on the model, brand, and make. Yet, how many watts does a coffee maker use can vary depending on the type, size, and features of a coffee maker and the time it requires to make coffee. Therefore, you cannot rely on just one factor to ascertain how many watts does your coffee maker use; all aspects matter.
Let’s delve right into them.
1. Type
Various types of coffee makers are now found in the market. Some examples include drip coffee makers, espresso machines, and single-serve coffee makers. You must own at least one of them, don’t you? Well, the news is that drip coffee makers are the most energy-efficient, i.e., they require the least amount of power to generate coffee.
Espresso machines are less energy-efficient than drip coffee makers, while single-serve coffee makers need the most power to produce coffee. Undoubtedly, more power consumption means more utility bills.
2. Size
It must be cliche, but yes, a larger size requires greater power to make coffee. So, if you own a larger-sized coffee maker, it will definitely consume more electricity when compared to owning a smaller-sized coffee maker.
3. Features
Advanced coffee makers now come with super enticing additional features that make you want to buy that coffee maker right away. But wait! What about their power consumption? That’s right.
Additional features - such as warming plates and timers - will also cost you more in terms of your electricity consumption and, thus, your utility bill. So, better think thrice before directly going for the most tempting coffee maker to buy.
4. Brew Time and Heating Duration
How long does your coffee maker take to make coffee? The longer time it takes, the longer the device stays plugged to a socket, the more power it will consume. Naturally, the opposite is also true. The less time your coffee maker requires, the less power it will consume, and the less it will add to your utility bill. Of course, the time duration is not all that matters. Other factors contribute just as much.
Energy Consumption of Common Kitchen Appliances
A kitchen uses not just a coffee maker. Many other devices, such as microwaves, refrigerators, toasters, kettles, blenders, and others, are common electrical appliances used daily in the kitchen. Let us explore how many watts does a coffee maker use when compared to other kitchen appliances, shall we? Coffee makers have an energy consumption rate from 700W to 1,500W. What about the others?
Microwaves: Microwaves consume 600W to 1,200W of power; thus, they have a similar range to coffee makers. Therefore, microwaves utilize almost the same power that coffee makers do.
Refrigerators: Our ever-reliant storage device, refrigerators use up merely 300W to 800W of power, much less than coffee makers. Yet, refrigerators work continuously, unlike coffee makers that only remain plugged in for a few minutes. Hence, refrigerators’ power consumption is not exactly less either. Find out the best power generator for refrigerators when there is a power outage.
Toasters: Ranging from 800W to 1,500W, toasted also lie in the same category of power consumption as coffee makers. Like coffee makers, they, too, consume power only for short intervals.
Blender: Blenders consume power ranging from 500W to 700W. They also operate for short intervals; thus, blenders consume less power than coffee makers.
Kettles: Electric kettles have a power consumption ranging from 1,200W to 1,500W. Like coffee makers, they operate for short intervals; their power consumption is similar to coffee makers.
Kitchen Appliances |
Wattage |
Coffee maker |
700W to 1,500W |
Microwave |
600W to 1,200W |
Refrigerator |
300W to 800W |
Toaster |
800W to 1,500W |
Blender |
500W to 700W |
Kettle |
1,200W to 1,500W |
Can You Use a Solar Generator to Power Coffee Makers?
Yes. A solar generator can run most household coffee makers as long as its AC output meets the machine's wattage. Battery capacity then determines how long the coffee maker can run before recharging.
For coffee makers that typically draw around600W to 1,500W, focus on continuous AC output, battery capacity, and available recharge options. Pairing a portable power station with solar panels also provides another way to replenish the battery during camping, RV trips, or power outages.
BLUETTI Elite 200 V2 + 2×200W Solar Generator
The BLUETTI Elite 200 V2 + 2×200W Solar Generator combines 2,600W AC output, 2,073.6Wh capacity, and 400W of solar panels. At about 53.4 lb, the Elite 200 V2 is manageable for RV and campsite use, while noise levels as low as 16 dB help keep early-morning coffee quieter. Its 15ms UPS also provides backup support during brief outages.
Estimated Coffee Maker Runtime
- 600W Drip Coffee Maker: ~2.9 hours
- 1,000W Espresso Machine:~1.8 hours
- 1,200W Pod / Single-Serve Machine:~1.5 hours
Best Use Cases
It fits well for camping, RV travel, and shorter home outages, where you may want to brew coffee while also powering lights, phones, or other essentials. The solar panels provide another way to recharge when wall power is limited.
- 2600W | 2073.6Wh | LiFePO₄
- 15ms UPS Response Time
- 6,000+ Life Cycles to 80% Capacity
- MPPT Controller, BMS, and More
- Ideal for Home Backup and Outdoor Adventures
BLUETTI Apex 300 + B300K + 2×200W Solar Generator
The BLUETTI Apex 300 + B300K + 2×200W Solar Generator delivers 3,840W AC output, 5,529.6Wh capacity, and 400W of solar panels, giving plenty of headroom for 600W–1,500W coffee makers alongside a refrigerator or router. Its 120V/240V dual-voltage output, expandable storage, 0ms UPS, and up to 2,400W solar input make it a strong fit for longer home outages.
- 600W Drip Coffee Maker: ~7.8 hours
- 1,000W Espresso Machine: ~4.7 hours
- 1,200W Pod / Single-Serve Machine: ~3.9 hours
Best Use Cases
Better for extended home backup when several appliances need to stay powered at the same time. Expandable battery storage and solar charging make it more suitable for longer outages than occasional coffee brewing.
Runtime estimates assume approximately 85% usable battery capacity and continuous operation at the stated wattage. Actual runtime may vary depending on the coffee maker, operating stage, and other connected loads.
FAQs about Coffee Maker Wattage
How Many Watts Does a 12-Cup Coffee Maker Use?
A standard 12-cup drip coffee maker uses about 900W to 1,200W while brewing. After brewing, the keep-warm plate usually draws much less power, often around 50W to 100W. Actual wattage varies by brand, heating element, and features such as built-in grinders or digital controls. Check the product label for the exact rated wattage of your model.
How Many Watts Does a Keurig Coffee Maker Use?
Most Keurig coffee makers use about 1,200W to 1,500W while heating and brewing. For example, the K-Café Essentials is rated at about 1,520W, while the K-Mini is around 1,470W. Because this high power draw lasts only briefly, a typical brew uses roughly 0.03–0.05kWh of electricity, depending on the model and cup size.
What Low-Wattage Coffee Makers Work Well for RV or Camping?
For RV or camping use, compact 4-cup or 5-cup drip coffee makers around 550W to 650W are a practical low-wattage option. They are easier to run from a solar generator or smaller inverter than many full-size drip, pod, or espresso machines that draw 1,000W or more.Manual options such as an AeroPress, pour-over, or French press use no electricity themselves and can help save battery power when camping off-grid.
Final Thoughts on Coffee Maker Wattage
Knowing how many watts a coffee maker uses helps you estimate both electricity consumption and backup power needs. A coffee maker’s actual energy use depends on brewing time, keep-warm use, and how its power draw changes during each stage. To estimate running cost, convert wattage and operating time into kWh. If you are choosing a portable power station or solar generator, make sure its AC output meets the coffee maker’s wattage, then use battery capacity to estimate how long it can keep the machine running. For shorter trips or outages, the BLUETTI Elite 200 V2 + 2×200W Solar Generator offers a more portable setup, while the Apex 300 + B300K + 2×200W Solar Generator provides more capacity for longer home backup.
