Shop our products
All the energy drink-loving students struggling in their hostels, Listen Up! You can keep your drinks cool at pocket-friendly rates. Not only the students, but a mini fridge is a godsend for all those who want hassle-free cooling devices.
But before you add the mini-fridge to your shopping carts, do the math. You need to know what effects this device will have on your electricity bills. In this blog, we will discuss how many amps a mini fridge uses, their consumption cost, and the sustainable methods to reduce these costs.
What Are Refrigerator Amps?
Before we jump into calculating the amp count of your mini-fridge, let's find out what a refrigerator amp means. Refrigerator amperes or amps are a measure of how much current your mini-refrigerator draws from your electricity supply.
You need to know how many amps a mini fridge uses. That way, you will know whether your electricity system can bear the load of your refrigerator.
For example, when your electricity system can only handle 10 amperes, and you buy a refrigerator that uses 12 amperes, it won't work. That is the core reason you need to know how many amps a mini fridge uses.
How Many Amps Does a Mini Fridge Use?
The ampere usage can vary with the size, model, make, and efficiency of your mini-fridge. Most of the compact mini-fridges use less than two amperes when connected to the 120-volt outlet. On the other hand, it may consume between 50-100 watts, while some need 240 watts of power.
To be exact, most mini-fridges use 0.8 to 1.5 amperes of current when their compressor is running. But you must keep in mind that the compressor is not always running. It continuously goes on and off to maintain the ideal temperature.
If you want to calculate the customized number of amperes a mini-fridge uses, you will need to follow the given procedure:
1. Check the Manual:
The manufacturers always mention the electric requirements of every electronic device. You can look into the manual and find out the ampere cont the specific device demands.
2. Calculation:
If you have other specifications like wattage and voltage, you can use the formula to know how many amps a mini fridge uses. Here's the formula:
I (ampere) = watts/ voltage.
For instance, the standard household voltage in the US is approximately 120 V. If the mini-fridge you have purchased uses 100 watts of power, the current it draws in is;
I=100/120 = 0.83Amperes
This is what an average refrigerator requires. However, refrigerators come in various sizes with different current needs. Let's find out the ampere needs of different-sized refrigerators.
1.6-1.7 cubic feet mini-fridge:
This is the smallest size of the mini-fridge that you will ever come across. Although the amps can vary depending on the model and brand, these usually consume less than an ampere when connected to a 120V outlet.
Most of these fridges consume 50 watts of energy. Now, using the information, let's find out the exact amperage;
I = watts/Volt = 50watts /120 volts = 0.42A
3.2 Cubic foot mini-refrigerator:
Usually, these fridges need only 2 amperes of current from your electric system when connected to an outlet for 120 volts. Although this fridge is twice as big as the 1.6/1.7 cubic feet refrigerator, it still doesn't consume as much wattage. These fridges use only 80 watts of electric power.
I= Watts/Voltage = 80/120 = 0.67 A
4.4 Cubic Feet mini-refrigerator: Although the brand and the model play a crucial role in determining the amperage, we still expect a 4.4 cubic refrigerator to consume between 1-2 amperes. It may use electric power up to 115 watts.
I= Watts/Voltage= 115/120 = 0.96 A
Related articles: What's the Meaning of Amp Hour in Batteries?
How Many Watts Does a Mini Fridge Use?
How Many Amps Does a Refrigerator Use?
The compressors of your refrigerators need some amperes to work. Generally, household refrigerators need between 3A and 5A to keep your meal fresh. However, you can calculate the number of amperes your home refrigerator is using.
You can get the power ratings from the refrigerator manual, which is mentioned in watts. In the US, the voltage range is usually 120V. Now that you have watts and voltage, you can calculate the amperes your refrigerator is using:
I = Watts/Voltage
If your refrigerator uses 600 wattages and the electricity supply is 120 Volts, then the number of amperes your refrigerator uses is:
I = 600/120
= 5A
That is how you can calculate the number of amperes your refrigerator uses.
Related articles: How Many Watts Does A Refrigerator Use?
Selecting Right Refrigerator Sizes for Maximum Efficiency
Alternative Ways to Supply Mini-Fridge
Your grid supply might not comply with the ampere needs of your mini-refrigerators. You can use alternative ways to supply mini-fridges that will suit the amperage needs of your refrigerator. There are some sustainable sources of electricity that you can use and supply the products, no matter where you live.
Here are some of the products you can use to supply the products;
Elite 200 V2 Portable Power Station
The BLUETTI Elite 200 V2 Portable Power Station can provide you with 2600 watts of electric power and comes with a LiFePO4 battery that lasts longer. This powerful power station can be charged in several ways, ranging from solar panels to home outlets.
Here are some of the key features:
2,600W AC Pure Sine Wave Inverter (3,900W Power Lifting): This power station can provide you with a steady flow of 2,600 watts of energy. If you need a burst of energy to start up demanding appliances, this power station is at your service. In such cases, it can handle up to 3,900 watts in power lifting mode.
2,073.6Wh Capacity: It comes with a battery that can store 2,073.6 watt-hours of energy. If you charge it fully, you get over 2,000Wh of usable power for your needs.
LiFePO4 Battery with 6,000+ Life Cycles to 80%:
You can charge and discharge the battery over 6,000 times, and it will still retain at least 80% of its original capacity. This means you can use this battery reliably for many years (often rated for a 17+ year lifespan under typical use).(Not expandable; this model focuses on high density and compactness in its built-in 2,073.6Wh capacity.)
Multiple Ways to Recharge: You have flexible options to charge the battery according to the resources available. Enjoy the versatility it offers. You can charge it via solar panels (up to 1,000W max input for fast solar charging, e.g., full charge in about 2.4 hours with optimal panels); through a wall outlet (up to 1,800W AC input for ultra-fast charging, reaching 0-80% in as little as 50 minutes or 1 hour); via a car alternator (with fast DC charging options); a generator; or combinations of these for even quicker recharges. It also supports smart modes via the app for turbo, standard, or silent charging.
BLUETTI PV200 Solar Panel | 200W
This BLUETTI 200W Solar Panel is a quality-assured foldable solar panel that converts solar energy into electric energy. This panel comes with a long-term life and is easy to carry. You can use these panels with multiple solar generators and power stations.
Here are some of the key features of these solar panels;
Monocrystalline Solar Cells With Up to 23.4% Efficiency:
These monocrystalline solar panels come with 23.4% efficiency. This implies that these solar panel cells can turn 23.4% of solar energy into electric energy, which is quite a good amount. Now, enjoy your own homemade energy and reduce the carbon footprint load on top of that.
Long-lasting ETFE Coating:
The ethylene tetrafluoroethylene coating is one of the most durable coatings ever. It gives longevity to your solar panel and helps it last longer. It stays clean and is more efficient.
Foldable & Portable:
You can fold these solar panels to make them easy to carry and transport to places. You can shrink the panel by folding it, and there you go. It fits in your car.
Compatible With Most Solar Generators with MC4 Connectors:
You can connect this solar panel with several other solar products. It is compatible with almost every solar generator which has an MC4 connector.
12-Month Warranty:
Once you have bought these solar panels, you can live a stress-free life. It comes with a 12-month warranty to make you feel assured.
BLUETTI Apex 300+2*200W Solar Generator Kit
This BLUETTI Apex 300 Solar Generator Kit comes with a portable and powerful battery, which can be an alternative for the power supply. You can plug in several other devices at a time.
2764.8Wh LiFePO4 / 3840W PSW Inverter, 6000+ Charge Cycles: It is a powerful battery that can store 2764.8Wh of power. This LiFePO4 battery will last longer and can work at its best efficiency. You can charge and discharge the battery 6000+ times, and it will still be working fine enough.
Movable Power Station: This power station is portable, and you can move it easily for easy usage.
In-grid UPS Mode & Flexible 24/7 UPS Mode: You can connect this power station to the main power grid, and you can use it as an uninterrupted power supply. If there is a power cut in your area, it has the capacity to provide power 24/7.
BLUETTI 200W Solar Panel: This kit comes with 2 BLUETTI PV200 solar panels, which offer 23.4% efficiency. With its monocrystalline solar cells. The ETFE coating gives it the durability that you ask for. In addition to this, you can fold these panels for easy carriage and portability.
Off-grid Energy Storage: If you live in a remote area where electricity is inaccessible, you can use this power station to power your home. Use the solar panels to generate electricity and store the electricity in the battery for later use.
Multiple Devices Can Be Loaded Simultaneously: With this power station, you can load multiple devices at the same time.
Wrapping Up
A mini-refrigerator is a good choice for those who want their cold drinks to be cool but the process to be hassle-free. These refrigerators take less than an ampere, and you can calculate the customized amperage requirement using the formula.
