You're likely the proud owner of a solar generator. Or you're deciding if a solar generator suits your needs. Either way, one question we always see floating around the internet is: "How many solar panels can I connect to my solar generator?"
It is a valid question, and in this article, we aim to give you the answer and, once and for all, lay this question to rest.
Let's get started.
Understanding Solar Generator Capacity
Before we begin talking about solar panels and their role in your solar generator setup, it is important that you have a firm grasp on what energy capacity is.
The reason for this is that it can impact the total amount of solar panels you connect to your generator.
Solar generators are rated/sized by their capacity. In fact, your solar generator's capacity is normally stated in the model name itself.
For example, you may or may not already be familiar with our BLUETTI AC200P Portable Power Station.
See that 2,000Wh number? That is the energy capacity of the solar generator. And by the way, in case you weren't familiar, Wh stands for Watt Hours.
Watt Hours can also be translated to Amp Hours (Ah). Perhaps some of you are more familiar with that term?
Simply divide the Wh by the voltage of the battery. For example: 2,000Wh / 12V = 166 Ah
Check your generator's battery voltage in the user manual, as it may differ (e.g., 12V, 24V, or 48V).
Do keep in mind that while Ah and Wh are both used to express battery capacity, they are not the same:
- Ah = Charge capacity
- Wh = Energy capacity
Nevertheless, it is important to understand that your solar generator's battery capacity will generally have an effect on how many solar panels you can connect to it.
But we will get to this a little later.
Understanding Solar Panel Energy Production
Next, we need to understand energy production and how exactly it works. Most readers are likely familiar with how solar panels work.
For those of you who aren't familiar, we recommend researching the photovoltaic effect.
If you are not interested in researching this phenomenon, here's our quick breakdown:
Solar panels convert sunlight into electricity via a method known as the photovoltaic effect.
In order for the photovoltaic effect to take place, a solar cell (or panel) needs to be exposed to photons (which are simply small bundles of electromagnetic radiation).
These photons are absorbed by the solar cell through two different types of semiconductors:
- p-type
- n-type
These two semiconductors are joined together to create a p-n junction.
The p-n junction creates an electric field that directs electrons, generating a current that produces electricity.
How Many Solar Panels Can Be Connected To A Solar Generator?
Now that we understand what battery capacity is and solar panel energy production, we are better equipped to figure out how many solar panels we could connect to our solar generator.
The number of panels you can connect depends on the solar generator model you have or plan to buy.
BLUETTI offers a range of solar panels with varying power outputs, as shown below. These panels are compatible with our generators, provided they meet the model's input requirements.
Category |
SP100L |
PV120 |
SP200L |
PV350D |
PV60L |
Power |
100W |
120W |
200W |
350W |
60W |
Cell Efficiency |
23.40% |
23.40% |
23.40% |
23.40% |
24.70% |
Solar Generator Compatibility Table
Model |
Max Power Input |
Max Input Current |
Voltage Range |
Elite 30 V2 |
200 W |
10 A |
12 V - 28 V |
Elite 200 V2 |
1000 W |
20 A |
12 V - 60 V |
Elite 100 V2 |
1000 W |
20 A |
12 V - 60 V |
AC200L |
1200 W |
15 A |
12 V - 145 V |
Apex 300 |
2400 W |
40 A |
12 V - 60 V |
Please note that you may connect solar panels in series or parallel to make up the maximum power input.
Imagine powering your RV for a weekend camping trip with just two 200W panels connected to your BLUETTI AC200L. However, you need to make sure you stick within the specified current and voltage range.
Easy Steps to Solar Charging
Switching to solar charging may seem overwhelming at first, but the process is actually very straightforward once you understand the basics.
Step 1: Check Your Generator's Input Rating
Before connecting any panels, confirm your solar generator's maximum input power, voltage, and current limits. This ensures you won't exceed safe operating levels.
Step 2: Connect Solar Panels in Series or Parallel
Decide whether to connect your solar panels in series (to increase voltage) or parallel (to increase current). This setup depends on your generator's specifications.
Series: Connects panels end-to-end, increasing voltage but keeping current the same. Ensure the total voltage stays within the generator's range (e.g., 12V–145V for the AC200L).
Parallel: Connects panels side-by-side, increasing current but keeping voltage the same. Ensure the total current doesn't exceed the generator's limit (e.g., 15A for the AC200L).
Step 3: Use the Proper Cables and Connectors
Most BLUETTI solar generators include MC4 connectors, which make secure and safe connections simple. Always ensure connections are tight and weather-protected. Models like the BLUETTI Apex 300 come with MC4 connectors for easy setup.
BLUETTI Apex 300 – A Smart Energy Ecosystem
When it comes to solar charging at scale, BLUETTI has gone a step further with advanced models designed for flexible energy use. The BLUETTI Apex 300 is a prime example of this innovation. Designed as an all-in-one smart energy ecosystem, it forms the foundation of a modular platform that can grow with your needs. Out of the box, it provides a 2,764.8Wh capacity with 3,840W of output, but with additional batteries and units, it can be expanded up to an impressive 58kWh and 11.52kW. Built with long-term ROI in mind, it is both compact and powerful, ready for home backup, RV use, or complete off-grid living.
For home backup, four 350W panels connected to an Apex 300 can charge its 2,764.8Wh battery in about 2–3 hours of optimal sunlight, powering essential appliances during an outage.
Step 4: Position Panels for Maximum Sunlight
Place your solar panels at an angle and location where they receive direct sunlight for the longest duration during the day. Adjust seasonally for better efficiency.
Step 5: Monitor Charging Progress
Use the generator's built-in display or mobile app to track solar input, charging speed, and battery health. This helps you maximize efficiency and safety.
As you can see, the number of solar panels you are able to connect to a solar generator largely depends on which model you have chosen.
BLUETTI solar generators can typically handle 1–6 solar panels, depending on the model's maximum power input, voltage, and current limits, as well as the panels' wattage and configuration.
All in all, the most important thing you take into consideration is the specified current and voltage range.
You can find these amounts in the user manual of your specific solar generator model.
