How To Troubleshoot Common Problems With Solar Generators
02/04/2026
Solar generators have become increasingly popular as a clean and sustainable alternative to traditional gasoline generators in recent years.
These innovative devices use solar panels to convert sunlight into electricity, which can be stored in a battery and used to power various devices and appliances
Despite their many benefits, solar generators are still capable of running into unforeseen issues.
In this article, we'll discuss some of the most common issues that users may encounter with their solar generators and tips for troubleshooting and resolving these problems.
(Please note: This article is only intended to inform you of potential issues solar generators may encounter and how you would go about in theory fixing them. If you own a BLUETTI solar generator and encounter an issue, do not try to fix the issue yourself - This is what our warranty is for. For more information on our warranties take a look at this page.)
Problem #1: Insufficient Sunlight
portable solar panel system set-up guide
A solar generator converts sunlight into electrical energy. However, the most prominent issue that can arise with a solar generator is a lack of sunlight. When solar panels don't receive enough sunlight, they cannot generate enough electricity to power the generator, which can be a significant problem on cloudy days or in areas with limited sunlight.
Solution: To solve this issue, you can first check the location of your solar panels to ensure trees, buildings, or other objects do not obstruct them. If the panels are in a shaded area, it is advisable to move them to a sunnier location. Additionally, ensure your solar panels are angled correctly to maximize their exposure to sunlight.
If you are still not getting enough sunlight, investing in additional solar panels may be necessary to increase your power output. The number of panels required depends on the amount of energy you need and the intensity of the sunlight in your area.
Problem #2: Battery Not Charging
Solar generators can also face issues related to batteries not charging correctly, which can be due to several reasons, such as a faulty battery, a malfunctioning charge controller, or a loose connection.
Solution: To troubleshoot this issue, begin by examining the connections between your solar panels, charge controller, and battery to ensure they are secure and free of corrosion. Loose or corroded connections can impede the flow of electricity, which affects the battery charging process.
If the connections appear to be fine, check the voltage output of your solar panels to ensure they are producing enough power. If the solar panels are functioning correctly, the issue may lie with the charge controller.
To determine if the charge controller is the problem, test it to ensure it is functioning properly. If you find any issue with the charge controller, replace it with a new one to ensure the proper charging of your battery.
Problem #3: Inverter Not Working
The inverter is the component of the solar generator that converts the DC power from the battery into AC power that can be used by appliances and devices. If the inverter is not working properly, you may not be able to power any of your devices.
Solution: First, check the connections between the inverter and the battery to ensure they are secure. If the connections are good, test the inverter to ensure it is functioning properly. If the inverter is malfunctioning, you may need to replace it.
Problem #4: Overloaded System
Solar generators, as a renewable energy source, have a finite power output capacity, meaning they can only provide power up to a certain level. Connecting too many devices to the solar generator at the same time can result in overloading the system and causing it to shut down.
Solution: To prevent this from happening, it is essential to know the maximum power output of your solar generator and ensure that you don't exceed it. It is recommended to use power strips or similar devices to distribute power more efficiently and only connect essential devices.
It is also advisable to avoid running power-hungry appliances like refrigerators or air conditioners as they require a lot of power, which may overload the system (unless your solar generator is intended for this purpose).
Problem #5: Faulty Components
Sometimes, the problem with your solar generator may be caused by a faulty component, such as a damaged solar panel, battery, or inverter.
Solution: If you suspect a faulty component is the issue, test each component individually to determine which one is causing the problem. Replace the faulty component and test the system again to ensure it is functioning properly.
BLUETTI Warranty
Product Item Warranty Period(Months)
Power Station AC300 48
AC500 48
EP500Pro 60
EP500 60
AC200MAX 48
AC200P 48
EB3A 24
EB55 24
EB70 24
EB70S 24
EB240 24
AC50S 24
Battery Module B230 48
B300 48
B300S 48
Solar Panel PV120 12
PV200 12
PV350 12
Accessories ALL 12
While solar generators offer a clean and sustainable alternative to traditional generators, they are not immune to problems.
With proper maintenance and care, your solar generator can provide reliable power for years to come.
Please remember that this article is only intended to offer your some indicators on where potential issues may lie.
If you, or anyone you may know who owns a BLUETTI solar generator runs into one of these problems, never try to fix them yourself. This is what the BLUETTI warranty is for.
For further information on our products take a look at this page here
