announcement-bar-bg
announcement-bar-bg
Blogs Banner
4 Best Battery Backup for Refrigerators During Power Outages [2026]
Home Appliances
Bluetti TeamBluetti Team
Refrigerators are ideal for keeping food and medicine fresh and safe to consume. However, due to power outages, food and other consumables can become unsafe to consume. It is for this reason you need a battery backup for the refrigerator. Let’s look at the best options you can purchase today.
  • To supply power during outages
  • For food preservation
  • For cost savings
  • Peace of mind
  • Top freeze refrigerator
  • Side-by-side refrigerator
  • Bottom freezer refrigerator
  • Mini fridge
4 Best Battery Backup For Refrigerators
If you want a powerful yet flexible battery backup for your refrigerator, the BLUETTI Apex 300 is one of the most capable options available. Built with a modular design, the Apex 300 starts with 2,764.8Wh of capacity and can be expanded to 5,529.6Wh with a B300K Expansion Battery or 7,884.8Wh with a B500K Expansion Battery, providing more flexibility for longer refrigerator backup and other essential household loads.
The Apex 300 delivers strong AC output that can easily handle refrigerators and other essential appliances during a power outage. With its expandable capacity, the system can power your fridge for extended periods while still providing energy for other devices such as phones, lights, and small electronics.
Another advantage is its versatile charging options. The Apex supports fast charging through AC and solar input, helping you recharge quickly and stay prepared for unexpected outages. Its pure sine wave inverter ensures stable and safe power for sensitive household electronics.
For users who need even more power, the Apex can be paired with additional units through BLUETTI’s hub system to support both 120V and 240V appliances. This makes it a strong choice not only for refrigerators but also for whole-home backup, RV setups, and off-grid living.
bluetti elite 400
The BLUETTI ELITE 400 is an ideal battery backup for people who need reliable power both at home and on the go. Its compact and portable design makes it easy to place in your kitchen, living room, or even take along for outdoor activities.
You can charge the ELITE 400 using solar panels, AC outlets, or your car, giving you flexibility during power outages. With a 4,000Wh capacity, it’s perfect for running small to medium refrigerators, lights, and other essential devices for several hours.
Safety is a priority: the ELITE 400 comes with certifications including FCC and CE, and it’s backed by a 60-month warranty for peace of mind. It also offers multiple outputs, from USB-C and USB-A ports to AC outlets, allowing you to power a variety of devices simultaneously. Its sleek, space-saving design ensures it fits comfortably in tight spaces while providing reliable energy whenever you need it.
BLUETTI Elite 400 portable power station 2600W 3840Wh featuring AC, USB-C, USB-A ports and pure sine wave.
BLUETTI Elite 400 portable power station with 2600W AC output and 3840Wh capacity.
BLUETTI Elite 400 portable power station with trolley, 100% charge display, 2600W 3840Wh.
  • Perfectly Sized Solar Generator: 3,840 Wh capacity, just right for home backup and outdoor adventures.
  • Wheels and handles for easy transport
  • High Output: 2,600 W rated, 3,900 W lifting power
  • Ultra-low 3 W standby draw extends runtime
  • 15 ms UPS switchover during outages
bluetti ELITE 200 V2
Another great portable battery backup is the BLUETTI ELITE 200 V2. With a 2,048Wh capacity, it can easily power a mini fridge or a top-freeze refrigerator. For example, it can supply energy to a typical 150W fridge for over 50 hours, making it ideal for short-term outages or camping trips.
The ELITE 200 V2 offers multiple charging options, including AC outlets, solar panels, generators, and car batteries. You can also monitor and control the system with its built-in smart control, giving you the flexibility to power your fridge, small appliances, or electronics like laptops and coffee makers.
With up to 900W solar input, the ELITE 200 V2 can recharge in just a few hours, making it a reliable choice even in areas with limited sunlight. Additionally, it has expansion ports to connect extra battery modules, allowing you to boost total capacity and run more devices when needed.
portable-power-elite200v2
  • 2600W | 2080Wh | LiFePO₄
  • 15ms UPS Response Time
  • BLUETTI FridgePower
If you want a dedicated, "set-it-and-forget-it" solution engineered exclusively for your kitchen, the BLUETTI FridgePower is arguably the most innovative option on the market. Measuring just 75mm thick—roughly the width of a smartphone—this ultra-slim battery is designed to slide perfectly into the "dead space" right on top of or beside your refrigerator without requiring any professional installation.
The base FridgePower Core unit packs a 2,016Wh capacity, which provides enough energy to keep a standard modern refrigerator running for 1 to 2 days. For those in storm-prone regions expecting longer blackouts, the system is fully modular. You can easily connect up to three BC200 expansion batteries to reach a massive 8,064Wh capacity, yielding up to four days of uninterrupted cooling. It also delivers 1,800W of continuous output with a peak lifting power of 3,600W, allowing it to effortlessly handle the heavy power surges required to start a refrigerator compressor.
What makes the FridgePower exceptional during a blackout is its automatic 10-millisecond UPS (Uninterruptible Power Supply) switchover. The moment the grid fails, it transitions to battery power so fast that your fridge compressor never stalls and the interior temperature remains stable. Furthermore, it uses a bypass-first architecture with an industry-leading ultra-low standby power consumption of just 4W, preventing "vampire drain" and extending your cooling runtime by up to 5 extra hours per day.
The FridgePower also offers advanced peace of mind through its smart features. By connecting to the BLUETTI app via Wi-Fi, the system's "Extreme Weather Alert" actively monitors local forecasts. If severe weather is detected, it automatically pulls power from the grid to Turbo Charge itself to 100% in just 80 minutes, ensuring you are fully prepared before the storm even hits.
Looking for a reliable way to keep your refrigerator running during an outage? Compare the BLUETTI FridgePower and Apex 300 Home Backup to find a solution that matches your refrigerator's energy use and backup needs. Visit our Black Friday Deals page to explore available offers on refrigerator and home backup power.
FridgePower
  • 75mm Ultra-Slim Backup Design
  • 1,800W AC Output / 3,600W Peak Power
  • 10ms UPS for Seamless Backup
  • Expandable Capacity up to 8kWh
  • Ultra-Low 4W Standby Power Consumption
Comparison of 4 Battery Backups for Refrigerators
Feature
BLUETTI Apex 300 (Versatile)
BLUETTI Elite 400 (Portable)
BLUETTI ELITE 200 V2 (Portable)
BLUETTI FridgePower (Dedicated Fridge UPS)
Base Capacity
2,765 Wh (expandable)
3,840 Wh (non-expandable)
2,074 Wh (non-expandable)
2,016 Wh (expandable to 8,064 Wh)
Continuous Output
3,840 W
2,600 W (Power Lifting: 3,900 W)
1,800 W (Power Lifting: ~3,600 W)
Surge/Peak Power
Up to 7,680 W
Up to 5,200 W
Up to 5,200 W
Up to 3,600 W
Voltage Output
120V/240V split-phase
120V
120V
120V
UPS Switchover Time
≤10 ms / 0 ms (true UPS)
≤15 ms
≤15 ms
≤10 ms (true plug-and-play UPS)
Solar Input (Max)
~2,400 W (per unit)
1,000 W
1,000 W
1,000 W
AC Charging Speed
Up to 3,840 W (50A bypass)
Up to 1,800 W
Up to 1,800 W (0–80% in ~50 min)
Standard AC + solar
Design & Footprint
Portable but heavy (~85 lbs base)
Wheeled portable (~86 lbs)
Compact portable (~53–55 lbs)
Ultra-slim (75 mm / 3" thick, fridge-top/wall-mount)
Weight (Base)
~85 lbs
~86 lbs
~53–55 lbs
~43 lbs
Best For
Versatile home/RV/off-grid (fridge + multiple loads)
High-capacity portable backup (fridge, tools, RV)
Compact high-output portable (daily use + backup)
Dedicated fridge/meds protection – space-saving, set-and-forget
Fridge Runtime (Typical Modern Fridge)
30–48+ hours (base + expansion)
~30–40+ hours
~18–25 hours
21+ hours base; 3–4 days expanded
Key Unique Advantage
Modular + 12 kW bypass (EV charging capable)
Highest base capacity in portable form
Excellent value, fast charging, compact power
Lowest idle draw + ultra-slim fridge-specific design
The four battery backup systems for a refrigerator are ideal for different applications. The BLUETTI Apex 300 is ideal for powering large models such as side-by-side and bottom-freezer refrigerators, thanks to its high 3,840W output (7,680W surge) and 2,764.8Wh capacity that handles substantial startup loads and extended runtime.
For small models, the BLUETTI ELITE 200 V2 and BLUETTI Elite 400 are your best bet. Not only are they portable (with wheels and handles on the Elite 400), but they produce ample power—2,600W continuous (up to 3,900W lifting/surge) with 2,073.6Wh in the ELITE 200 V2 and 2,600W with 3,840Wh in the Elite 400—to run mini-fridges and top-freezer options reliably.
In short, you should consider your needs—such as refrigerator size, portability, or whole-home requirements—before choosing one of the above battery backup systems for your refrigerator.
If you need refrigerator coverage plus other essential household loads for longer outages, explore our home battery backup options to compare expandable systems for your household.
  • Your refrigerator’s power requirements
Before settling for a battery backup, you should consider the power requirements of your refrigerator. All models have their power ratings, so this is as easy as reading it. Besides, you can find the ratings in the user manual. The ratings are usually in watts (W).If a refrigerator shares backup power with another cooling appliance, check the combined running load, available AC outlets, and surge capacity, since compressor startup can briefly draw more power than normal operation.
  • Consider the battery type
  • Battery capacity
  • Recharge speed
For refrigerator backup, faster recharging is especially useful when grid power returns only briefly between outages. For example, the Elite 200 V2 can reach 80% charge in about 1.1 hours with TurboBoost charging, while the Elite 400 can reach 80% in about 70 minutes when AC and solar are used together.
  • Monitoring and control
If you’ll be away for an extended period, app monitoring can help you track battery level, real-time power use, charging status, and available system alerts remotely. These indicators make it easier to judge how much backup capacity remains for refrigerator or freezer during outage. BLUETTI models such as the Apex 300, FridgePower, and Elite 200 V2 can be monitored through the BLUETTI App, allowing users to check battery level and system status remotely.
Frequently Asked Questions
For shorter outages, the Elite 200 V2 offers 2,073.6Wh of capacity and about 13.8 hours of refrigerator runtime. The Apex 300 increases that to 2,764.8Wh and about 18.4 hours, while the Elite 400 provides 3,840Wh and around 25.6 hours. For 48+ hour backup, expandable systems such as FridgePower are a better fit, with capacity scaling from 2,016Wh up to 8,064Wh. For more detailed runtime estimates, see our guide on how long BLUETTI can power a full-size refrigerator.
