New Release: Elite 30 mini — The Personal Power You Will Actually Carry Everyday
Day
Day
Blogs Banner
Benefits of Solar Panels: Save Money and Gain Energy Independence Today
Bluetti TeamBluetti Team
Solar panels can help reduce electricity bills and offer off-grid electricity. Whether solar makes financial sense depends on your location, electricity rates, site conditions, export-compensation rules, ownership horizon, financing, and available incentives. Renters or people without a suitable roof can still consider portable solar or community solar where available. Rooftop systems are more permanent, while portable panels are better suited for camping, RVs, and emergencies. The federal residential tax credit, which was scheduled to expire in 2025, is no longer available, so it’s important to weigh the advantages and disadvantages of installing solar panels.
Can solar panels save you money? Depending on your goal, location, energy costs, and consumption, the answer to this query will vary for U.S. homeowners, campers, renters, and backup-power shoppers. Utility bills can be reduced for 25 years or more by using rooftop solar panels. White portable panels provide power for RVs, camping, mobile homes, and emergencies.
The 30% federal residential ITC, however, is now gone due to the end of the tax credit period on December 31, 2025, and the math has changed. But solar isn’t dead. It’s simply more dependent than ever on where you live, what you pay for electricity, and your specific needs. So, there are both pros and cons of solar panels.
In this article, we’ll share the drawbacks, and benefits of solar panels, their costs, payback periods, incentives, net metering, rooftop vs. portable options, and backup power options. Then you can determine what makes sense for you.
a depiction of benefits of solar panels
Benefits vs. Disadvantages at a Glance
Benefits Disadvantages
Can reduce electricity purchases and provide long-term bill savings Requires significant upfront investment for a rooftop system
Generates clean electricity with no emissions during operation Roof condition, shading, orientation, and site limits can affect performance
Can support portable, RV, camping, and off-grid charging Payback depends on electricity rates, incentives, financing, and export compensation
Can reduce exposure to rising utility rates Conventional grid-tied systems normally shut down during outages unless designed with islanding-capable backup equipment
In What Ways Can Solar Panels Help You?
When it comes to solar panel benefits, they are more than just about generating electricity. They include reducing your energy bills at home, and achieving energy independence. The sections beneath explain the pros of solar panels in detail:
Potential Electricity Savings
One of the biggest advantages of solar panels is generating your own power and buying less from the utility. Using the U.S. Energy Information Administration's 2026 year-to-date residential average of 18.16¢/kWh through June, a well-designed 8 kW system producing 10,000–11,000 kWh a year could save about $1,816–$1,998 annually. Here’s how:
Annual savings = Solar electricity generated × Utility electricity price
For an 8 kW system:
  • If it produces 10,000 kWh/year: 10,000 × $0.1816 = $1,816/year
  • If it produces 11,000 kWh/year: 11,000 × $0.1816 = $1,997.60/year
But savings vary sharply by state. Residential electricity rates in Hawaii can be higher than $0.45/kWh, and time-of-use rates are higher than $0.60/kWh. The high cost of electricity makes the economics of residential solar systems attractive. EnergySage's September 2026 Marketplace data estimates a statewide solar payback period of about 9.6 years in Hawaii.
Whereas in Louisiana and Idaho, where residential electricity prices were 13.49¢/kWh and 14.37¢/kWh, respectively, in June 2026, solar payback can stretch to roughly 16 years under current cost and production assumptions. Solar also protects against rising utility rates. Once installed, your system’s power cost is essentially fixed, while utility prices can rise with grid congestion, data center demand, and power plant retirements.
Energy Access and Flexible Charging
A foldable solar panel and solar generator can juice up devices, operate appliances, and provide power to critical equipment anywhere, without a roof, permit, or utility connection. For instance, the BLUETTI SORA 500 is a 500W foldable unit for RVs, camping, and off-grid adventures.
BLUETTI 500W Solar Panel
The BLUETTI 350W portable panel is coated with ETFE, making it durable and easy to transport. Both panels can be connected to standard MC4 connectors with compatible power stations for flexible off-grid charging.
BLUETTI 350W Solar Panel
High Solar Conversion Efficiency
Easy Setup with Built-In Kickstand
Durable & Splash-Resistant Design
Compatible with Multiple BLUETTI Power Stations
Foldable & Portable for Outdoor Use
Environmental and Maintenance Considerations
Pros of solar panels also include clean electricity production with no emissions during operation. Modern panels are warranted for 25 years and routinely perform beyond that period. They possess no moving components, requiring only periodic cleaning and an annual inspection in your monitoring application. Take that compared to a roof, HVAC system, or water heater, which will most likely need replacement in the same time frame.
an installation image depicting the advantages of solar panels on a rooftop
What Are the Disadvantages of Solar Panels?
There are a number of solar panel benefits, but there are also a variety of disadvantages. Here are the cons of solar panels explained in detail:
Upfront Cost, Roof and Site Limits, Financing, and Contract Tradeoffs
EnergySage's June 2026 Marketplace data puts the average U.S. residential solar installation price at about $2.60 per watt before incentives. But prices can significantly differ based on geography and project specifics. At that current nationwide market average, a 7 kW system would be about $18,200 before incentives.
7 kW = 7,000 watts
7,000 W × $2.60/W = $18,200
Your roof matters, too. Shading, orientation, and age can hurt the economics. East-west roofs generate less energy than south-facing roofs, and an aging roof may need replacement before solar installation or may require the panels to be removed and reinstalled if the roof is replaced later.
Financing distributes the expense but adds interest. Loans, leases, and PPAs all change the economics. Leases and PPAs can require $0 down, and customers may still save on electricity depending on the contract. Because the third-party provider owns the system, it generally receives applicable tax incentives and RECs. Transferring the contract when selling can be complicated.
Also, with the federal residential tax credit having expired, actual payback varies substantially with location, electricity rates, incentives, export compensation, financing, and system cost.
Do Solar Panels Save Money?
Having solar panels to power your home can save you money in the long run. However, there are other factors besides the system cost that can influence the actual cost-saving benefits of photovoltaic panels. Here are the primary inputs that impact payback, how savings can be impacted by incentives and utility policies, and a quick example of the numbers:
Key Payback Inputs
The simple payback calculation to better understand the solar panels’ benefits and disadvantages is like this:
Net installed cost ÷ Estimated annual savings = Payback in years
But that “simple” equation hides a lot of complexity. The actual inputs include:
EnergySage's September 2026 Marketplace data reports an average solar shopper payback period of about 10.8 years, although actual payback varies substantially by project.
  • Specifics of the installation (how many panels can be fitted on your roof)
  • The amount you produce each year (will vary according to your location, roof orientation, shading, and weather)
  • Electricity rate (how much you pay for every kWh. The higher, the faster the payback)
  • Net metering or export compensation (how much your utility credits you for excess power)
Incentives, Electricity Rates, Net Metering or Export Credits, and Financing
The Section 25D residential ITC has come to an end on December 31, 2025, and therefore residential installations in 2026 will not benefit from it. However, some states still offer incentives. Massachusetts, New York, and New Jersey have programs that help offset the loss. New Jersey’s SREC-II program pays a fixed incentive per megawatt-hour for 15 years, separate from bill savings.
Net metering remains the biggest policy factor in solar ROI. 38 states, Washington, D.C., and four territories offer net metering; utilities in Idaho and Texas have voluntarily adopted net-metering programs, while seven states use statewide distributed-generation compensation rules other than net metering. California's Net Billing Tariff uses time-varying avoided-cost export credits. The California Public Utilities Commission notes that these export credits are usually below retail electricity rates but can rise above retail rates during some high-value late-summer evening periods.
Simple Example Calculation
Let’s go through an example based on a homeowner in a mid-rate state to better understand the pros and cons of solar panels realistically in 2026:
  • System size: 7 kW
  • Installed cost: $2.60/W = $18,200
  • Annual production: 9,800 kWh
  • Electricity rate: $0.16/kWh
  • Annual savings: 9,800 × $0.16 = $1,568
  • Simple payback: $18,200 ÷ $1,568 = ~11.6 years
Assumptions: Here, the example assumes no state incentives, full retail-rate net metering, and that financing and maintenance costs are not included. The actual numbers will vary per person. Using EnergySage's September 2026 Marketplace methodology, the statewide payback estimate is about 12.7 years in New York and about 15.8 years in Louisiana.
What Are Solar Panels Used For?
Solar panels can be employed in a variety of applications and functions, not just for powering an average home, but also for portable, emergency power, and much more. Here we’ve explained solar panel uses for residential and commercial systems, as well as why solar panels are good for camping, RV travel, off-grid living, and backup charging:
Home and Commercial Electricity Generation
Rooftop solar offsets grid electricity. A grid-tied system reduces what you buy from the utility, while excess production may earn bill credits through net metering. But there’s a critical catch. Conventional grid-tied solar normally shuts down during a blackout.
Safety codes demand that inverters shut down when the grid fails to prevent hazardous backfeeding. To keep power during a blackout, the system needs an islanding-capable backup architecture. Many backup systems use a battery with a compatible inverter, while some specially designed inverter systems can provide limited daytime solar power without battery storage.
Camping, RV, Off-Grid, and Backup Charging
Portable panels are not intended for a whole-home system (unless paired with a large solar generator). Add them to the right equipment, and they create a versatile and potent off-grid system. BLUETTI has a wide variety of products that can be used for camping, RVing, and emergency backup. The components are all connected together like this:
The Power Hub: BLUETTI Apex 300
The BLUETTI Apex 300 is a portable power station with a high capacity designed to be used on the move or as a backup power source. It serves 3,840W of AC output, and up to 7,680W of Lifting Power. This unit can be employed to power systems at both 120V and 240V for RVs fitted with 30A or 50A shore power.
Its 2,764.8 Wh LiFePO₄ battery can also expand with B300K or B500K modules. With B500K expansion batteries, the Apex 300 ecosystem can scale up to 100 kWh. The Apex 300 supports fast 0ms or 20ms UPS switching depending on the operating configuration, while the base battery can charge from 0 to 80% in 45 minutes. Furthermore, a built-in app also monitors input and output in detail.
  • 0ms UPS Response Time
The High-Voltage Charger: BLUETTI SolarX 4K
The BLUETTI SolarX 4K is a solar charge controller that greatly expands the Apex 300’s solar capacity. It accepts PV arrays from 150V to 500V, compared with the Apex 300’s 60V built-in limit, enabling higher-voltage panels and longer cable runs with less power loss. The SolarX 4K accepts up to 4,200W of solar input and delivers 4,000W of charging power.
BLUETTI SolarX 4K MPPT solar charge controller and bundled XT60 solar cable.
BLUETTI SolarX 4K MPPT solar charge controller for fast solar charging.
BLUETTI SolarX 4K MPPT solar charge controller with green RUN light
BLUETTI SolarX 4K MPPT solar charge controller with RUN, WARNING, ERROR indicator lights.
BLUETTI 4kW solar energy storage system on home with Apex 300
BLUETTI EP500 solar power station and B300 batteries in modern garage with solar panels.
SolarX 4K & Locking Terminal to XT60 Adapter Cable(for Parallel Use)
4,000W Max. Solar Charging Input
Supports 150V–500V Solar Panel Systems
Safe Voltage Step-Down to Below 60V
Advanced MPPT with Electrical Isolation
Compatible with Apex 300, B300 Series, AC300 & AC500
In larger installations, BLUETTI's 12kW SolarX architecture uses multiple Apex 300 and SolarX units rather than three SolarX controllers on one Apex 300. The current 12kW configuration pairs 3 × Apex 300, 9 × B300K, 3 × SolarX 4K, and an AT1. It is designed with an isolated circuit to isolate the high-voltage solar array from the low-voltage battery system, which provides increased safety.
The Portable Power Source: 500W & 350W Solar Panels
Built for RV travel, the BLUETTI SORA 500W panels collapse into 22.4 × 17.5 × 3.3 inches and have tough ETFE. They possess an IP67 water-resistant rating with standard MC4 connectors.
The BLUETTI 350W Portable solar panel delivers portability features with the adjustable kickstand, ETFE coating, and MC4 connectors. At about 30.6 lbs, it folds for travel and functions well for camping and off-grid charging. It is compatible with the BLUETTI Apex 300 and other power stations with its output specifications.
For portable charging, compatible SORA 500W or 350W panels can connect directly to the Apex 300 within its solar-input specifications. SolarX 4K is intended for higher-voltage PV arrays: any array routed through SolarX must provide a combined input within its 150–500V operating range. Solar panels capture the sun’s energy, SolarX 4K optimizes and accelerates charging when used with a compatible high-voltage array, and Apex 300 stores and distributes the energy.
Bluetti Apex 300 solar generator connected with solar panels for RV backup power
Rooftop Solar vs. Portable Solar Panels
Both rooftop and portable solar panels generate electricity from sunlight, but they serve different purposes and lifestyles. The following comparison summarizes these solar panels’ advantages and disadvantages with respect to expense, installation, power generation, outage support, portability, and economics:
Feature Rooftop Solar Portable Solar Panels
Primary use Offset household electricity bills Camping, RVs, off-grid charging, emergency backup
Installation Permanent mounting. Requires roof assessment, permits, and professional installation No installation. Unfolds and connects to a power station
Cost About $31,135 before incentives for a typical 12 kW system $500–$1,000+ for high-capacity panels
Power output Multiple kilowatts. Can cover an entire home Typically 100W–500W. Powers devices and small appliances
Outage support Conventional grid-tied systems normally shut down during outages unless designed with islanding-capable backup equipment Can recharge compatible storage when solar conditions allow; stored energy can then support outages
Renters/movers Not practical. Long-term ownership commitment Ideal to take it with you
Economics Long-term investment; actual payback varies substantially by project Typically purchased for portability, resilience, or off-grid use rather than household ROI
How to Decide Whether Solar Panels Fit Your Needs
It’s not enough to just be aware of the advantages and disadvantages of solar panels. The type of solar system to choose depends on energy requirements, financial constraints, residence, and length of time the residence is occupied. Therefore, ask yourself these questions:
  1. What’s your goal? Lower utility bills? Off-grid charging? Outage backup?
  2. How long will you stay in your home? Because solar payback varies substantially by project, portable panels or solar generators may be more appropriate if you’re moving out in 5 years.
  3. What’s your electricity rate? Higher rates = faster payback.
  4. How much sun does your roof get? Shade, orientation, and roof condition matter.
  5. What’s your utility’s net metering policy? Full retail credit vs. wholesale export makes a huge difference.
When a Portable Panel and Solar Generator Make Sense
You might need a convenient power source without the commitment of a permanent rooftop system. Here are the situations where a portable solar panel paired with a compatible solar generator provides a flexible solution:
  • You’re a renter or plan to move soon
  • You want backup charging during short outages (not whole-house power)
  • You camp, RV, or spend time off-grid
  • You want a lower-cost entry point to solar without a major commitment
  • You want to take your power source with you
Portable panels function best when paired with a compatible solar generator, like the BLUETTI Apex 300, for off-grid charging and powering 120V and 240V loads. This makes it suitable for both RV life and home backup scenarios.
Solar power can be a good investment, but only if it is in line with the goal, site, cost, usage pattern, and system design. Over time, rooftop solar panels can save on electricity expenses. The average upfront cost of about $31,135 for a typical 12 kW system, project-specific payback periods, roof space constraints, and the loss of the 30% federal ITC make the numbers more critical than ever.
There are distinct benefits of solar panels, such as flexible power for camping, RVs, off-grid use, and short outages without a permanent installation. However, don’t judge solar by a universal payback claim. Decide on the system that best fits your needs, and calculate before you purchase.
For portable panels and backup power, BLUETTI has a very flexible ecosystem to offer here. You can pair BLUETTI SORA 500 or 350W portable solar panels with the BLUETTI Apex 300 power station. This will deliver a scalable setup that you can take with you or use for backup power at home. You can also use the BLUETTI SolarX 4K solar charge controller to expand the Apex 300’s solar capacity.
Frequently Asked Questions
Reduce electricity costs, safeguard against rising rates, generate electricity with clean energy, and charge on the go with portable systems. However, the benefits of solar panels vary based on location, roof suitability, and usage.
