Refrigerators are ideal for keeping food and medicine fresh and safe to consume. However, due to power outages, food and other consumables can become unsafe to consume. It is for this reason you need a battery backup for the refrigerator. Let’s look at the best options you can purchase today.
To supply power during outages
For food preservation
For cost savings
Peace of mind
Top freeze refrigerator
Side-by-side refrigerator
Bottom freezer refrigerator
Mini fridge
5 Best Battery Backup For Refrigerators
If you are looking for a battery backup for all appliances, consider buying this option. It has up to 19.8kWh capacity making it ideal for running just about any refrigerator. Whether you have a mini fridge or a top-freeze refrigerator, this battery backup will do the trick.
And thanks to its built-in technology, it runs within 20ms after the power goes out. The best part is that you can install it indoors or outdoors. And for peace of mind and convenience, it comes with an app for real-time monitoring.
Like other BLUETTI battery backups, it has a NEMA IP65 rating, making it ideal for use in harsh environments. For safety, the unit has a short-circuit protection feature. You can use it in environments between -20 C and 40 C.
If you want a powerful yet flexible battery backup for your refrigerator, the BLUETTI Apex 300 is one of the most capable options available. Built with a modular design, it allows you to expand the system with additional battery packs, making it suitable for both emergency home backup and outdoor power needs.
The Apex 300 delivers strong AC output that can easily handle refrigerators and other essential appliances during a power outage. With its expandable capacity, the system can power your fridge for extended periods while still providing energy for other devices such as phones, lights, and small electronics.
Another advantage is its versatile charging options. The Apex supports fast charging through AC and solar input, helping you recharge quickly and stay prepared for unexpected outages. Its pure sine wave inverter ensures stable and safe power for sensitive household electronics.
For users who need even more power, the Apex can be paired with additional units through BLUETTI’s hub system to support both 120V and 240V appliances. This makes it a strong choice not only for refrigerators but also for whole-home backup, RV setups, and off-grid living.
The BLUETTI ELITE 400 is an ideal battery backup for people who need reliable power both at home and on the go. Its compact and portable design makes it easy to place in your kitchen, living room, or even take along for outdoor activities.
You can charge the ELITE 400 using solar panels, AC outlets, or your car, giving you flexibility during power outages. With a 4,000Wh capacity, it’s perfect for running small to medium refrigerators, lights, and other essential devices for several hours.
Safety is a priority: the ELITE 400 comes with certifications including FCC and CE, and it’s backed by a 60-month warranty for peace of mind. It also offers multiple outputs, from USB-C and USB-A ports to AC outlets, allowing you to power a variety of devices simultaneously. Its sleek, space-saving design ensures it fits comfortably in tight spaces while providing reliable energy whenever you need it.
Another great portable battery backup is the BLUETTI ELITE 200 V2. With a 2,048Wh capacity, it can easily power a mini fridge or a top-freeze refrigerator. For example, it can supply energy to a typical 150W fridge for over 50 hours, making it ideal for short-term outages or camping trips.
The ELITE 200 V2 offers multiple charging options, including AC outlets, solar panels, generators, and car batteries. You can also monitor and control the system with its built-in smart control, giving you the flexibility to power your fridge, small appliances, or electronics like laptops and coffee makers.
With up to 900W solar input, the ELITE 200 V2 can recharge in just a few hours, making it a reliable choice even in areas with limited sunlight. Additionally, it has expansion ports to connect extra battery modules, allowing you to boost total capacity and run more devices when needed.
If you want a dedicated, "set-it-and-forget-it" solution engineered exclusively for your kitchen, the BLUETTI FridgePower is arguably the most innovative option on the market. Measuring just 75mm thick—roughly the width of a smartphone—this ultra-slim battery is designed to slide perfectly into the "dead space" right on top of or beside your refrigerator without requiring any professional installation.
The base FridgePower Core unit packs a 2,016Wh capacity, which provides enough energy to keep a standard modern refrigerator running for 1 to 2 days. For those in storm-prone regions expecting longer blackouts, the system is fully modular. You can easily connect up to three BlueCell 200 expansion batteries to reach a massive 8,064Wh capacity, yielding up to four days of uninterrupted cooling. It also delivers 1,800W of continuous output with a peak lifting power of 3,600W, allowing it to effortlessly handle the heavy power surges required to start a refrigerator compressor.
What makes the FridgePower exceptional during a blackout is its automatic 10-millisecond UPS (Uninterruptible Power Supply) switchover. The moment the grid fails, it transitions to battery power so fast that your fridge compressor never stalls and the interior temperature remains stable. Furthermore, it uses a bypass-first architecture with an industry-leading ultra-low standby power consumption of just 4W, preventing "vampire drain" and extending your cooling runtime by up to 5 extra hours per day.
The FridgePower also offers advanced peace of mind through its smart features. By connecting to the BLUETTI app via Wi-Fi, the system's "Extreme Weather Alert" actively monitors local forecasts. If severe weather is detected, it automatically pulls power from the grid to Turbo Charge itself to 100% in just 80 minutes, ensuring you are fully prepared before the storm even hits.
Comparison of 5 Battery Backup For Refrigerator
Feature |
BLUETTI EP800 (Home ESS) |
BLUETTI Apex 300 (Versatile) |
BLUETTI Elite 400 (Portable) |
BLUETTI ELITE 200 V2 (Portable) |
BLUETTI FridgePower (Dedicated Fridge UPS) |
Base Capacity |
9.9 kWh (with 2× B500) up to 39.6 kWh |
2,765 Wh (expandable) |
3,840 Wh (non-expandable) |
2,074 Wh (non-expandable) |
2,016 Wh (expandable to 8,064 Wh) |
Continuous Output |
7,600 W (up to 15,200 W parallel) |
3,840 W |
2,600 W (Power Lifting: 3,900 W) |
1,800 W (Power Lifting: ~3,600 W) |
Surge/Peak Power |
High (supports heavy 240V loads) |
Up to 7,680 W |
Up to 5,200 W |
Up to 5,200 W |
Up to 3,600 W |
Voltage Output |
120V/240V split-phase |
120V |
120V |
120V |
UPS Switchover Time |
<20 ms |
≤10 ms / 0 ms (true UPS) |
≤15 ms |
≤15 ms |
≤10 ms (true plug-and-play UPS) |
Solar Input (Max) |
9,000 W (up to 18,000 W parallel) |
~2,400 W (per unit) |
1,000 W |
1,000 W |
1,000 W |
AC Charging Speed |
Fast (grid-tied capable) |
Up to 3,840 W (50A bypass) |
Up to 1,800 W |
Up to 1,800 W (0–80% in ~50 min) |
Standard AC + solar |
Design & Footprint |
Large all-in-one indoor/outdoor ESS (NEMA 4X) |
Portable but heavy (~85 lbs base) |
Wheeled portable (~86 lbs) |
Compact portable (~53–55 lbs) |
Ultra-slim (75 mm / 3" thick, fridge-top/wall-mount) |
Weight (Base) |
~97–128 lbs (inverter + batteries) |
~85 lbs |
~86 lbs |
~53–55 lbs |
~43 lbs |
Best For |
Whole-home backup, high-power 240V appliances, solar integration |
Versatile home/RV/off-grid (fridge + multiple loads) |
High-capacity portable backup (fridge, tools, RV) |
Compact high-output portable (daily use + backup) |
Dedicated fridge/meds protection – space-saving, set-and-forget |
Fridge Runtime (Typical Modern Fridge) |
Multi-day (depending on config) |
30–48+ hours (base + expansion) |
~30–40+ hours |
~18–25 hours |
21+ hours base; 3–4 days expanded |
Key Unique Advantage |
Massive scalable home ESS with 240V support |
Modular + 12 kW bypass (EV charging capable) |
Highest base capacity in portable form |
Excellent value, fast charging, compact power |
Lowest idle draw + ultra-slim fridge-specific design |
The five battery backup systems for a refrigerator are ideal for different applications. The BLUETTI Apex 300 is ideal for powering large models such as side-by-side and bottom-freezer refrigerators, thanks to its high 3,840W output (7,680W surge) and 2,764.8Wh capacity that handles substantial startup loads and extended runtime.
For small models, the BLUETTI ELITE 200 V2 and BLUETTI Elite 400 are your best bet. Not only are they portable (with wheels and handles on the Elite 400), but they produce ample power—2,600W continuous (up to 3,900W lifting/surge) with 2,073.6Wh in the ELITE 200 V2 and 2,600W with 3,840Wh in the Elite 400—to run mini-fridges and top-freezer options reliably.
The BLUETTI EP800 + B500 Home Battery Backup is ideal for powering most of your house appliances during an outage, including refrigerators alongside other essentials, with its robust 7,600W output and expandable capacity starting from around 5kWh (with one B500) up to 19.8kWh or more.
In short, you should consider your needs—such as refrigerator size, portability, or whole-home requirements—before choosing one of the above battery backup systems for your refrigerator.
Your refrigerator’s power requirements
Before settling for a battery backup, you should consider the power requirements of your refrigerator. All models have their power ratings, so this is as easy as reading it. Besides, you can find the ratings in the user manual. The ratings are usually in watts (W).
Consider the battery type
Battery capacity
Monitoring and control
If you’ll be away for an extended period, consider purchasing a model with remote control capabilities. This allows you to monitor its performance from anywhere. Look for features such as mobile apps and digital displays.
